Question about Mitsubishi Televison & Video
How to determine if I need a new a ballast for my Mitsubishi dlp tv.. I just bought a new Osram bulb and it's working fine but now there's no picture. Need help!!
    Master:
  • Mitsubishi Master
  • 687 Answers
If the ballast were bad the lamp would not light up.
First be sure you have no picture on each input source, if not then try resetting the unit by unplugging unit for 1minute, then plug back in & turn on.
If still no picture you may have problem with light engine or video circuit.
Posted on Apr 14, 2015
SOURCE: 2 new bulbs, still dim picture
It could be a dirty projection lense or the light engine is malfunctioning by a slipped lense in front of the color wheel or the light engine is dirty it self. They are not two hard to take out if the mounts have set marks on them then it is easy to put the engine the way it was.
Posted on Mar 18, 2008
Big Poppa Ma
  • 302 Answers
SOURCE: I need a PWB POWER SUPPLY for a WD-62525 MITSUBISHI DLPTV
1-800-553-7278, this is mitsubishi parts dept
Posted on Dec 06, 2008
SOURCE: how to replace ballast in toshiba 52hm84 dlp rear tv.
how do I change the lamp?
Posted on May 15, 2009
ladywinn
  • 5138 Answers
SOURCE: My lamp on my Mitsubishi WD65733 DLP TV actually
No check for bad capacitors on Power supply board they will be vented swollen or puffed up on top.
Go to Encompass Parts Distribution and look up your Model number.
Posted on May 09, 2010
Sebin
  • 712 Answers
SOURCE: LG 52SX4D-UB DLP TV - tv tries to come on with the
Checking the lamp in another working television would be the best way to identify whether it is the ballast or the bulb which is the source of the problem.
Cheers. Thank You.
Posted on Oct 16, 2010
How do I fix a mitsubishi tv that shuts off and has a steasy red light
Replace your lamp. Make sure its a real Osram bulb and not some cheap knock off. These folks have Osram bulbs and a 6mo warranty. Projector Lamps and TV Lampson Sale ProjectorLamps com stocks Superior...
Sep 26, 2016 | Mitsubishi WD Televison & Video
Third time replacing 65" mitsubishi dlp bulb ?
Use Osram or Phillips bulbs
Check for blocked air flow
Always allow TV to complete cool down with plug in wall
Check/Replace ballast
Aug 22, 2016 | Mitsubishi WD-65638 65" DLP HDTV
My Mitsubishi tv WD 73734 won't show a picture you can hear sound and it powers on and off lamp light red and timer lighter blinking
No TVs will behave that way due to a timer. TVs only will display a nag screen telling you to reset the timer. If your lamp is more than 2 years old, it is suspect of failure. Be sure you buy a lamp with an Osram brand or Philips brand bulb inside. Any compatible(knockoff)lamps will not perform as they should. Mitsubishi DLP TV Bulbs
These folks sell original Osram bulbs in their lamps and they have a 6 month warranty. I use them myself for repairs and really have had great experiences with them.
Sep 09, 2015 | Mitsubishi WD-73734 73" Television
What can I do about my Mitsubishi WD-65737 having a dark screen and cutting itself off? We have already replaced the bulb and ballast.
Can you link a picture of the issue? If the picture is bright in some areas and not in others then it could be anything from the lamp lens, light tunnel, or any other mirrors or lenses. If the picture cuts off sharply, it may be something else. A ballast wouldn't cause that but a lamp could. Make sure the bulb is an Osram brand or Philips. Any knocks offs are not to be trusted regardless of how good they say it is. Without a picture or video of the problem, its hard to determine where the problem lies.
Jun 05, 2015 | Mitsubishi WD-65737 65"" rear projection...
I have a mitsubishi projection tv. I need to replace the bulb. Does any one know the difference between a pure glare bulb and a osram neolux bulb? Which bulb is right product for my tv? Also, which bulb is...
