Question about Dryers
My dyer is turning of after a few min the it is telling me thier is a wrinkle block and lint filter lighting up
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 40 Answers
Sounds like a restriction in the vent line or in the blower wheel and or blower wheel duct good luck
Posted on Apr 17, 2015
  • 7 Answers
SOURCE: Bosch WTL5400 Condensation Dryer
We continuously had a similar problem with signals forever coming on after just a few dryer loads. The problem was corrected when we took the back off of the dryer and cleaned the recirculating fan and removed a rubber glove that somehow came through the system and blocked the air flow at the heating element. Low air flow is the same as plugged filter and apparently the computer in our German-made Bosch dryer simply says that. We cleaned the area well, removed all traces of the glove and restored the dryer to operation. We have not had the filter problem since. We routinely clean the heater area at the back of the dryer to maintain our sanity. And we now dry our clothes. Bosch never responded to my query.
Posted on Oct 25, 2008
SOURCE: Lint Filter Light comes on and cycle is interupted
I just found that the filter itself was not allowing airflow- I tested by blowing through it with my mouth- no airflow. I cleaned it with a high pressure air hose and noticed that the flow is much better now. I cleaned it by hand several times, and washing in water (which may have made theproblem).
Posted on Sep 11, 2009
heatman101
  • 43501 Answers
SOURCE: I have a Bosch V20-Ul
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 13, 2010
rylee_smith
  • 8619 Answers
SOURCE: I have a bosch Nexxt
Hi
Thanks for using FixYa. If the lint is clean then it seems to be the issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Also, often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 24, 2010
richroth
  • 9472 Answers
SOURCE: dryer check filter light keeps blinking and dryer
There is a reminder light to "Check Lint Filter" near the lower right of the cycle knob. It will come on every time the power button is pushed. After cleaning the lint filter, if the "check lint screen" light does not go off, it is likely that the touch pad control will need replacement.
Posted on Jan 09, 2011
Trum turns but will heat dyer. Is there an internal lint filter?
bottom lower right remove panel drain if ok then lint filter inside top or lint in vent
Nov 13, 2014 | Splendide 2000S Vented Washer/Dryer
Quiet wash 1 doesn't drain
the pump could be siezed or blocked. burnt rubber smell from the drive belt. look under the machine and try to turn the pump pulley
Apr 17, 2014 | Whirlpool WED5600XW - 27", 7.4 Cu Ft, He...
Bosch dryer won't run
bad air flow switch,check wire diagram.
Mar 04, 2014 | Bosch Dryers
No lint on filter? Where is it all going? Checked exhaust vent bought a vacuum attachment and there is no lint. Twice and sometimes triple the drying time! Help!
Instructions
  1. Dryer Does Not Run
    • 1 Close the door firmly. The dryer will not operate if the door is not completely closed.
    • 2 Press the "Start" button firmly or push the knob in to start the dryer.
    • 3 Turn the dial past the "Off" position and away from "Wrinkle Prevent." The dryer will not start in the "Off" or "Wrinkle Prevent" position.
    Long Drying Times
    • 4 Remove the lint screen. Clean it and replace it.
    • 5 Check the temperature of the room. The dryer will not operate properly in temperatures below 45 degrees Fahrenheit.
    • 6 Inspect the area around the dryer. It requires at least 1-inch clearance on the front and sides of the dryer. A 5-inch clearance is needed on the back of the dryer. Move the dryer, if needed.
    • 7 Separate large loads and do not use an air dry cycle.
    Lint, Stains and Wrinkles
    • 8 Clean the lint screen before drying each load of clothes to prevent lint buildup on clothing.
    • 9 Add fabric softener sheets before starting a drying cycle. If the sheets are added after the load has partially dried, they can leave stains on the clothing.
    • 10 Dry small loads and remove clothing as soon as the drying cycle completes to prevent wrinkling.
    Dryer is Noisy
    • 11 Check the inside of the dryer for loose change, buttons or other items. Empty the pockets on clothing before drying.
    • 12 Separate items that are knotted together and restart the load. Knotted or balled up clothing will bounce and make the dryer vibrate.
