Question about Samsung Galaxy S3
No network connection: no signal found for mobile networks
Does not register to mobile network
SOURCE: CONTINUOUS SEARCHING FOR NETWORK
change the settings to automatic network selection
if still the problem exists
then contact ur service provider
Posted on Feb 01, 2008
SOURCE: Can't register network in my Sigmatel dual sim card china make
Ibought the phoneSigmatel model CLX W919 from China but i am trying to connect the data cable to my computer to transffer some data but the computer is refusing to recognize the cable yet it can charge from the same cable.what can i do
Posted on Dec 31, 2008
lukem9962
  • 144 Answers
SOURCE: no network
are you trying to use it on o2 because it wont work after entering that code but that code usualy unlocks ur phone so try antother network sim
Posted on Apr 16, 2009
  • 89 Answers
SOURCE: I have a problem in
Try to reset it to factory settings, if it does not help upgrade the firmware or if you recently upgraded the firmware downgrade it.
Posted on May 23, 2011
arjunprasadk
SOURCE: samsung gtc3010s accepting t- mobile sim but no network signal
acsept sim but no network single
Posted on Aug 03, 2012
My samsung galaxy proclaim will not let me make calls {not registered in network} cant send texts or recieve text says no signal found for mobile networks no network connection . facebook works fine
Hello Kay
Your smartphone is two devices in one.
1. A phone that makes calls and sends text messages via over air signals via a cellular provider on a contract or pay as you go.
2. A device that can access the internet in two ways
2a. via your cellular carrier using a data plan.
2b. via a wifi connection using someone else's internet connection.
So yes, Facebook works fine via wifi, but you have no cellular network set up. Contact a cellular provider, sort out a contract and they will give you a SIM card to put in the phone and then your calls, text and data will work.
Jan 04, 2017 | Samsung Cell Phones
When you Galaxy Samsung Say Not registered on network when you trying to call someone How to fix that
According to WikiNix.com:
Step 1:
First, go to Settings.
Step 2:
Then go to Wireless and networks.
Step 3:
Then Tap Mobile Networks (If mobile networks not found then tap More settings and then find and tap Mobile networks). Watch video to understand and solve this issue easily.
Step 4:
Now tap Networks operators.
Step 5:
After complete searching.... Then select your Network Operator (Like Vodafone, Idea, AirTel, etc.)
That's it, problem solved.
Updated Fix 1. In Mobile Networks, set Network mode as WCDMA only and restart your phone. After restarting, follow above steps. That.s it (Updated on 12 September 2014). "
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
May 10, 2015 | Samsung Cell Phones
How do I fix my phone if I get the message" Not registered on Network"
There may be few possibilities like the network not recognized,
locked with some other network,firmware not updated etc...
Network Not Recognized:
First, go to Settings-->Then go to Wireless and networks.-->Then Tap Mobile Networks (If mobile networks not found then tap More settings and then find and tap Mobile networks).-->Now tap Networks operators.-->After complete searching.... Then select your Network Operator (Like Vodafone, Idea, AirTel, etc.)
Locked with someother Network:
I suggest you can approach Simpleunlocking.com and specify the country,locked network of ZTE .Based on the availability you can get the permanent unlock code along with free instructions.
UN-updated firmware or software:
Select Software Update and Wait For It to reboot and Completed Update Completed!
Oct 20, 2014 | ZTE Cell Phones
Cannot make a phonecall, message is not registered on network
I suggest you can approach Prounlocking.com and specify the country,locked network of ZTE .Based on the availability you can get the permanent unlock code along with free instructions.
Oct 03, 2014 | ZTE Cell Phones
What do i do when my mobile phone says 'mobile network unavailable?
The ideal solution temporarily is to find a spot with wifi.
The "network is probably not your phone's problem. Its either the network having problems or your location.
The problem is that u cant get a proper network at that place. In your phone, come to the home screen, where wallpaper & other options are displayed. There'll be two indicators, one of your battery, & the other, of the same style & behaviour, the network indicator. That tells you about your signal strength.
First, restart your phone, it'll refresh the network. If there's still a problem, then it means that u cant get a proper connection to that network. Then what u should do is- If you're in a crouded area, or in a room, go out in the open. Or if you're in a village, then you cant find signal there easily. But rather travelling for good network, you should use someone else's phone which can get signal or a landline. Or if you want signal, you'll have to travel to some distance, or maybe even a long distance. That's all which can be done.
Jul 31, 2014 | Samsung S5830l Galaxy Ace Black Unlocked...
I can't make calls nor receive
Check to make sure phone is registering in network. Check a network is selected. Try the following.