When in doubt check with sites such as www.TvRepairKits.com - check their online store first then email them if they do not show it. In most csases OSRAM is a great lamp...nore sure about pure glare...
Feb 22, 2013 | Philips 915P028010-P Projection TV...
I thought I had a bad bulb. Took out the old one and it was black and melted looking on the inside. Bought a new bulb and put it in the 61 inch DLP and the lamp light is still blinking yellow. I have no...
The tv have clicking noises sounds too?Yes?The board that call Ballast board it is dead too.This Ballast board only job are to ignite the tv projection lamp only.Tries websites like Partstore.com,Ebay.com to buy a new Ballast board for the replacement.
Aug 12, 2011 | Mitsubishi WD-62827 62" Television
My tv mitsubishi wd-60735 turns on for about 2 min. then shuts off and red lamp light turns on,,,The lamp is only 3 months old.. Do I just need to replace bulb again or is it something else???
Don't know if this applys to you but if you have purchased anything but Osram or Philips replacement lamp for your DLP tv then this is probably your problem.. The generic is VERY tempting in this recession but in this case generic is poison to your dlp tv... i have a Mitsubishi 60735 and went thru 2 generic bulbs when my tv kept shutting down on it's own and the lights on front would flash, i could cut it back on for 10 minutes then flicker and shut down again ..well since the bulb was new i thought it may be defective so i got is exchanged for another one ... after all of the post i have seen how much repairs were going to cost on dlp sets no matter what the problem was ..i was ready to chunk the tv out the door when the second lamp was doing the same thing.....!! well a last ditch effort to save my tv before i trashed it or taking it apart to dissect it.. was to buy a brandname lamp ... in my case i purchased a Philips ..it cost twice as much =/ ..i could just return it if it didn't work.. well it was the generic lamps that was causing trouble.. the brandname worked perfectly .. i am just glad the generic lamp didn't do any damage to my TV!!! I have done further research on the generic lamps and realized that the damage it could have done was not worth the money i saved when i purchesed it... Generic is a great deal In some cases (household cleaners, etc..) but in this case GET THE NAME BRAND!!!! the only name brands i know of for these lamps are Philips or Osram/Sylvania.. hope this helps others from this headache. Do your research don't by generic lamp replacements, your DLP set cost to much to risk it.
Jul 20, 2011 | Mitsubishi WD-60735 Projection Television
I have a infocus IN35 that at 100 hours burnt out a bulb. Thinking that it was just a bulb problem I bought a new bulb and it lasted 20 minutes. a t.v.repair shop said its probably the ballast that is the...
It is not a common problem. Ballasts rarely need repairs. Have you reset the lamp hours to zero after installing new bulb? If, yes to confirm about ballast please ask the TV repair shop man whether previously he had repaired any DLP projector. There is lot of difference in technology of DLP projector & TV (except DLP Projection TV). The problem could be in the projector main board. The lamp lights after getting Lamp ON signal from the projector main board. As the lamp ignites the ballast sends the signal of Lamp Lit. If the projector board senses that any blower/exhaust fan or colour wheel is not running then it will send a signal to Switch OFF the lamp. If you are tech-savvy then do as follows to check about lamp & ballast. Remove 5 pin connector from the projector. Connect projector to mains supply. Get a 5V DC power supply. Connect +ve to pin 3 & -ve to pin 4 of the ballast connector from this supply. The lamp should light. If it does not light then there is problem in the ballast (if the lamp is new). To give a chance you can check it for your lamp which lasted 20 minutes. Generally ballasts are made by OSRAM. You can get the ballast from OSRAM dealer. You will need the part number for that. Take out the ballast, it is there on it.
Apr 14, 2011 | InFocus IN35 Projector
New bulb/TV still shuts down
Its far more likely the result of the power pwb capacitors that have failed. As the 34 code will appear if the capacitors fail on the Power PWB. You can get the V26 DLP Power repair kit at the following link.with free instructions
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Apr 30, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Televison & Video Logo
52 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
