Question about Samsung Refrigerators
How to i clean food debris How do I remove debris that is stuck in the from section of the crisper drawers?
There is as area of the crisper drawers where two pieces of plastic overlap. small pieces of food are getting trapped between these two pieces.
  • David Thompson
    David Thompson Jul 31, 2015
    You CAN pry the 3-pc drawers apart - be careful, though, there is a fragile tab on the top. I broke one, but it's all clean now! (More comments under the answer below)
I contacted Samsung regarding this exact issue. Woe is me I cleaned my drawers and now have water in addition to food stuck in them. The solution is... Nothing. Yup, was told there is nothing you can do. There is no way to clean between those two pieces of factory connected pieces of plastic. We have to live with it. Guess what my next fridge will NOT be? Yeah...
Posted on Jul 13, 2015
  • 2 more comments
  • mary bourke
    mary bourke Jul 22, 2015
    I agree I will not support Samsung again - this is totally unhygienic. Not happy at all.
  • David Thompson
    I got the drawers apart by carefully prying the top tabs free, then slipping the bottom piece both up and down at the same time. When you look at it, it makes sense. Be more careful than I was - on one of the 3 drawers, I broke a plastic tab and had to glue it. I will silicone the crack at the bottom so no more food can get in it...
  • ginger1498 Nov 06, 2015
    Thanks for your info David. I have no choice but to attempt to pry the pieces apart, looking at trapped debris is not an option. It's very hard to believe that Samsung thinks this is an acceptable design.
  • Lize Francis
    Lize Francis Jul 12, 2016
    So I got exactly the same problem with my brand new samsung fridge. And do find it irritating.
    Reading about the water getting stuck I decided to use air via a small compressor and blow it out ( we live on a farm and these things are available) and then sealed the holes with clear silicon. The holes I think was made by the 'mold' in the factory and therefore totally useless / not needed. If this proofs other problems over a period of time I will let you know.
  • 66 Answers
SOURCE: the refrigerator section is freezing. the temp adjust is at 1
This could be the actuator is not closing the door that controls how much cold air from the freezer is ciculated into the fresh food section. It could be something broken or there could be ice biuldup on the door itself, not allowing the door to open or close.
Posted on Nov 12, 2008
22yooper
  • 828 Answers
SOURCE: Vegetable crisper drawer problem with food freezing
Absolutely lower the setting.
Posted on May 21, 2008
bluegreenash
  • 661 Answers
SOURCE: Fridge filling with water
There usually is a drain at the back of the fridge it's possible that this is clogged, This drain leads to an evaporation tray usually in the base of the fridge.
Posted on Oct 09, 2007
SOURCE: Vegetable and fruit crisper drawers freezing foods
I had the same problem. Apparently the problem is the main control board. According to the technician that came out to fix mine there is a design flaw and these boards are very sensitive and can blow a circuit or malfunction from the slightest power surge. What happens then is that the control board doesn't "tell" the fan to turn on and off at the right time so the fridge and freezer warm up too much before the fan kicks in and then it cools everything down but since the fan isn't running at the correct intervals and circulating the air all of the cold air settles to the bottom which causes the produce in the drawers to freeze while the top shelves get warmer. I had done a fair bit of research before calling GE and came to the conclusion that this was a common problem. So I pressed them and was able to get the fee for the part waived (before I made the service call appointment) which was around $150. The part now has a 5 year waranty which I find funny, because I'm not sure why it wouldn't have that upfront as my refridgerator is only 2 years old. Whatever!! Unfortunately, unless you have indepth knowledge of refridgerator repair there is no way around the service call and labor. Anyone buying a new model of refridgerator (any company) should consider an extended waranty. The service tech also told me that all refridgerators made after 2001 are required, by law, to have an electronic mother board which in all likelyhood will fail at somepoint prior to when you are ready to buy a new fridge!
Good Lucak!
Posted on Feb 11, 2009
57 varieties
  • 1653 Answers
SOURCE: I have an Electrolux side
On our side by side we had to lift the shelf up or out to be able to remove the drawers. They are very fiddly and some patience is required.
