Question about Epson Workforce 610 All-In-One InkJet Printer
I have replaced all new cartridges and ran all the cleaning and alignment tests...still blank pages???
  • 63 Answers
Hi ya
its sounds like the print heads are blocked - this can happen by either not using the printer for long time or compatable inks
there is a hope, you can get head cleaning fluid - normally from ebay its not 100% guranteed to work and is a last resort
its normally about a £5 you get a small bottle of fluid / seringe and plastic tube,
instructions are normally provided or u tube videos will show you
hope it helps
Posted on Apr 13, 2015
Printer cartridge alignment checks
Is this with new cartridges or refilled?
If refilled, the nozzles may have become blocked which isn't the easiest thing to clear. If new cartridges, take them back for a replacement at the store and try again with new ones
Dec 12, 2011 | HP LaserJet 1320 Printer
I have try to print but its not printing. i've allready fill the ink still the page come out blank.
It could be due to the refilled cartridge that you are using. Refilled cartridges tend to degrade print quality and cartridge performance.
You can try to clean the cartridge nozzles. Please follow the steps below to fix the problem:
  1. On the printer control panel, press Copy.
  2. Press Options until Maintenance is highlighted.
  3. Press the right arrow until Align Cartridges or Clean Cartridges appears, and then press Select. A test page will then be printed forcing ink through the cartridge nozzles and clean them.
Try to print your document again to verify that the cartridges are working.
If that doesn't help, I would suggest you replace your cartridges with new genuine Lexmark cartridges.
Aug 17, 2011 | Lexmark X6150 All-In-One InkJet Printer
My printer has not been hooked up for a good 6 months. I recently installed it again on a brand new laptop, and everything installed correctly however when I send a print job to it, the pages come up...
HI!
When the printers are out of action for a while and since its alcohol based ink it tends to evaporate and glogg the head or ink!The best thing to do is to get new cartridges or if it has a separate printhead replace it!!
Hope it helps!!
Apr 02, 2011 | HP Photosmart C4180 All-In-One InkJet...
My hp officejet 6210 all in one is instaled under general heading: officejet 6200 series. Result: the printer reacts to command given by laptop windows xp but does not print given text. The paper comes out...
Are you able to print Self test page from printer ( standalone ) or able to make a copy ? if you are able to make copy/print self test page from printer, this issue is with Printer Drivers, You can uninstall and reinstall the software ( download the latest software and drivers from HP website )
If you are not able to make copy/print self test page from printer, it is issue with printer/cartridges... you need to re-align the printer
to clean/align cartridge
On Printer Front panel
Press - Setup Button ( press ok)
Press - Tools ( Press Ok )
Press - Clean Cartridges ( Press OK )
And/Or
Press - Align Cartridges ( Press OK )
Jun 22, 2010 | Office Equipment & Supplies
HP Deskjet 722c appears to print but the page is blank. New toner cartridges have been installed
If the clean test page shows streaked or broken colors, the printer or cartridges are not functioning properly. Note that HP cannot guarantee the quality of refilled or remanufactured cartridges. Follow the steps below to solve the problem:
  1. Remove and reseat the cartridges. Try printing again.
  2. Check ink levels, and if a cartridge is low on ink or out of ink, replace it and try printing again.
  3. Clean the cartridges. Depending on what printer you have, you can either print another clean test page or run a cleaning utility. Check your User's Guide for instructions. Try printing again.
  4. Clean the contacts, then try printing again. Click here to see how .
  5. Align or calibrate your cartridges (depending on what printer you have). Check your User's Guide for instructions.
  6. If none of the steps above have helped, clean the nozzle plate manually. Click here to see how .
  7. If the problem still has not been solved, replace the cartridges or service the printer. Click here to see how to decide which to do .
Feb 13, 2010 | HP DeskJet 722c InkJet Printer
Lexmark x73 - prints blank pages
This is a possibility however I can't be positive unless I were there to check it myself... where the printer hasn't been used in years it is highly possible that the ink in the cartridges has dried up. This is not uncommon.
It's also possible that the outlet for the ink on the cartridge itself is blocked with dried ink. You could place the ink cartridge itself in a saucer of nail polish remover (covering the electronic looking portion of the ink cartridge. Leave it there for 30 minutes. Blot dry it with a cloth and replace it into your printer. Try to print once again.
If this doesn't work, you most likely need new ink cartridges. Considering the cost of the ink cartridges for your printer, you are better off buying a new printer in which new ink cartridges are included. A new printer should only cost a little more than the cost of new ink cartridges. Considering you only require am all in one home use printer. Check online sites and check stores as there are usually sales ongoing.
Sep 22, 2009 | Lexmark X73 All-In-One InkJet Printer
Printer is printing every line two times and is faint
if you said you have done and removed the tape and run all test, chances are the cartridge itself is the problem , return to vendor for a new replacement, this can sometimes happen
Jul 23, 2008 | Dell 922 All-In-One InkJet Printer
Is it time to Replace my S200Print Head?
YES, IT IS EASY TO REPLACE THE CARTRIDGE, JUST PRESS DOWN A LEVER FOUND ON THE RIGHT SIDE OF THE PRINT HEAD AND EVERYTHING LOOSENS UP... YOU COULD ALSO CHANGE THE CARTRIDGE BY REPLACING IT WITH A BC-20 CARTRIDGE... IT'S A PURE BLACK CARTRIDGE.
Jan 05, 2008 | Canon BJC S200 InkJet Printer
C66 Inkjet Printer
If you have tried new cartridges and many cleaning cycles with no change, then it would be best to just replace the unit. Contact Epson as they may be able to offer you a good price on a replacement unit.
Apr 02, 2007 | Epson Stylus C66 InkJet Photo Printer
Epson Workforce 610 All-In-One InkJet Printer Logo
196 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