APN & data settings To set the Access Point Name (APN) and turn on data settings, follow these steps:
  1. From any Home screen, tap the Menu key.
  2. Tap Settings.
  3. Tap the Connections tab.
  4. Tap More networks.
  5. Tap Mobile networks.
  6. Tap Access Point Names.
  7. If available, tap the T-Mobile US APN (the bullet point fills with green). If not available, tap the Menu key, and then tap New APN.
    Note: To reset your APN settings, tap the Menu key and then tap Reset to default.
  8. Verify and update the following settings for the Data APN:
    • Name: T-Mobile US LTE
    • APN: fast.t-mobile.com
    • Proxy: <Not set>
    • Port: <Not set>
    • Username: <Not set>
    • Password: <Not set>
    • Server: <Not set>
    • MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
    • MMS proxy: <Not set>
    • MMS port: <Not set>
    • MMS protocol: WAP 2.0
    • MCC: 310
    • MNC: 260
    • Authentication type: <Not set>
    • APN type: <Not set> OR Internet+MMS
    • APN protocol: IPv4/IPv6
    • APN roaming protocol: IPv4
    • Enable/disable APN: <greyed out unless there are multiple APN's>
    • Bearer: Unspecified
  9. Tap the Menu key.
  10. Tap Save.
  11. Tap the desired APN profile you want to use. The bullet point fills with green next to the APN profile.
Manual network selection To manually select the wireless network the device connects to, follow these steps:
  2. Tap Settings.
  6. Tap Network operators.
  7. Tap Search now.
The device detects and registers on wireless networks inside T-Mobile's calling area, but roaming networks are usually restricted to T-Mobile SIM cards. You can manually select a network only in areas where T-Mobile does not own GSM spectrum.
Switch 2G / 4G To change the band between 2G and 4G, follow these steps:
  2. Tap Settings.
  6. Tap Network mode.
  7. Tap one of the following desired band settings:
    • GSM / WCDMA (auto connect)
    • GSM only (2G only setting)
    • WCDMA only
Turn on / off Airplane mode Airplane mode turns off wireless connections. This allows you to use apps and menus, but not make calls or use the internet.
To turn on or turn off airplane mode, follow these steps:
  2. Tap Settings.
  5. To turn on, tap Airplane mode to select the check box. Tap OK.
  6. To turn off, tap Airplane mode to clear the check box. Tap OK.
Jul 06, 2014 | Cell Phones
No network in nokia music xpress mobile
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Nov 02, 2012 | Cell Phones
My mobile has a special problem. The mobile shows a weak signal and sometimes zero signal at my home even though the other nokia mobile signals are very high at my home.(same network other nokia mobile...
Are they the same models?
The phone's capability to sustain a stable network coverage may vary even in model types.
While at your home,remove the phone's battery and simcard and fit them again.
Note how the phone's network signal registers.
It may start very high and then drop drasticaly to very low or no signal at all or sustain a constant signal reception.
If the reception's good in other areas,then your home area's network coverage may not be that good.
Hope this helps.Thanks!
Oct 31, 2011 | Nokia Cell Phones
How to have my phone a mobile internet?
The first thing you have is to have a mobile phone that are capable to have an internet connection.The next thing is to choose your network.After that you must register to your network..The internet connection..See the manual of your sim on how to register to the internet connection.
Jul 26, 2011 | Home
Thanks
I recommend you contact your service provider.
Blacklisted or Barred Handsets
What is it all about???
A phone may be blacklisted (or barred) for many different reasons, but the most common reason is that it has been reported either lost or stolen! It is only the networks (Orange, T-Mobile, O2, Vodafone etc) that have the facility to blacklist a handset.
If you are unfortunate enough to either lose or even worse have your phone stolen you should report it to your service provider (your network) immediately!
Your service provider can then blacklist the handset so that it can no longer be used to make or receive any calls. The networks do this by adding your phones serial number onto a national blacklist database (Central Equipment Identity Register). Effectively the handset becomes absolutely useless and the thief is in possession of a pretty paper weight! :-))
So How Does Blacklisting Work?
Every mobile phone has a unique serial number. This serial number is called the IMEI number (International Mobile Equipment Identity). It can normally be found underneath the phones battery and it is 15 digits long.
Now each time you switch your phone on or attempt to make a call the network systems check the IMEI number of the handset you are using. At this point the IMEI number of your handset is cross referenced with the Central Equipment Identity Register. If the IMEI number of your handset is on the CEIR then the network will either:
1) Refuse to send a signal to your phone (No signal strength at all)
2) OR WILL supply a signal but will not allow any outgoing or
incoming calls.
If your IMEI number is on the CEIR your handset is blacklisted and therefore useless.
Apr 27, 2008 | Samsung SGH-E370 Cellular Phone
Samsung Galaxy S3 Logo
52 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
