Question about SanDisk Electronics - Others
How many kilabytes in a one gigabyte USB drive
    Top Expert:
  • SanDisk Master
  • 10,875 Answers
10,000
Posted on Apr 13, 2015
Which is smaller, gigabytes or megabytes
megabits is smaller
if you want to back up 2.83 gb get a usb flash drive
get a 5gb unit
usb sticks (flash drive) rated at 5 gb will hold 4.5 gb of data as the rating is the total capacity but all flash drives require a small amount of space to work so the actual amount of data capacity is always less than the stated size on the flash drive
the capacity rating is-- smallest to largest --bytes, mega bytes , gigabytes, and terabytes
Nov 05, 2016 | Computers & Internet
Need Some Help in USB Booting
Hello to boot for usb you have to enter the bios to change the boot settings.
From here you can download a manual:
http://www.gigabyte.com/products/product-page.aspx?pid=2304#dl
There is also youtube:
http://www.youtube.com/results?search_query=gigabyte+bios+setup&oq=gigabyte+bios+&gs_l=youtube.1.1.0l7.6819.7546.0.10322.4.4.0.0.0.0.82.246.4.4.0...0.0...1ac.1.RKkQUHVyHD4
The F12 button is also an option under restart
If the setting is on in the bios.
This will give an option what drive you want to boot from.
Good luck
Oct 29, 2012 | Gigabyte GA-8I945GZME-RH Motherboard
Acer Aspire 5002WLMi Laptop won't recognize full 320 Gigabytes of new PATA hard drive. It's always been running a 80 Gigabyte 4200 RPM but that drive is old...a 2005 HD. New WD320 only reads 137...
The BIOS in the ACER determines the maximum size of the hard drive it can support.
Check the laptop's specification to see the max size you can install in this model laptop.
It appears that the max size your laptop can support is 140 Gb (unformatted). 137Gb formatted.
I suggest you install a hard drive up to 140 Gb capacity in your laptop and place the 320 Gb hard drive in an USB hard drive adapter case and when you attach this hard drive to the USB port in your ACER laptop then you will be able to get the full 320 Gb capacity after you delete the partition and create a 320 Gb partition and format the hard drive.
Nov 02, 2011 | Acer Aspire 5002WLMi Notebook
I want to download gigabyte ga8i915pmd mother bord drivers my computer
You can download the drivers from Gigabyte WEB support site,select your model motherboard to download :- http://www.gigabyte.com/support-downloads/support-downloads.aspx
Jan 21, 2011 | Exabyte 00678 LTO Cartridge (100...
My gigabyte 8S661FXMP-RZ system running server2003 sp2 no longer recognizes my coolmaster x-craft external usb drives, please help
Some times it happen due to improper removel of usb drives or malfunctionning with the ports on the board. first remove the usb drive >chk system tools>sub devices & ports the drivers are proper or not then rollover the drivers the problem is not solved re install the drivers. still have a problem get back to me
Jul 09, 2009 | Gigabyte Giga-Byte: GA-8S661FXMP-RZ P4...
Sandisk cruzer 2gb flash drive
Reset the whole memory stick via the PC should jog the memory and make it work.
Jul 07, 2009 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Gigabyte k8t890 m/b cannot find sata wd7500aacs drive
You must creacte a Floppy disk with SATA drivers so windows can recognize your SATA controller.
To creacte this disk you can boot whit your motherboard CD, or you can download dirver on gigabyte website and then copy it to a floppy.
If you are installing WinXP, you must press F6 when it asks if you have a third party scsi our raid controller.
Jan 14, 2009 | VIA Gigabyte GA-K8VT890-9 K8T890 Socket...
USB drive is not working - Drivers are installed.
Hi I m using Gigabyte GA-8I845GVM-RZ Motherboard USB drive is not working, printer, data cable, pen drive everying is not working but all the drivers are installed properly. Advise please. Arul selvan. M
Sep 03, 2008 | Gigabyte GA-8I845GVM-RZ Motherboard
How to correctly disconnect maxtor 500 gigabyte external hd
Hi, Normally the steps would be: 1. In your PC, in the System Tray, click on the "Safely Remove Hardware" and then on the "Safely Remove USB Mass Storage Device-Drive(?); 2. Unplug USB cable; 3. Power down external device. Hope this be of some help/idea. Good luck and kind regards.
Sep 17, 2007 | Maxtor OneTouch II external hard drive...
Electronics - Others Logo
267 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
