Question about Miscellaneous
I got a 1987 Yamaha warrior 350. I was ridding and it lost spark some one help plz
  • 4,536 Answers
U think its spark..mite b fuel....inspect wiring and whole ign area..is batt good..must b 12.6v at all time. Buy a clymer manual for total maintenanc
Posted on Apr 13, 2015
fastboyz
  • 674 Answers
SOURCE: QUAD QUESTION! 1998 yamaha warrior 350 bogging down
sounds like fuel starvation
do you have a petcock plugging or a dirty carb?
pull the fuel line and check flow
Posted on Nov 17, 2008
bennito10
  • 51 Answers
SOURCE: 2001 yamaha warrior valve adjustment
hello
with the cylinder set at top dead center compression. using a feeler gauge between the tappets and the valves there should be .002-.003in clearance on the intake valves, and .006-.007in. clearance on the exhaust valves. thank you.
Posted on Mar 24, 2009
  • 89 Answers
SOURCE: How do I adjust the valves on my 2003 Yamaha Warrior YFM 350X?
first you need to remove everything that covers your valve covers(gas tank etc.) remove the intake valve cover,and the rotor nut and timing plug.set the engine a t.d.c.(top dead center)fit a socket onto the rotor nut and turn it counterclockwise until the"I" mark appears align it with the index mark in the timing hole.use a flat feeler gauge between the top of the valve and the adjuster.loosen the locknut and turn the adjuster just until you feel resistance on the feeler guage.hold the adjuster and tighten the lock nut down.i can not tell you the min.clearance spec to your quad since i have a 660 raptor.try using the smallest clearance number.
Posted on Apr 25, 2009
SOURCE: my yamaha warrior 350 has gas and spark but wont start.
check your timing as described if it checks out ok. you might want to check the intake valves and exhaust valves. intake 4 and exhaust 6
could have a bent valve.
Posted on May 06, 2009
SOURCE: yamaha warrior won't start
a yamaha warrior isnt a 2 stroke. they make a street bike nad a four stroke quad. Check your carburator. check your spark plug and check your stator. it may be very minor considering it was running fine then just went out. no noise or anything. you would have heard something if you broke something internal.
Posted on May 21, 2009
Have an 1987 Yamaha moto 4 350 has spark with key off and no spark when key is on
Sounds like you have a bad igntion switch or other electrical gremlin somewhere. If this is something you bought like this, then I would get a service manual with a wiring diagram and ensure the wires on the key switch are in the right positions.
Aug 21, 2016 | Yamaha 2004 Warrior Base
How do I test the stator coil on a yamaha warrior 350 electric start
hi .. go straight to here .. youtube link. http://www.youtube.com/results?search_query=yamaha+350+warrior+stator+test
yamaha 350 warrior stator test YouTube
Jul 20, 2014 | Motorcycles
No spark on 350 warrior
Go to the on/off switch and see if it's shorting out. Also check the ignition.
Jan 13, 2014 | Yamaha Genuine Yfm 350 Yfm 600 Yfm660...
Will a yamaha 350 warrior cdi work on a yamaha 350 motot 4 they look exatly the same
I would call the dealer and have them check the part numbers. If the part numbers match then yes you can. Alot of the time the only difference is the connector. Yamaha has alot of interchangeable parts but the safest way is to verify the part numbers. If you just " try it " and they don't match you just may have fried the cdi box and you'll be trying to troubleshoot a bad part that you think is bad.
Nov 15, 2013 | 2008 Yamaha YZF-R15
1992 Yamaha Warrior 350 sound when letting of throttle!??
Check spark plug, that sounds like it's running little too lean.
May 30, 2017 | Yamaha 2004 Warrior Base
Hi i have a 1997 yamaha 350 warrior i have no spark to the spark plug what could be
hello, you probably need to have your stator checked out, sometimes the pickup coil in the stator will go out, also you can try ign coil, the one spark plug wire is hooked to,warriors are bad about cdi going out, mine would idle, would not rev up, would bog down, source coil in stator probably needs to be checked also..
Feb 27, 2010 | 1974 Yamaha DT 360
98 YAMAHA WARRIOR 350 WONT START
have your carb. rebuilt and make sure there is not anything in the intake tube between the carb and the engine.
Jun 01, 2009 | 2002 Yamaha Road Star Warrior
I had a problem somewhat the same.
Make sure the air-intake boot has no holes in it.
Apr 18, 2009 | 2002 Yamaha Road Star Warrior
hello
Mar 23, 2009 | 2003 Yamaha YZ 250
Miscellaneous Logo
51 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
