Question about Smartphones Technologies Android Apps
What is the best smartphone within 300-350 dollar?
Phone won't charge
Test charger on another device. It may need replaced
Mar 04, 2015 | Cell Phones
My Frigidare refrigerator is freezing on both sides.
Hello friend, thanks for your post!
I understand that your Frigidaire refrigerator has been freezing on both sides. I would recommend turning down the temperature within your refrigerator. If you are developing frost it could be a leak within your air gasket and that could be causing frost to build-up.
I would test the gasket to verify it is the issue the best way to test this would be to place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then replace the gasket. I hope this information is helpful. -Matt
Oct 17, 2014 | Frigidaire Refrigerators
Ice maker chute not sealing. Ice and frost is building up around the ice maker and the chute door in the freezer door.
Thank you for your post, friend!
It sounds like there could be a possible air leak within your Frigidaire refrigerator. I would check the gasket that goes around your refrigerator. The best way to test this would be to place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then replace the gasket.
If the seal checks out to be fine it could be a possible problem with your dispenser or leak within your icemaker. I would recommend having a professional come out to properly diagnosis your appliance. I hope this information is helpful. -Matt
Oct 06, 2014 | Frigidaire Refrigerators
98 sunfire low beam will not stay on unless i manually hold it in place how do i fix?
sounds like it is broke within the steering wheel..
replace as needed.
Best regards
Ck
Mar 07, 2011 | 1998 Pontiac Sunfire
I have my Emerson FR966T wine coller set for 60 degrees, but my cooler never seems to get the high. It always hovers around 58-59. When I heat my house up (never above 68) my cooler seems to warm up to...
Yes, because the fridge is a heat exchanger. The trade off for cooling the inside is a condenser coil on the outside which is warm. If you raise the temperature on the outside it will affect the inside a little. Having said that, the thermostat should keep the temperature within specifications. If you have it set for 60 and it is 58 or 59, to me it is within spec.The difference in 2 or 3 degrees Fahrenheit is tiny.
Also it should be pointed out this is a $63 cooler from Walmart. If you want a good one for storing thousand dollar bottles of Chateau Margeaux, you need a $600 wine cooler with a solid state digital thermostat and controls that talks to your smartphone when the temperature is one degree off..
Oct 21, 2017 | Refrigerators
PICTURE IS BOWING INWARD AND THE COLOR . LIKE PERSON FACE IT WILL HAVE A SHADOW OF RED, BLUE, GREEN, YELLOW
Tv have a problems known as a convergence problems,it dead.Colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts are dead,must be replaced on the tv convergence board to repair the convergence problems.The shop,will cost u $300,350 for parts and labors.
Sep 14, 2010 | RCA HD52W58 52" TV
My touch screen is not responding to unlock the device
Possible fault within the display unit interrface to the main board.
The best is to try to remove any traces of moisture on the board , then reset to try . if not the panel is faulty
Sep 14, 2010 | Dopod 818 Pro Smartphone
Stops running during cycle
Replace the timer and all will work ok. The timer is stuck for some reason, you may be able to clean it out if there is any debris but you are best off just replacing it. 25 dollar or so part
Feb 09, 2009 | Dryers
Android Apps Logo
504 people viewed this question
Top Smartphones Technologies Apps Experts
Brett Duxbury
Brett Duxbury
Are you a Smartphones Technologies App Expert? Answer questions, earn points and help others
