On off light showing -display lights no showing can't select cycle
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check door inter lock
Posted on Apr 13, 2015
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
Oct 05, 2015 | Bosch Dishwashers
Samsung front loading dryer the display shows rotating circle rather than time remaining
Rotating blinking lights in the display is probably an indication that the Wrinkle Prevent option has been selected. Wrinkle Prevent will continue to tumble the dryer without heat after the cycle has ended to help prevent wrinkles from setting in. When this option is selected by pressing the Wrinkle Prevent button on the control panel, the display will count down the estimated cycle time; when the cycle ends, the display will show lights blinking in a circular (or actually rectangular) motion.
To deactivate, simply press the Wrinkle Prevent button again so the light is not illuminated.
Jul 28, 2014 | Washing Machines
How does the self-clean feature work on a Frigidaire CFEF366EMB model?
Hi Beverly,
I understand that you are looking to run your self-clean feature on your Frigidaire range, model# CFEF366EMB.
-To start this you will remove all racks and make sure that any excessive spillovers are cleaned up as best as you can.
-Next you will press the "Clean" button, and the display will show "---".
-Press the up or down arrows to select the length of time you want the oven to clean. Usually 2 or 3 hours.
-The door will automatically lock once your time has been chosen and the "LOCK" indicator light will flash. DO NOT open the door while the light is flashing. (it takes about 15 seconds for the oven door to lock).
-"Cln" will appear in the display during the self-clean cycle and the "LOCK" light will continue to glow until the self-cleaning cycle is complete or cancelled and the oven has cooled.
When the self-clean cycle has completed:
-The time of day or "END" will appear in the display window and the "Clean" and "LOCK" light will continue to glow.
-Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened.
-If "END" is in the display and the Clean indicator light remains ON, press the "CLEAR/OFF" button and the time of day will appear on the display.
-When the oven is cool, wipe away any residue or powdered ash with a damp cloth or paper towel.
-Best Regards-
Jan 23, 2014 | Frigidaire Ovens
Can't select wash cycles
Is the control board displaying any fault codes?
Try disconnecting the power cord to the washer from the wall outlet for 5 maybe 10 minutes...give the control board enough time to power down and hopefully the control board could self-correct itself by resetting. No different than re-booting a computer.
If you still run into the same problem, and if so equipped, try holding down the "end of cycle" signal button for 10 seconds and see if that resets it.
Dec 07, 2013 | Kenmore Washing Machines
I can't select a cycle. The buttons quit working.
it sounds like the touchpad is gone,phone the manufacture and see how much it will cost ,and then take it from there
Mar 30, 2010 | Maytag 24 in. MDB7601AWS Stainless Steel...
How do I reset my 2008 Honda Accord oil %
Honda Accord 1998-09 To reset MAINT REQ’D light, press and hold select/reset button on right side of instrument panel. Turn ignition on and hold until the light goes out.
On the right of your dash is a pair of buttons, one for selecting/changing the odometer and the other for cycling from MPH to KMH and back.
Turn the key on.
Push the select button until your display indicated the remaining oil life percentage. When it is displayed press and HOLD the select button until it begins to flash. Once it starts flashing release the button and press and hold it again. The display will clear and if you release the button and cycle through the display with the select button you will see oil life 100%. Good luck and this should reset the oil life.
Oct 29, 2009 | 2008 Honda Accord
Control Locked
Locking controls
The Control Lock prevents unintended use of the washer. You
can also use the control lock feature to prevent unintended cycle
or option changes during a cycle. When CONTROL LOCKED is
lit, all buttons are disabled. You can lock the washer while it is
operating.
To lock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds.
The CONTROL LOCKED status light glows.
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
2007 FORD EXPLORER SPORT TRAC 4X4 Change oil light on
Press and hold the SELECT/RESET
control switch to select SYSTEM
CHECK when “SYSTEM CHECK /
HOLD RESET” is displayed in the
message center. Selecting this
function from the SETUP MENU
causes the message center to cycle through each of the systems being
monitored. For each of the monitored systems, the message center will
indicate either an OK message or a warning message for two seconds.
Pressing the SELECT/RESET control switch cycles the message center
through each of the systems being monitored.
The sequence of the system check report and how it appears in the
message center is as follows:
1. OIL LIFE RESET
2. CHARGING SYSTEM
3. WASHER FLUID
4. DOOR AJAR
5. EXTERIOR LAMP
6. BRAKE SYSTEM
7. PARK BRAKE
8. MILES TO EMPTY
9. FUEL LEVEL LOW (will only display if 50 miles or less to empty)
To reset the oil monitoring system to 100% after each oil change
[approximately 5,000 miles (8,000 km) or 180 days] perform the
following:
1. Enter SYSTEM CHECK to display
“OIL XXX% RESET IF NEW”.
2. Press SELECT/RESET control
switch to display “HOLD RESET IF
NEW OIL”.
3. Press and hold the
SELECT/RESET control switch for
more than 2 seconds. Oil life is set
to 100% and “OIL CHANGE SET TO
100%” is displayed.
Apr 02, 2009 | 2007 Ford Explorer Sport Trac
Washing mashine dispalys symbol not in users manual.Where time is displayed it shows a symbol that look like a padlock.The machine does have a key symbol on side panel. Door is showing unlocked. Cannot...
Try buttons "dry" & "spin" together for a few seconds. This could be the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............
Mar 30, 2009 | Electrolux EW1000i Front Load Washer
Bosch Axxis problem
Thought these additional details might help as we are having a similar problem.
When the washer is turned on we get a blank screen, then after a bit we see the display flash. After sometime flashing then we see it go to normal and we can run it. It is as almost as if it need to warm up...
We can get the display to show faster, by playing with the knob. However, the machine still needs time before we can use it.
Any ideas?
Thanks in advance.
May 04, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
