Question about Tablets & eReaders
Has no sound? - Tablets & eReaders
Low sound can hardly hear it even tho the sound is turned high
Sometimes the app you're using has it's own sound control that overrides the device sound setting. Look in the app for sound settings, eg audiobooks apps often have a separate setting for volume and this is the one that you need to adjust.
Jan 01, 2015 | Tablets & eReaders
How do I get the sound on my ipad apple 16gb
Go into settings: notification center : check your apps to make sure the sound is on for that app.
Sep 15, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Nextbook has no sound
hi there.
see if this link helps you out.
Nextbook has no sound Google Search
Nov 19, 2017 | Tablets & eReaders
How To Unmute Sound
tablet setting icon gear shape has sound display option from ringtones to touch sound.And volumes,increase bar section on volume to maximum to enable sound in case it was disable.
May 09, 2013 | Acer Iconia Tab A200-10g16u XE.H8QPN.001...
Unable to turn on the sound on my Asus tablet T300. What do I do ?
The sound icon with a slash means the mute is turned on. Tap on the icon to see is there is sound otherwise you have to go into settings and manually turn on the sound.
Jun 12, 2012 | Tablets & eReaders
Android 7" sound problem, no sound comes out of my
have you checked for sound mute? Settings/sounds/silent mode to see if its unchecked? if its still silent, then root software is or could be missing or deleted or last of all a hardware issue.
Oct 11, 2011 | Archos 28 Internet Tablet
I HAVE A SOTEC BRANDED PC.IT HAS SOME ISSUE IN ITS SOUND.MY PC HAS NO SOUND.WHILE ALL THE SOUND DRIVERS ARE INSTALLED AUTOMATICALLY.MY OS IS XP SP2.WHEN I CLICK VOLUME CONTROL IT SAYS: "THERE ARE NO ACTIVE...
there may be 2 problem.1/ you could not stall required sound driver 2/ your computer sound card is damage. i think your instaling process is correct. you came to know problem changining sound card.
Jun 08, 2009 | Tablets & eReaders
845motherboard
1.check that ether sound is not muted
Mar 04, 2008 | Tablets & eReaders
How To fix sound for Toshiba Satellite.
Sound issue can be related to driver, sound settings or hardware itself. If you tell me more about the issue an I will give you step by step solution.
Check if device manager shows the Sound device? When you play a media file does it indicates any error message? Have you unmuted all the channels?
I will look forward your follow post
Jan 10, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Toshiba satellite pro l20 sound
my l20 cant play any sound can i download sound through this site
Dec 02, 2007 | Toshiba Satellite R10-S802TD Tablet PC
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
