Question about Sunlight Supply EcoPlus Submersible Pump - 396 gph
THE PUMP START WATER RUNNING FEW MINUTES LATER STOP . ELECTRICAL CONNECTION OK.
Flashing code F21
EXPLANATION AND RECOMMENDED PROCEDURE
F21 LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:After 4 minutes the "Sd" error will be displayed, then
4 minutes later the "F/21" error code will be displayed. Press
PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Aug 16, 2015 | Washing Machines
I have a 2000 dodge Durango when it gets hot I have to wait about 10 to 15 minutes before it starts can't find the problem
Start with an error code if any read at your favorite auto parts store. How hot does it get? Possible so hot (cooling system problems) that the block sensor feeding the ECU is telling it there's a problem. A kind of safety system. Double check all cooling system components. Is the Water pump ok, or belt slipping? Battery and electrical system ok?
Mar 28, 2015 | 2000 Dodge Durango
2009 528i after driving 30 minutes and parked 30 minutes later no start, will jump start, new battery still does this. can't find Battery voltage status when running after jump car runs fine .
Have you tried disconnecting the hot wire from the battery to the starter and cleaning both the connection from battery and on the starter. A toothbrush and water/baking soda?
Jan 20, 2013 | 2009 BMW - 528i
Washing machine stop and start flashing o2f
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later
the F/02 error code will be displayed.
Potential Causes • Check the drain hose and make sure it is not plugged or kinked • Check the electrical connections at the pump and make sure the pump is
running. • Check the drain pump filter for foreign objects • If the above does not correct the problem replace the pump
Feb 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F21 code
F21 = Long Drain
If the drain time exceeds 8 minutes the water valves turn off. NOTES: ? After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed. ? Press STOP two times to clear the display.
Possible Causes/Procedure 1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check the electrical connections at the pump and make sure the pump is running. 4. Check the drain pump filter for foreign objects. 5. Plug in washer or reconnect power. 6. If the above does not correct the problem, go to step 7. 7. Unplug washer or disconnect power. 8. Replace the pump.
Jan 06, 2011 | Kenmore Washing Machines
I cleaned the pump filter after getting sud error. now i get F 21 code.
Press the pause cancel button 2 times this should clear it. If it does not and the filter and drain hose are clear you will need to replace the pump.
F21 Fault Code Repair
LONG DRAIN
NOTES:
Press PAUSE/CANCEL two times to clear the display.
LONG DRAIN
NOTES:
LONG DRAIN
NOTES:
Nov 03, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
F21 Code and door remains locked after unplug and restart same thing
Hi, If the drain time exceeds 8 minutes the water valves turn off. NOTES: ■ After 4 minutes the “Sd” error will be displayed, then 4 minutes later the “F/21” error code will be displayed. ■ Press STOP two times to clear the display.
Possible Causes/Procedure: 1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check the electrical connections at the pump and make sure the pump is running. 4. Check the drain pump filter for foreign objects. 5. Plug in washer or reconnect power. 6. If the above does not correct the problem, go to step 7. 7. Unplug washer or disconnect power. 8. Replace the pump.
Apr 12, 2010 | Kenmore HE3T Washer
My water pump stops and starts. the contacts on the pressure switch are closed and voltage is going to the pump. The pump will run for a few minutes but not long enough to reach the 60 # to turn off the...
A lot of these pumps do have automatic thermal switches built into the motor end cap, Double check that its being fed the name plate voltage and that the voltage doesn't drop when the pump is running (which would indicate a loose or bad connection or just undersized wire in the circuit)
Dec 12, 2009 | Plumbing
Started getting an F2 error code
I looked up the F02 code online and this is what it says:
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the electrical connections at the pump and make sure the pump is running.
Hope that helps.
May 18, 2009 | Whirlpool GHW9400 Duet Washer
Washer will not leave the drain cycle
Press PAUSE/CANCEL twice to clear the display then
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
It's because of a Long Drain condition. If the drain time exceeds 8 minutes, the water valves are turned off the code is flashed.
But Note: After 4 minutes the "Sud" error is usually displayed, then 4 minutes later the error code is displayed.
Jan 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Sunlight Supply EcoPlus Submersible Pump - 396 gph Logo
311 people viewed this question
Top Sunlight Supply Fish Experts
Richard Lindsey ...
ThothMer
ThothMer
Level 1 Expert
Tom Chichester
Are you a Sunlight Supply Fish Expert? Answer questions, earn points and help others