    • 13 Level the dryer. Turn the leveling legs on the front of the dryer clockwise or counter-clockwise until the dryer is level. Turning the legs clockwise will lower the dryer. Turning the legs counter-clockwise will raise the dryer.
Jan 15, 2013 | Admiral Dryers
Dryer check filter light keeps blinking and dryer will not start cleaned lint filter and nothing happened display on control board blinks when dryer is turned on and that's about it can you assist dyer...
Jan 09, 2011 | LG DLE0442 Electric Dryer
Warning signal "linter filter" comes on and dryer
You don't have very much information here to give you a better diagnosis, like the model or the error code, but I'll take a shot at it. If you're thinking that the flashing list filter light is the error code you can relax. The lint filter light ALWAYS flashes at the end of a cycle or before you hit the start button to begin a cycle. This is just a reminder to check the filter.
If your dyer is displaying an E:01 code this indicates blockage in the venting system. Do the simple thing 1st. wash your lint filter with some dish soap and running water, lightly scrubbing it with your finger tips. After rinsing clean pat the filter dry and re install it in the dryer. While you have the filter out look down in the filter holder area and see if you have lint built up there. They make brushes for cleaning this area or you can use a vacuum cleaner attachment to reach in there and **** out the lint.
If you still have an E:01 error after doing all this you may need to have your house vent pipe cleaned. But before you do this check your vent hood where the dyer vent exhausts out of the house. If it's obstructed you found your problem
Nov 27, 2010 | Bosch Nexxt 500 Dryer
I have a Bosch V20-Ul dryer that is 2 years old. Suddenly stopped creating heat. The dryer drum turns but no matter which cyle I select, it spins for about 1 min, then stops, beeps and the wrinkle block...
heatman101
Aug 09, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Depending on how old this is or how much it is used depends how much lint has built up inside
the air flow tube. I have seen where you look inside where the lint screen is and beneath it with screen removed there is nothing but lint, in which case the dryer thinks the screen is clogged. You might have two screws on the inside of the drum that hold the screen holder in place. First remove the lint screen
and hold the little door that closes when you remove the screen, open the little door and look down inside it with a flash light, if you see a lot of lint, like I said you might be able to remove the holder
and clean this area out, also take a coat hanger and bend a little piece at the end and use this to get most of the lint out of this area and the tube that Leeds down from this area. If this can be done
and you get this area clean and it still happens, you might have to clean the entire area the tube
and the back tube,the tube leeding to the outside of the house and vent. Any questions please post back.
Mar 27, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Lint Filter
hi there,
i can understand your frustration. i have reviewed the information that i have from Bosch and they indicate that the lint filter indicator light should only come on as a reminder but should not shut off the dryer.
here is my recommendation and also a question:
the dryer is shutting off due to the fact that it's overheating. it's a safety precaution from the manufacturer and it's built in to prevent the lint collected in the lint filter, since it's highly flammable.
check the venting in the back or side, wherever it was installed.
the vent tube is often the cause for the dyer to stop functioning.
if that turns out to be okay, the dyer is equiped with a sensor on the heater. it is possible that it's opening due to the heat generated by the dryer that has nowhere to go.
does the display show any error messages?
can you tell me what they are?
thanks again
Sep 24, 2008 | Bosch Nexxt WTMC 6300 Electric Dryer
Lint filter wanring signal
I posted in late December on the lint alarm and what I discovered was a bit alarming. (no pun intended) Lint had been accumulating on and around the heating coils used to dry our clothes. Some of the lint was burnt and the remainder, amounting to a small handful, was caught up in other area's around the lint sensor. After carefully cleaning the heating coils (with a tooth brush) and removing the rest of the lint and successfully putting everything back together, we have not had a lint alarm issue since. (Touch wood). No need to replace the lint sensor or any other parts. It was not that hard to take apart the back and remove the heating coils to clean, but it requires the unit to be unplugged, careful attention to what came off and where it goes back on. After what I found, I will be cleaning the heater coils out once a year. Which then raises the question. Should a person have to do this? The obvious answer is no! But from time to time we buy things that are not what we would expect and do what we need to do to make it work. From what I can tell, lint is getting past the lint filter and ending up where it shouldn't be. Hope this helps any of you that are having the same issue.
Mar 04, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Dryers Logo
65 people viewed this question
Top Dryers Experts
