Question about Electric Mobility Shoprider Electric Power Wheelchairs Scooters Trooper
My Shoprider does not have a constant speed, even with new batteries and fully charged.
My husband said it might be the reostat
    Sergeant:
  • 313 Answers
This is a sign that the Wig-wag control is at fault or motor brushes need attention. Your husband is on the right track. you will need to take to a service centre for attention.
Posted on Jun 16, 2015
4 Suggested Answers
  • 61 Answers
SOURCE: Shoprider- wheelchair will not move-Lights keep flashing
This usually occurs when either the battery charger is still plugged in when the button is pressed to turn on the wheelchair, or if the joystick has got 'Locked'. On the majority of electric wheelchairs you can lock the joystick control so that the wheelchair cannot be moved, for instance, it it was left outside a shop. You would need a manual for the controller from the manufacturer to tell you how to unlock it. You should be able to find this online somewhere. Most controllers on shopriders are made by Penny & Giles (P&G Drives Technology). Hope thats helpful to you...
Posted on Mar 19, 2010
  • 313 Answers
SOURCE: i have a 4 wheeled shoprider sunrunner scooter.
Possible one or both batteries have had there day. How old are the batteries. If they are between 1 and 2 years old they will probably need replacing. it would be adviseable to get the batteries tested and have the charger checked as well. When did it have its last service ?
Posted on Aug 01, 2010
shastalaker7
  • 1515 Answers
SOURCE: Shoprider sovereign - fully charged
Hi, this sounds as though you are having a problem with the ignition switch. If and when you turn the key off and back on, and it shows a full charge, do you have plenty of power like it is fully charged? If not, your battery's are in need of service, and they will not hold a full charge. The cells with in them will sulfate causing the positive and negitive plates to corrode up, and not hold a charge for very long at all, even though the gauge shows it is fully charged. If you have someone that can buy a simple battery cell checker at any auto store, this will tell you the condition of each cell on each battery. Very inexpensive also. This would be the first thing to check. If the battery cells show in the good to excellent range, you will need to have the ignition switch checked out by a company that works on them. I wish you the best on this, and I hope I have been of some help to you.
Sincerely,
Shastalaker7
Posted on Apr 23, 2011
I have a shoprider model no.ph8-c new batteries and fully charged but only goes a few yards and stops any ideas I can't find a manual online for it
See if you bang on the top of the tiller when you start driving if it stops, then could be a bad Throttle Pot. Watch to see if only happens when you hit a bump or a certain speed, also watch to see if the power goes out this would indicate loosing a connection to the brain box or loss of a battery connection.
Oct 06, 2016 | Shoprider Health & Beauty
Should the battery lights go iut in quick succession ie within half mile on my shoprider cordoba?
hi, no , are they fully charged and if so how long do they take before being fully charged ?
Have you tired another charger ?
Regards
Rob
Sep 18, 2016 | Shoprider Health & Beauty
Why won't batteries charge?
Those chargers are designed to turn solid green when the batteries are fully charged. When batteries are less than new and have some time on them they will not charge as much as a new one. It is conceivable that either the battery condition is not the best there is or that perhaps there may be something wrong with the charger.
I suspect it is the new batteries not being so new.
Aug 29, 2015 | Shoprider Sprinter XL4
Hi, have a shoprider TE-889XL. Unit has new batteries and has had both the speed and throttle potentiometer replaced over the last 3 years to cure erratic throttle. Now with fully charged batteries it...
On older units this is a fairly common issue with loose, burned contacts at the battery terminal, battery harness plugs and circuit breaker. Check, clean and lube all the power connectors with a petroleum jelly. Don't use WD-40. Then retighten the connectors.
Another issue may be a bad key switch. Intermittent contacts can often be detected by wiggling the key when it starts acting up.
Oct 23, 2013 | Pride New Mobility Victory XL 4 Wheel...
My Battery on my Shoprider Delux is fully charged but lasts only about 45mins is my Battery Knackered?
first of all , this is a common mistake , can you borrow another charger to make sure that is not causing the problem , you need to convince yourself that the charger is okay then lok at the batteries located under the cover located under the seat, make sure the batterys connectors are clean and tight, if all fails sadly it is a batteries replacement.
Nov 21, 2012 | Shoprider Sprinter Deluxe Four Wheel...
Left chair unplug without charging battries are down and put charger on for 1 1/2 hours nothing has happened what do we do?
Hi,im disabled myself.when it comes to batteries,they gotta be treated as manufacturer says,please let the charger charge the batteries for the time given.Then go from there.I have a shoprider milan scooter.& even if i go 1/2 a mile i put them on charge so they are fully charged,my batteries are the Gel kind.But please read all info on Batteries.You can visit:shoprider.com & see what info you can download as a PDF File,print & keep for future ref,Colin.
Aug 01, 2010 | Jet 3 Ultra Power Chair
Shoprider xl4 deluxe has no power on inclines. lucky if it goes a couple of blocks even on the slightest grade ang the battery gauge goes to 1 light. Even with a fully charged battery has no guts on hills...
`Hi. Sounds very much like a loose battery terminal, or a faulty battery lead connector.
I have also had a few machines that can start jerking because of worn or stuck motor brushes.
Also check the high/low speed switch if you have one, they sometimes cause problems.
How old are your batteries, worn out batteries can still be " fully charged", but are unable to supply the current ( amps ), that the motor needs.
Good luck. Neil.
Jun 27, 2010 | Shoprider Sprinter XL4 Deluxe 4 Wheel HD...
My shoprider cobra loses speed when I am on top speed.
Hi. Does the machine do this more soon after removing the machine off the charger? When a mobility scooter is going down hill, the controller feeds the voltage generated by the motor back into the batteries. When I an testing machines here at the workshop, I have seen cases where 10 to 12 amps is going back into the batteries on a down hill run. If the batteries are fully charged or unable to take much current, the controller slows the scooter right down to limit the higher voltage generated.
It might pay to check the battery leads and connectors as well, and get the batteries tested.
While you are driving along, try moving the speed lever slowly up and down, not in and out as you normally use it. Sometimes a faulty speed pot ( wig wag ) will cause the speed to change.
Good luck. Neil.
Feb 14, 2010 | Shoprider Sprinter Jumbo 3
Shop rider sovereign voltage indication. Brand new fully charged
hi Richard,
Does the scooter actually lose power after the 3 leds show ?
If it is losing power then a suggest to try some other batteries to confirm dodgy batteries, check the terminal connections etc.
If it does not lose power then the volt meter is at fault, if you can check the voltage before riding then after it shows only 3 leds , if there is a big drop, check the charger first to make sure the batteries are getting fully charged.
Regards
GeWiz.,
Dec 21, 2009 | Electric Mobility Shoprider Electric Power...
Electric Mobility Shoprider Electric Power Wheelchairs Scooters Trooper Logo
103 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
