Question about Refrigerators
I have a KichenAid side by side freezer/refrigerator, and for the first time ever we found a pool of water on the floor this morning around the fridge. It looks like the drain pan was overflowing.
What could cause this and how to fix it?
  • Refrigerators Master
  • 5,323 Answers
Highly unlikely the pan would over flow as it is evaporated by the heat of the compressor. or atleast suppose to . I would check for a clogged drain plug in the fridge unless u have a defrost problem where the ice is defrosting faster than the compressor can evaporate.
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Posted on Apr 22, 2015
  • 183 Answers
SOURCE: Kenmore / GE side by side defrost drain keeps freezing up
Check under the base, the tube must be clear to the water tray, often there is a rubber flow restrictor, this either perishes or blockes, either way remove it, defrost over night and then turn back on, should then work ok within 24hrs. Regards Adbvisor
Posted on Aug 23, 2007
hotuna
  • 288 Answers
SOURCE: Drain Pan overflowing
Refrigerators use different methods to eliminate the water, but they all use evaporation of some sort.This works,as most of the water in the drain pan comes from melted ice on the evaporator coil during the defrost cycle, and this is not very much. It sounds like you have excessive water in the pan. You stated the freezer/fredge is working properly. The condenser fan is running, I assume. Cleaning the dust off the coil will help the air flow. Most residential units do not have heating element in the drain pan. Your problem sounds like you are getting too much water in the pan. Have you noticed excessive ice in the freezer? Are the door gaskets in good shape. Does the unit have water and ice in the door? If so, where does the drain to, and has there been high usage of this?
Posted on Nov 11, 2007
  • 1462 Answers
SOURCE: Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
Posted on Sep 07, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool GD25DF auto defrost drain problem
There is a drain hole in the back of the freezer on the bottom. Get back there with some hot water. Most of the time it is just lime build up. Unless you know what feel back there. Another way is to move the freezer out and from the back side you can see the drain line. It just pulls right off
Posted on Feb 11, 2009
Healeyman
  • 1198 Answers
SOURCE: Whirlpool side by side defrost drain pan overflowing
Maybe your machine has a leaky door, letting moist air inside. Make sure your compressor area is lint free. The heat from the compressor is supposed to evaporate that water. Make sure the pan is exactly in the right place, level, not cracked.
Posted on Apr 25, 2009
How can I stop condesation building up on back wall of freezer side ? Water is running onto floor and pooling up.
Good Morning Friend,
I understand you have condensation building up on the back wall of the freezer side of your Frigidaire refrigerator, model# FGHC2342LF. I also see that this is a new refrigerator for you, and the water is pooling on the floor. It would take 24 hours for your refrigerator to stabilize at the set temperatures. First, I suggest giving it this timeframe. Secondly, if it is hot and humid, this is normal and can occur. Lastly, check with your installer to make sure that your refrigerator was installed correctly. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire FGHC2342LF Side By Side...
Gd5sha water under the freezer
This normally occurs when you have a large buildup of ice in the freezer, when it does a defrost there is just too much water for the hat on the compressor to handle. Make sure the door to the freezer & fridge is closing properly & the seal is in good condition & not falling off, moisture in the air causes frost in a freezer. So too many door openings can cause the same problem.
Nov 20, 2013 | Whirlpool Refrigerators
Lately there is a pool of water forming under and in front of the refrigerator . what can we do. It is a side by side Jennair?
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Aug 12, 2011 | Jenn-Air JCD2389G Side by Side...
We have an almost 4 year old Amana refrigerator with the freezer on the bottom #Abb1922FEW. From time to time we find puddles of water on the floor outside the refrigerator and dont know the ause or what...
OK the silent defrost pool drop problem. This is one that seem to be playing hide but most are just that leaving everyone wondering what caused the problem. This may be a little tricky but try to locate from what door thee leak is coming from. Also below the refrigerator there are possibilities also liker a crack in the defrost condensate pan near compressor or rven someting I found around mine a couple weeks ago. Someone had placed an object on the top near back of refrigerator and when it fell it became tangeled in the water supply hose to ice maker. I first noticed a small pool to the front and right of floor in the front of refrigerator.The ice bin was full so I did not think that a hose would be loose but it was and cause a pool of water about twice a day. Returned hose to its connection and have had no problems since. You may need to a little detective work yourself but I have found that is the best way. Here are a couple links I want you to read over and a short clip on how to fix a leaking refrigerator, I really hope to be of some help here, Thanks Sea Breeze
Click here to continue=> Leaking Refrigerator's Just What May Be Happening and then again here=> Leaking Refrigerator's
Apr 21, 2011 | Amana ABB1927DE Bottom Freezer...
My refrigerator expelled water tonight. Whe I woke, this morning, I found the floor with water. Can you tell me what could be happening?
if the drain is blocked in the freezer water can leak out onto the floor if it's leaking out of the frezer door.open the door and check the bottom rack,if it's frozen in or ice is on the floor of the freezer then it's the drain.also if you have a water line going to the machine one of the water lines could have cracked.let me know what you find and we can go from there
Jan 08, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
I found a water pool on the floor...
a coupltle thinges ,ur het plate to evaporate condensation it out, ur low on collant, or door sel is not sealing
May 30, 2010 | Magic Chef CTB2125 Top Freezer...
Water and ice in bottom of freezer, occasional water on floor
I believe your defrost condensate pan below the evaporator is blocked with ice and now when defrost happens the water pours over the tray and to the bottom of the freezer. You will need to defrost the ice in the collector tray and the pour a solution of hot water and clorox to make sure the water ends up in the condensate pan below your refrigerator. So unplug the refrigerator remove the panel and let me know what you find. I have some more solutions depending on what you see is happening. Thanks, Sea Breeze
Jul 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
It's snowing in my freezer!
it's not the filter. is there frost on the inside lower back of the freezer. or is it around the edge of the door are your ice cubes fuzzy can you here the fan running in the freezer
Jun 27, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kenmore elite side by side has water that pools in the freezer.
you need to clean out the freezer drain at the back of the freezer,use a hair dryer and a hanger or maybe a shop vac can **** it out-mike
Mar 16, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