Posted on Nov 08, 2009
I have a Kenmore Fridge Model 596-729-12200
fb4dfaa6-7995-4ceb-a384-cb74f4ab1f6a.jpgThe fresh food section has a 67003410 Damper that has a thermostat probe that senses the fresh food section temperatures and then regulates the fresh food section cold air from freezer by opening and closing to maintain a set temperature. If defective the damper may remain closed or remain closed. You can test the damper by removing and placing the temperature probe into a glass filled with ice and no water. The damper should close in the ice and open when not in the ice. I will be here to answer any questions you have, Thanks Sea Breeze
May 02, 2013 | Refrigerators
Food in crisper drawers freezing
HI. UMMM I WOULD DEFROST ALL FIRST.24/48 HOURS.AND TRY.MIGHT BE PARTIALY BLOCKED WITH ICE IMPAIRING CIRCULATION.GOOD LUCK.ALI
Jul 05, 2012 | GE (GTS16BBS) Top Freezer Refrigerator
Refrigerator section freezes food with temperature setting on highest (46F)
Does the compressor ever switch off? If not suspect stuck relay on pcb. May be probe, may be as simple as blocked up condenser.
Apr 26, 2012 | Refrigerators
Water under crisper drawers
I am pretty sure you are having a defrost drain blockage problem. Most refrigerators defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section (depending on the style refrigerator you have).Click Here=> Leaking Refrigerators Just What may Be Happening
Much more on this page=> Leaking Refrigerators!
I willbe here should you have questions, Thank You,
Sea Breeze
Feb 08, 2012 | Maytag Refrigerators
I need to replace the door seal. I cannot find a model # to confirm this is the correct one that I selected. I will be looking for the seal and instructions on replacing it.
The model number can be in 4 places need it to order correct part,it could be on; ceiling of fresh food section,left side wall of fresh food section,under grill below doors,under crisper drawer
Aug 02, 2011 | Estate TT21AKXKQ / TT21AKXKT Top Freezer...
Water is getting into the refrigerator. there is
If the fridge has the freezer on top - the problem is in clogged drain under the evaporator.Whenever the defrost cycle is activated (every 6-12 hours), the water will drain not to the drain pan underneath the fridge, but into the air vents between the sections. Depending on the make/model to get to the drain line you may need either:
  • to remove the back cover in the freezer section;
  • remove the bottom of the freezer section;
  • remove the console with controls on the ceiling of the fresh food section
  • get behind the fridge, find the drain line going to the pan under the fridge remove the drain line and clean.
Good luck.
Vlad
First Choice Appliance
Mar 13, 2010 | Refrigerators
Salad in drawer is freezing
Good day,
One user claims that the return air vents or vent located at the bottom rear of the fresh food compartment, have collected enough junk to block the cold air from returning to the freezer compartment. You can clean them out but I cannot verify that solution.
The crispers are located in the coldest part of the fresh food compartment.
This problem can occur when the machine gets light usage especially in colder weather, when the machine running time drops and the air in the fresh food stratifies, causing to cold air to pool in the bottom.
Normal may no longer be normal. Controls by their design will tend to run colder as they age. You might try tweaking the control warmer.
Patience and time are the most important tool you have to work with in dealing with this issue.
Dec 04, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
GE with top freezer has water accumulating in bottom of frig under the crisper drawers.
Remove the food from the freezer , then remove the icemaker , if it has one ( 2 screws ) . Remove the rear freezer panel . Useing a hair dryer , start in the middle of the drain trough , and defrost until you see the drain hole . Keep defrosting the hole ( hot water helps ) until water will go thru . Use a piece of tubing inserted into the hole , and blow thru , to remove any debris accumulated in drain line .Remove any excess ice from trough . Reassemble freezer .
Aug 27, 2009 | GE Refrigerators
Water dispenser not working ice maker is fine
The refrigerator has a dual water valve. The water dispenser side of the valve may be defective, but, my experience has shown the problem to be in the water reservoir, located in the bottom of the fresh food section, which, might be frozen or the water line through the freezer door is frozen. Scenario #1: Remove the kick panel, disconnect the water line from the fitting. Have someone depress the water actuator, while, holding a cup to collect any water which may come through the line. If water comes through the tube. The problem is a frozen water line in the door. My best advice for this problem is to remove any frozen goods from the door. Take a piece of cardboard and seal the freezer section of the refrigerator with any kind of tape. Make sure you tape the door switch in the closed position, so, the refrigerator will continue it's normal operation. The frozen goods will remain frozen and the fresh food section will be okay. Leave the freezer door open. You might want to put a towel under the door. The water line will thaw. It might take 15 minutes. It might take 3 hours. Periodically check the water dispenser operation. When the water flows remove the cardboard. Scenario # 2:if, after disconnecting the water line and depressing the water actuator there is not water. The reservoir is frozen. Use a hair dryer to that the reservoir. You will have to remove at least a couple of crisper drawers to perform this action. The cause of a reservoir freeze is too little stuff in the drawers or too low a temp in the crisper drawer area.
Jun 17, 2009 | Refrigerators
Refrigerators Logo
1,058 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
