Question about Audiovox Acam350 3.5 Inch Lcd Rear-view Monitor
How do I turn on the feature to parallel park correctly
The red, yellow and green zones use to show up but now they do not
Stopped midway through game turned to flashing red light, now wont turn on flickers to green then flashes red again
Maybe you have the RLOD (red light of death)
Have a look at this video.
http://www.youtube.com/watch?v=L3HMykBcVhs&feature=related
yellow light of death is the same thing its another name for Red Light Of Death.
This video shows u how to repair it.
Jan 04, 2011 | Sony Playstation 3 (PS3) Console
Wiring diagrams for clarion dxz535 car stereo
Here's how it goes:
Speaker wires:
grey=right front pos.
grey/black=right front neg.
white=left front pos.
white/black=left front neg.
violet=right rear pos.
violet/black=right rear neg.
green=left rear pos.
green/black=left rear neg.
red=12 volt switched power source
yellow=12 volt constant power source (direct to battery)
black=chassis ground
orange/white=illumination (switched source,not to head light switch)
blue/white=amp turn on lead (to remote turn on lead of amp)
blue=auto antenna (switched power source)
brown=phone mute lead (to cell phone mute lead)
RCA connector leads:
grey lead:
red=right front
white=left front
black lead:
red=right rear/right rear subwoofer
white=left rear/left rear subwoofer
(connect to external amp)
red lead:
red=right aux input
white=left aux input
(connect to external unit)
green lead:
red=right dual zone output
white=left dual zone output
(connect to wireless head phones)
That should be all there is. on the yellow that goes direct to the battery you need to use an inline fuse holder with 30 amp fuse.
Sep 26, 2010 | Car Audio & Video
Just need a diagram showing how to install the
If you need step by step instructions to wire something, you shouldn't really attempt to install a security system, as it will tie into almost every important electrical system in the car i.e. starter, door locks, lights, etc.
However, if you know how to get the lower portion of the drivers side dashboard off, and how to cut/splice a wire correctly and aren't color blind, you should be able to follow the installation instructions that came with the system. The wiring diagram for your car is:
What/ Color/ Where:
Constant 12V+ White Ignition Switch Harness
Starter Black/White Ignition Switch Harness
Ignition Black/Yellow Ignition Switch Harness
Accessory Yellow Ignition Switch Harness
Tach Blue Distributor
Brake Switch Green/White Brake Switch
Trunk Pin Green/Black (-) Above Fuse Panel
Parking Lights Red/Black Above Fuse Panel
Head Lamp Red/White Steering Column
Door Trigger Green/Red (-) Driver's Running Board (One of Two Wires)
Door Lock Green/White (-) In Driver's Door at Door Lock Module or at Anti-Theft Module under Driver's Seat
Door Unlock Green/Red (-) Driver's Running Board
Horn Wire Blue/Red (-) Steering Column, use Relay
Windows Up LF=Red/Blue, RF=Blue/Yellow
Windows Down LF=Red/Yellow, RF=Blue/Green
Jan 13, 2010 | XX-67A II LED/Valet Switch Pod
I installed the laser hp 1100 on windows xp
Your problem is your PC parallel port is not configured or turned on. I would first look in the control panel, device manager and see if you have a parallel port listed and it does not have a yellow or red sign on it. If red or yellow then it is on but not configured. See below for that solution.
If it does not appear, reboot your PC and enter the bios. Find the setting for the parallel port and set to enable. If on you can change the setting on what type of parallel it is emulating. Normal is bi-directional IEEE.
Then save and restart to go into Windows. Test and print.
OK, if the parallel port in the DEVICE MANAGER shows a yellow or red sign on it, it has a bad driver, or bad settings. Un-install the port by right clicking and choose UN-INSTALL. Restart your PC and it should find the parallel port and install it again. Hopefully without the yellow or red sign on it. If the red or yellow sign is back. Look on the internet for the newest driver for your motherboard.
As a note: if you are using a print server or USB to parallel adapter these solutions won't help. You will have other issues to address.
Good Luck
Dec 17, 2009 | HP LaserJet 1100 Printer
Installing a new radio, how do I remove the old radio?
Here's the basics..Same as a grand am if you've done one of those..Let me know if you need any other info.
Driver underdash. Harness going into firewall. (If there's two harnesses running parallel to each other they will be in the harness that is higher up)
Constant: Red (+)
Ignition: Pink (+)
Starter: Yellow (+)
Heat/AC: Orange (+)
Horn: Black (-)
Parking Lights: Brown (+)
Ignition Switch. Remove radio to access
Ignition 2: Dark Green
Passlock 2: Yellow and Black Wires
Driver Kick: Harness Coming In From Driver Door Boot
Trunk Release: Black/White (-)
Lock/Unlock: White (-) (Negative pulse to lock, unlock needs a 1,500 ohm resistor)
Dome Sup: Green/Black (-)
Door Trigger 1: Green/Black (-)
Pass Kick: Harness Coming In From Driver Door Boot
Door Trigger 2: Light Blue (-)
thats the wiring diagram for you
to remove the unit Disconnect cables from the rear & pull off front plate. (should pop off). Flat head driver needed.
Oct 27, 2009 | 2003 Oldsmobile Alero
I need the wiring color codes for speakers in a 2002 alero
Constant: Red (+)
Ignition: Pink (+)
Starter: Yellow (+)
Heat/AC: Orange (+)
Horn: Black (-)
Other
Tach: White @ Coil pack
Brake: L. Blue (+) @ Brake Switch
Oct 12, 2009 | OEM Systems Car Audio & Video
My video yellow plug works fine, showing correct video colors yet, the red blue green connection is only showing picture in a pale green
Yellow is composite input if RGB is not working it's probably a cable/output problem try with a different device first.
Aug 28, 2009 | InFocus ScreenPlay 4805 Multimedia...
Trailer wiring
you have to purchase a converter box with 5 wires, red, yellow, green and brown. this is because your turn signal is seperate from you parking and brake light bulb. you have to wire it straight in behind the connector.your basically converting two wires ( brakes and parking) to one wire (tailights) 5 wire to 4 wire.
Jul 12, 2008 | 2004 Ford Escape
Audiovox Acam350 3.5 Inch Lcd Rear-view Monitor Logo
Top Audiovox Video Cameras Experts
NOEL
NOEL
Tony Parsons
Tony Parsons
Are you an Audiovox Video Camera Expert? Answer questions, earn points and help others
