Question about Maytag Washing Machines
My Maytag washer 9501EWW will agitate and spin when there is only water in it but when you load clothes in it , it won' agitate or spin...how do I fix this
Was to start motoring running but no go
    Genius:
  • Maytag Master
  • 1,585 Answers
Mortor capacitor very suss
Posted on Apr 13, 2015
The start switch start the dryer but shuts itself when we release the button
Several different components could be preventing your dryer from continuing to run when the start button is released. The wiring diagram and other technical information for your dryer are shown in the image below. When the start (PTS or Push To Start) button is pushed, the PTS contact is closed and voltage is supplied to the drive motor. Start voltage is also sensed through the blue/black wire that is connected to the P1-5 Start Sense pin on the control board. When the control board senses the start voltage, it normally applies 48 volts DC voltage through the Pink/Black wire to the motor relay to hold the contact closed between the two blue wires attached to the motor relay that supplies normal run voltage to the drive motor. With the start button taped down, the motor continues to run since it gets voltage through the closed start button. Since the motor stops running when the start button is released, it indicates that you have one of these 3 failures:
Broken or disconnected Start Sense wire.
Failed electronic control board that is not sending the 48 volts DC voltage through the motor relay Failed motor relay. Wiring failure between the components.
Since the motor relay and the heater relay are both exactly the same part, you could unplug the dryer and switch the motor and heater relay to see if the dryer will stay running. If it does, then you just need to order and replace the bad relay.
Jan 05, 2017 | Dryers
Motor humms but wont engage
The start capacitor or start winding has gone bad. Or bearings are dry.
Don't run motor if it does not rotate full speed or motor will overheat and go bad.
Replace or repair motor.
Each motor has 2 winding circuits.
Start winding and run winding.
Both windings receive power same time.
Start winding has capacitor that releases sudden burst of electricity that starts motor rotation. Kind of like low speed on transmission.
Run winding then brings motor up to speed.
http://waterheatertimer.org/images/Motor-wiring-500.jpg
http://waterheatertimer.org/pdf/AO-Smith-motor-wiring.pdf
Nov 07, 2012 | Pool & Spa
My dryer will only run for 5-10 minutes
sounds like you have a bad motor,when it heats up it's stalling and when you go to restart it there are start windings and run windings in the motor it's not switching over to the run windings so when you hold the start switch in you're sending constant power to the motor,all it does is when you push the button it's a momentary switch power goes to the motor and hits the start winding in the motor should be just for a moment,then it switches over to the run winding and this keeps the motor running,your motor isn't doing this,
Dec 23, 2017 | Whirlpool Dryers
Amana front load washer hums only
A centrifugal switch to allow the motor to start up on the start winding and once started it opens to take it out of the start winding. The motor has to have voltage applied to the start winding and the run winding at the same time in order for the motor to start. The capacitor is part of the start circuit. When the motor goes to start, the voltage must be applied to the start winding in order for the motor to start or it will just hum. The moment the motor reaches a certain RPM the centrifugal switch opens up to remove the start voltage to the motor and it will remain running on the run winding. The motor will not start up on run voltage alone. It needs both, the start voltage and run voltage.
I think the problem is that the motor is not getting the start voltage supplied to the motor or the start winding has opened up in the motor.
Oct 22, 2011 | Amana NFW7300WW Washer
Washer runs until it gets to the Rinse cycle and stops... You can tell it wants to work because there is a faint humminb sound, but doesn't.
If the washer will agitate it's not a motor problem, capacitor or a broken motor coupler. It's either a loose wire connection on the start circuit or failed contact in the timer. When you say that the motor hums during spin, that would indicate that the motor has run voltage, but it has no start voltage. It needs both start and run voltage in order to get the motor started and running. The start voltage gets the motor started, and once started all it needs is run voltage to keep it running. The only difference between agitate and spin is that the polarity is reversed in order to start the motor in the opposite direction.
Jan 10, 2011 | GE 3.2 Cu. Ft. 14-Cycle Super Plus...
My blower motor will not start. it hums and gets very hot. i can spin the wheel with no resistance gmp075-4
Assuming you are spinning it when the motor is humming, if the motor runs after spinning it it could be the run capacitor (replace) or open/broken start winding in motor(need new motor). Humming should indicate the motor is getting proper voltage. If motor does not try to run by spinning then open run winding in motor (replace motor).
Aug 30, 2009 | Heating & Cooling
Not running at251201-01
Check if the motor winding is still OK. (Not grounded or
burnt windings) If still ok, replace the starting capacitor
and running capacitor of the motor. Start it up, see if
this will run normally. If it doesn't, check the centrifugal
switch. All this tips is for a capacitor start and run motors for pumpmotor service.
Jun 25, 2009 | Plumbing
Motor stops
Could be the run winding on the motor...indicating a bad motor. When you press the button, the start winding starts the motor, then the run winding kicks in to run the motor and the start winding turns off (it's no longer needed). You should replace the motor, that would be my first thought.
Feb 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Dishwasher motor won't run.
This motor has motor start relay behind the control panel
Wires to the mortor:
BU-W run from motor start relay.
Y wash (forvard).
GY drain (reverse)
W-V neutral.
Dec 08, 2008 | Dishwashers
Kenmore Electric Dryer Will not Run
there is a centrifugal switch on the dryer motor. pressing start energizes the start winding and the motor runs. when the motor is up to proper rpm the start switch is supposed to kick out and the motor runs on its run winding.
Sep 21, 2007 | Dryers
Washing Machines Logo
27 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
