Question about Garden
As soon as I turn it on the power cuts off - Garden
Amp buzzes all the time
Make sure the ground plug is not cut off of power plug. Also, if the power switch moves in 2 directions, it is a ground reverse, meaning switch it the other way. If it doesn't, look for a ground reverse switch somewhere on the back.
Mar 05, 2013 | Music
Cricut expression 2 has no power, will not turn on
Any resolution to this issue? I like stone234 have narrowed it down to the cricut not getting power past the power board. I tested the two prongs that feed the red and black power for the main board and no voltage. Cricut Exp 2. Powered on as soon as I plugged it in. Plugged in usb to computer, I didnt have the software so i searched for it then started downloading it and noticed the screen on the unit was frozen. unplugged it and after plugging it back in it wouldn't power back on.
Nov 05, 2011 | Cricut Expression Cutting Machine
When making a u-turn in either direction seems like the power-steering cuts out
check the fluid level, check for slippage in the belt or a worn belt, if those 2 check out ok, your power steering pump is getting weak and will soon need replacement
Jul 09, 2011 | GMC Jimmy Cars & Trucks
GREETING HAPPY HOLIDAYS T.V, COMES ON THEN FEW SECONDS CUT OFF. PICTURE SHOW WHEN COMES ON & SPEAK. WHEN CUT OFF BLACK SCREEN & NO SPEAKING. WHAT'S THE PROBLEM JUST HAPPEN TODAY. TRULY
This is a power supply regulator problem. As soon as one of the resistors gets a full load, it trips the fault circuitry, shutting down the screen and preventing the screen from destroying itself.
It's either that, or there is a fuse that is almost burnt out, so that, when cold the contacts touch and it turns on, but as soon as it warms up, it turns off.
Dec 15, 2010 | Proview PS 909 (White) 19 in.CRT...
I was watching tv and it suddenly cut off; soon thereafter the red light near the power button began blinking and I cannot turn the tv back on
Power supply board is dead.Replaced the power supply board will get ur power back.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board.
Feb 15, 2010 | Panasonic Viera TH-50PX80U Plasma TV
I have a emachine, and it cuts off soon as you start it up, i replace the mother and it still does the same thing
if a computer cuts off as soon as you start it up it is some times the power supply. You may have added something to your computer that when it gets loaded it pulls just enough wattage that the power supply overloads. Let's say you have a 250 watt power supply...if you computer pulls 255 watts it will overload the power supply and shut itself off. Try getting a Power supply with more wattage output.
Jul 15, 2009 | Computers & Internet
Memorex 38 in.flatscreen keeps cutting off and on and none of the buttons work either. Help!
Power supply has a issue or two check and see if the power supply is putting out enought power to the unit this is the major cause of these TV's going out.
Rulds2008
May 02, 2009 | Televison & Video
Dryer cutting main power off after acouple of seconds
you need to ck the back off the dryer and open the small cover wher the elet cord is ateched . it may bo loose or need to replace the block.
Apr 14, 2008 | Dryers
your heating element is the most likely cause of this. will need replacing
Nov 18, 2007 | Hotpoint TDC32 Electric Dryer
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
