Question about Canon imagePROGRAF IPF710 Printer
Error code 03130031-2618
Just got this printer I need help connecting it and getting rid of this error code.
  • rizky
    rizky Sep 16, 2015
    Dear fix ya member,
    The problem is in the mainboard, you must check the printhead first, before change the mainboard. Why it can be happened?
    The Print head have a short circuit on the heater voltage, and the supplay voltage came from the main board. It is totaly problem from the mainboard not at the carriage unit, or the power supplay.
    please contact me if you wat to fix your plotter mainboard. My email is plottersolution700@gmail.com.
    New Friend:
    Problem Solver:
  • 9 Answers
Dear fix ya member,
Posted on Sep 16, 2015
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
It mean "Vh voltage error" and can be cause of short circuit in the printhead . Sometimes you can get good result with printhead changing, but it is not guarantied because of possible printer electric parts (carriage board, flat cable, motherboard or power supply) damage. For printhead changing, delete paper and use Service mode (hold Paper sourse + Information while switching printer on).
Posted on Apr 14, 2015
Ricoh Aficio Sg 3110Dn erorr code sc (20200)
Sometimes when you get an error on a printer you can just press the stop button or some have a clear button to get rid of the error code.
If that doesn't work, try unplugging the printer from the outlet for a few seconds then plug back in to reset the error code.
Dec 05, 2013 | Ricoh Aficio Sg 3110Dn - Printer - Color -...
Printer settings can not be changed error 0x000006d9
You can easily get rid off of Printer settings cannot be changed error 0x000006d9 within time by dialing HP Printer Customer Support Number 1(844)355-5111 24*7 available for your support to fix your printer error online with the help of brilliant technicians.
HP Printer Support Phone Number 1 844 355 5111
Jan 15, 2018 | Canon Office Equipment & Supplies
My canon pixma printer is showing error code 2 140 21 while scaanning???
i got this error while trying to scan. my ink cartridges were out of the printer (i was going to get them refilled). i stuck the cartridges back in and the scanner worked again.
Jan 20, 2012 | Office Equipment & Supplies
Printer showing error code 3802, says to go to kodak. com/go/aiosupport
I am new user of Kodak printer and i used to get error code 3802.
The main cause of the error 3802 is improper installation of printer driver. To get rid of this error you always ensure that properly install the printer driver.
I was looking for the solution and then found this using google. I found this link helpful.
http://printersupportsnumber.weebly.com/blog/kodak-printer-error-code-3802-its-cause-and-solution
Any other suggestions are welcome.
Thanks in advance.
Picturemate printer; how do you reset ink pad counter; or how do you get rid of the error message so you can continue printing
Hi
You need a reset ink pad software to get rid of this error message. Since you do not put the printer model and number. Try this link for epson printer only. http://www.ssclg.com/epsone.shtml. If not, use websearch to find your free software resetter for ink pad error message.
Let me know if you need more help
Mar 12, 2011 | Office Equipment & Supplies
Invalid engine code?
Try putting the old fuser back and see if it gets rid of the error, then if that's the case the new fuser is defective. If not, here's a link to the Lexmark website which gives you instructions on what to do when having that "Invalid Engine Code" error message. http://bit.ly/9D61W3. Hope this helps. Let me know if you need more assistance.
Apr 16, 2010 | Lexmark Optra T612 Laser Printer
KM-2035 error call service c6000
Hello sir; Just follow my instruction, I will help you to get rid off the error code; With front door open press10871087 then enter 163 press "start" key, final press " stop/clear " key to get out reset procedure.
Aug 23, 2009 | Kyocera Mita Office Equipment & Supplies
AIDC error code
When an “AIDC Error” occurs, do this:
1. Replace the Image Transfer Belt
2. Check to see if the AIDC Sensor is dirty
3. Securely connect the connectors to the High Voltage Unit
4. Replace PWB-A
Aug 05, 2009 | Konica Minolta magicolor 5430 DL Laser...
Eror Code 6B00
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
May 24, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Samsung scx-4521 f
if it's a vertical line in scanned pictures, it's probably a dust bunny on the scanner head, if it's only on printed pages, it's probably a dust bunny on or in the laser assembly or between the laser and the photosensitive drum. if cleaning doesn't get rid of it, you could have a defective scanner head or laser assembly, or a scratch on the photosensitive drum.
Jun 27, 2006 | Samsung SCX 4521F All-In-One Laser Printer
Canon imagePROGRAF IPF710 Printer Logo
204 people viewed this question
old marine
old marine
