Question about Zephyr Napoli ZNA-M90S Stainless Steel Kitchen Hood
Range hood not working after short in light socket. Neither lights nor fans respond even with power.
I was replacing a light bulb when it shorted. The entire range hood refused to work after that. I looked online and read the manual but there do not seem to be a sure answer whether there is a fuse!? I tried to find where it is anyway. I disassembled as much as I can, but so far no success sighting it. I saw three light colored plastic containers next to blower. One for electric connection, one for control circuit and the third one with a big metal cylinder which i am not sure what it is used for.I checked that power is still coming in OK to connection box and the metal cylinder. Power is also going to control circuit and there is no obvious visible burns. What else can I try? Is there a good supplier for the circuit board/parts if it really comes down to that?
  • 833 Answers
SOURCE: Zephyr ZMI-M90S stopped working
The company doesn't list such a part. Probably, you have a bad connection in the unit. With the power off, remove the motor housing. Find the connection box and fix up the connections.
Posted on Dec 09, 2007
shaggyrat
  • 1224 Answers
SOURCE: Zephyr typhoon AK2100 Kitchen Range Hood
its the relay inside that controls which speeds the hood works at this connects to the switch speed control
Posted on Jun 01, 2008
  • 1462 Answers
SOURCE: Neither lights nor fans work
don't know model but they are all much the same.
there will be a pcb behind the control buttons and you will find some of the track burnt out causedd by the bulb blowing. do a soldered wire link across the burnt section of the track
Posted on Sep 25, 2008
  • 171 Answers
SOURCE: Zephyr Milano hood fan and lights stop working. Power is on.
Hi ronio,
I'm Harvey the Master Plumber.
Your problem is: After the power went out your Zephyr hood lights and fan don't work at all. There is a faint glow on the digital display but the fan and lights don't respond to pressing the control buttons.
First check the circuit breaker. If OK then check the transformer in the unit. It's next to the fan motor. If no power on the high side then you have a loose or broken connection. If you have no power on the low side the you have a bad transformer. If OK then you have a bad control board.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 27, 2008
SOURCE: Fan and light does not turn on .
FAN AND LIGHT DOES NOT WORK
my zephyr typhoon stopped working. Neither light not the fan come up. I am sure there is power going into the unit. I turned on the light one day , the light cam on and suddenly went away. From then even the fan stopped working. any information on what happened is appreciated. Thanks
Posted on Feb 07, 2010
Bulbs blew on my nutone allure range hood new bulbs does not work. please help
Depends what is wrong.To call a repair man will cost a service call before he starts. Check all your wiring and see if there is a short. See what you can do before you call a repairman.
Nov 04, 2014 | Broan-NuTone Kitchen Ranges
Viking hood Lights out
There is a short inside, you need to check wirings to locate the short.
Apr 05, 2008 | Viking VWH3048 Kitchen Hood
Turntable, lights and fan inop
sounds like a cross wire, and a short. I'd inspect the socket for the bulbs to ensure that there's no short circuit.
Feb 11, 2008 | Magic Chef CMV1000B Microwave Oven
Rookie mistake... Resetting Dacor? Or replacing fuse?
when you turned the light cover you turned the whole socket and the power connection shorted and blew relay board
you need relay board and light socket
Jun 24, 2017 | Dacor Preference RSE30 Electric Kitchen...
Replaced light bulbs but no light
Original bulb has a JDR designation. I ordered bulbs and received bulbs with a JDRC designation, the brand was Hikari--these bulbs were shorter than the original bulbs and will not seat properly even after removing filters and turning bulbs by the neck of the bulb (porcelain section). Since they won't seat completely in the socket there is no electrical contact and they won't work.
Feb 05, 2009 | Zephyr Savona ZSA-M90S Kitchen Hood
Sep 25, 2008 | Zephyr Typhoon AK2100 Kitchen Hood
Light bulb socket replacement for a really old Air Fare kitchen hood
The chances are that your range hood light socket was fully impacted with grease from cooking. Shut the power off to the range hood or, in many applications, simply unplug the power cord. Remove the socket. Get a spray can of electrical parts cleaner and saturate the socket through the tiny pin holes you may see at back of socket. shake out all of the cleaner fluid. Somehow hang the socket up with bulb base facing up all night. Hook it up. That might solve the problem.
It worked for me very recently on a 20 year old range hood.
DON'T USE ANYTHING OTHER THAN AN OFFICIAL ELECTRICAL PARTS CLCEANER. Most hardware stores, etc., have it.
Jul 23, 2008 | Kitchen Ranges
The extractor on my Baumatic fan stopped working. Thsi was shortly after the light bulbs blew which I replaced and they work OK. Any suggestions as to how i can resolve this?
Sounds like it was the main fan motor - that caused the lights to blow in the first place.
Isolate from supply, and get the fan motor checked out. If it is burnt out (inside) you will need a replacement.
Hope this helps.
Jun 05, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
Light doesn't work on Kenmore Model 55022 Range hood...
If you have 120VAC on the center contact of the light socket, and a working fan, but the bulb won't light...the most likely cause would be a disconnected neutral wire (white) in the light wiring inside the hood....assuming everything else is wired correctly.
If you're comfortable with further electrical testing...let me know, and I can describe a detailed procedure to check the status of the neutral wire. Otherwise, you may need the assistance of someone familiar with electrical troubleshooting or appliance repair.
Jan 27, 2008 | Kenmore 51840 Kitchen Hood
Light socket is dead on my Maytag
Yes, this is caused by not disconnecting the microwave from the power line when removing or installing a bulb or by the filaments shorting when the bulb blows. This is a problem with the control panel assembly, which we repair nationwide for $39.95. If you or a friend decide to send it to us, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Apr 01, 2007 | Maytag MMV4205 Microwave Oven
Zephyr Napoli ZNA-M90S Stainless Steel Kitchen Hood Logo
166 people viewed this question
Top Zephyr Kitchen Ranges Experts
Treefrog15
Treefrog15
Dale Copeland
Dale Copeland
Len
Level 1 Expert
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
