Question about Casio Privia PX150 Digital Piano
My casio privia px150 turns on and makes a siren noise and the lights and buttons dont work and wont turn off unless unplugged
Sometimes if i unplug it and turn it back on some of the lights come on but no sound
SOURCE: Casio Privia keyboard PX-100
There are a number of issues that could cause this, the most likely culprit is the power supply, when I say power supply I mean the internal power supply,
This means that you have already obtained a good "known to work" AC to DC power supply, and tested it on your keyboard to see if that is the problem.
If you have completed this step, then your next step is to test your unit with batteries only, if the keyboard works, then you know your problem, is internal to the keyboard.
There are two issues to check, before proceeding please read the following note.
 (a note here for those who have no experience working with internal electronics)
If you have no experience working with internal electronics I would not recommend, opening your keyboard.
Two reasons, one, will void warranty if it still is under warranty.
secondly, you could accidently cause more damage to the unit.
Now if you are still reading, and feeling confident, you know that as a child you have dissembled many many electronic devices, just to see how they work.
If you do decide to open the box, disconnect the power supply to the unit including any batteries.
open the box and locate the power on button, clean using a Dielectric cleaning agent, can be obtained at most electronic specialty stores.
clean the power button, may work but doubtful, usually the switch itself is usually bad, there is a way to test the switch, however, that is beyond the scope of this answer, if you are following this you will most likely have the knowledge to do this.
The second and more challenging issue will be the internal power supply to the keyboard, or the interface that connects to your ac to dc converter.
This can be much more trickier, and I wont go into it here.
If you test your power switch determine that it is good then you should consider getting the unit serviced by a technician.
If you examine the boards, (electronic circuit boards,) and notice burned, connections, (darker than other circuits) then most likely it will not be worth trying to fix.
Hope this helps somewhat, if nothing else, take this print out to your local service dealer, and that will help in getting your keyboard repaired,
Delete this part, before taking this to your dealer,
Most electronic products can be easily fixed with a power switch, or power supply, however, many dealers will not tell you this and give you an estimate of fixing the unit that far exceeds the actual cost of repair,
an example, in a local TV repair shop, a friend brought in a wide screen Plasma HD TV, quoted repair, $654.00  problem,
power supply, actual cost, $75.00 my friend ordered the part online and with the help of a friend installed the new power supply returning his unit to full functionality.
So beware,
Posted on Mar 05, 2008
  • 5603 Answers
SOURCE: I have a Casio Privia PX-320. The left side keys
Check that the front of the keys is not hitting the lower plastic case front. If they hit it, then you need to disassemble the case partly and see what has shifted. It is ALSO possible that something has caaaused the aftertouch sensor to move out of position and it is hitting the keys early. ANY of these conditions needs to be addressed before damage is done.
Posted on Dec 01, 2009
  • 5603 Answers
SOURCE: I have a casio wk-200 piano. I bought headphones
The keyboard has a mic jack that is the same size as the headphones. You probably put the headphone plug into the wrong jack is all.
Posted on Jan 10, 2010
  • 5603 Answers
SOURCE: Casio wk-3700 keyboard started malfunctioning out
Check the power supply voltage or try another adapter.
Posted on Jan 19, 2010
  • 1138 Answers
SOURCE: Casio Privia PX-120 cannot be connected to Reason or FL
When you are using midi the sounds from your keyboard aren't sent anywhere. What happens is control messages are sent over the midi cable from midi out to midi in on the other device which must have midi sounds on it (in your case the sound card) to make any sounds. The messages can be things like note on/of or pitch bend etc. If you want to send messages to produce a result on your laptop and still here something you can loop the messages by running from midi out on the device end ( your laptop) back to midi in on your keyboard. A much better explanation is available here: I also signed up to this site (its free) that has great people and lots of info: I recommend downloading Killer Home Recording setting up which at this time is also free and has the best advice you could want in it. I'd also recommend checking out Reaper which is comparable to Reason, Cubase or Protools. If this helps please let me know.
Posted on Jan 21, 2010
C key is sunken down. The hammer action counterbalance isn't working properly
Check it again. It may have something dragging on the key, maybe something sticky like soda or juice residue. You can also try swapping out the key with another C or F key that is less used. Good luck!
Sep 24, 2016 | Casio Privia PX150 Digital Piano
How do I remove the cover to fix a popped-up key?
Fixing the keys on digital piano. try to watch the video maybe there is a tips to fix your piano. thanks
Dec 26, 2015 | Casio Privia PX150 Digital Piano
How do I unlayer notes on my casio privia 150 digital piano
I assumed you mean a PX150. Here is a link to a manual for that but I found nothing for a privia 150. It looks here to me on page 19 that you choose track 1 or 2 which seems to be left or right and if you start new recording on one of them, it deletes what was there.
Mar 03, 2014 | Casio Music
Privia 830 factory reset
TRY this;-
1. Turn off the digital piano
2. While holding down both the (TONE) and (FUNCTION) buttons, press the (POWER) button
Jan 11, 2014 | Casio PX-830 BK Privia
How to reset the Privia Px-110 back to factory setting
Try this
Nov 17, 2013 | Casio Privia Px-130 Px130 88 Key Digital...
Casio Privia px 130 One of the keys (e4) sometimes playes at full velocity even when pressed lightly. It happenes vary regularly which means I can no longer rely on the key playing softly. It is...
One of the two contacts for that key is not working. This could be dirty or damaged contact. They use a conductive rubber pills that the key presses against circuit board traces. One contact makes before the other and this is how velocity is sensed. Unless you are adept at this repair, I would recommend you take it in for repair. Chances are any part cost is negligible... mostly labor to open and access the contacts for cleaning. Clean ONLY with 99% isoprophyl alcohol and Q TIps... VERY GENTLY.
Jul 02, 2011 | Casio Privia Px-130 Px130 88 Key Digital...
I have a Casio Privia PX-130 and I tried to turn it on and it wouldn't turn on. I have noticed lately that when I would be playing a song that when I pressed a certain key that it would make this...
Test the adapter with a meter... Most probable cause is a bad power connector. Often the solder at the input power connector breaks loose is only problem. If you are not electronically adept, best to take it to a shop.
Jun 27, 2011 | Casio Privia Px-130 Px130 88 Key Digital...
Casio Privia PX150 Digital Piano Logo
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
