Question about Excalibur 5 Tray Food Dehydrator in White 3500W
Not a clothes dryer a food dehydrator Excalibur heater not heating?
My Excalibur fan works but heating element does not heat. looks intact is there a link or fuse?
Food dehydrator heat not working
What is the make and model please, some dehydrators only have fans and no heating element.
Here is a link to the manual which has a phone number to call if you still have problems:
http://www.nesco.com/customer_support/owners_manual_download/english/
http://www.nesco.com/products/Dehydrators/
Feb 20, 2017 | Kitchen Appliances - Others
NESCO FD-75PR Food Dehydrator quit working. Can I repair it? Company was very unhelpful. Suspect it was heat related? About how much are parts and where do I buy a part?
Does the fan run and just won't heat or is it completely dead. If the fan runs ok then look at the temperature dial. That is the thermostat. It could be bad. Next to check is the heating element itself to see if it isn't open. There's an inline safety device that may have opened too. It looks like a small silver cylinder with one end narrowing to a point. That usually goes first. Try googling Nesco parts to see if any parts are available.
Sep 11, 2014 | Kitchen Appliances - Others
Wont heat
Look for the thermal cutoff
Nov 30, 2013 | Nesco Gardenmaster Digital Food Dehydrator
My dryer is turning but the clothes are not drying. There is no heat in the dryer.
Check the dryer heating elements that they are intact. You will have to open the back. Chek for fuses in the dryer. Good luck
Jul 02, 2011 | Dryers
Have lost manual for my sunbeam dehydrator model AR72716 07-03 cannot locate one any where
Sunbeam only have 2 listed:
  • DT100E Healthy Food Dehydrator link to manual: http://www.sunbeam.com.au/PDFDownloadHandler.ashx?id=11092
  • DT5600 Food dehydrator link to manual : http://www.sunbeam.com.au/PDFDownloadHandler.ashx?id=11096
Does your dryer go by another name such as Excalibur?
Sep 06, 2010 | Sunbeam Vacuums
Wiring Diagram for Nesco FD60 Dehydrator
There is a recall on some of these. Check it out here:
http://www.cpsc.gov/cpscpub/prerel/prhtml11/11104.html
It has to do with something overheating. Maybe your unit is covered...
Apr 27, 2010 | Nesco Gardenmaster Digital Food Dehydrator
HAVE DEHYDRATOR THAT DOES NOT HEAT ANYMORE
Take apart the bottom unit that contains the heating element. Hopefully it's put together with phillips screws. Mine are not. I'd have to drill out the brads that are holding it together. Once it's apart, use an Ohmmeter to check the heating element. Be sure to disconnect the fan from the heating element when ohmming out the element. If the element is open electrically, replace it. Good luck in finding a place to purchase a new element.
Sep 12, 2009 | Nesco Gardenmaster Digital Food Dehydrator
No heat from condenser dryer
the heater element has to be tested with a multi-meter, the wires may be intact and it may look good, but looking good just isn't enough, it could also be a cut out that has tripped, there are normally 3 on a dryer, all need to be checked with a meter, easy job if you know what you are doing hope i have helped you where to look next, if so please rate me
Sep 29, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Heating element in Crosley Clothes dryer
Before you replace the heating element, check the thermal fuse. All heaters have safety thermal fuse. This opens in case the thermostat fails. This is normally attached on or near the heating element, looks like diode. (When replacing, do not solder ! this will damage the fuse)
May 30, 2007 | Crosley CDE6000 Electric Dryer
Excalibur 5 Tray Food Dehydrator in White 3500W Logo
408 people viewed this question
Top Excalibur Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Excalibur Kitchen Appliances - Other Expert? Answer questions, earn points and help others
