Question about Bush Televison & Video
I've just installed my new bush 50" tv and now the remote as stopped working what can I do? I've tried new batteries
  • 86 Answers
SOURCE: My remote stopped working. Replaced batteries so
1) Reset the remote. To do this, remove the batteries and hold down one of the number buttons for about 5 seconds to drain the capacitors. Replace the batteries, reprogram the remote to your TV and see if it works.
2) If it doesn't, try a second set of replacement batteries just in case.
3) If none of the DirectTV codes work, you have 3 options.
1) Contact Directv and see if they have additional codes not listed in the manual.
2) Contact your televisions manufacturer and see if they have additional codes to try.
3) Purchase a 3rd party remote that works with both devices..
Posted on Jun 03, 2009
SOURCE: My remote does not work with my bush a632" tv. i
Hi there we had same problem so phoned 08456040105 and they told me to press menu button on tv for 10 secs and take batteries out of remote and press power button on remote for 10 secs while batteries are out. it worked for us doing both at same time....good luck
Posted on Feb 05, 2010
Testimonial: "Oh my goodness thank you so much for this advice. I was a bit sceptical but it worked wonderfully!!"
  • 8457 Answers
SOURCE: Our remotes suddenly stopped working.
Tries take the remotes aparts.Take some Q tips soak it with some rubbing alchahols.Clean the PCB circuits board and the rubbers films between them might help,could work after do the cleaning.Not,than sorry ur remotes CPU probally it shorted and dead.That why the remotes not functioning any more.
Posted on May 24, 2010
PhilwithDISH
  • 123 Answers
SOURCE: no remote will work with the tv - at the same time
We are sorry to hear that both remotes have stopped working, we would be happy to help get your DISH Network remote up and running. The first thing we want to check is if the issue isaffecting multiple buttons on the remote. If you are having the issue withspecific buttons then the remote needs to be replaced, give us a call at1-800-333-DISH (3474). Check if you are using the correct remote for thecorrect room, there may be a number on the bottom of the remote that tells youwhich room the remote should be in. If UHF, check that your UHF remote antennais securely connected to the remote antennaport on the back of your receiver and that the antenna is upright. Atthis point we want to re-address your remote, if issue is with the TV2 remote,bring your TV2 remote with you to TV1. Access "System Info" at TV1.Using the remote that is NOT functioning, press and release the "SAT" button then press andrelease the "Record" button onremote control. If the batteries in the remote have not been replaced in thepast 60 days, replace the batteries. Reset the receiver by unplugging it for 10seconds then plug it back in then re-address the remote again. If the remote isstill not working at this point then it may be an interference issue. If youare having issues with an infrared remote, find interference source(backlighting or power save mode on LCD TV's, fluorescent lighting in room, ordirect sunlight), eliminate, or convert remote to UHF. If you are having issueswith an UHF remote, find interference source (component (VCR, DVD Player, etc.)near DISH receiver), adjust UHF antenna, or distance UHF antenna from receiverusing coax cable/barrel connector. If the remote is still not working after allthese steps we need to have your remote replaced.
We really hope all these steps resolve your remote issue. Thank you for being avalued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Posted on Mar 02, 2011
SOURCE: I have a Grundig GU22DVD
The buttons on the grundig gu22dvdblk remote control unit don't work sometimes.
What can this be,as my Nan has bought an exact replacement control and is having the same problem??????
Posted on Apr 22, 2011
Do bush tv remote controls stop working even with new batteries
Sometimes, the buttons we push on the remote become worn out and need to be pushed extra hard, or a new remote may be needed.
Oct 20, 2014 | Televison & Video
Remote control for bush tv not working
REMOVE THE BATTERIES FROM YOUR REMOTE AND TRY USING THE CONTROLS ON THE TV
Jun 21, 2013 | Televison & Video
Tcl tv freez no sound/picture
are you using a cable box, tried to reset the box.
Oct 13, 2012 | TCL L32D20
My TV remote control has stopped working. I've tried changing the batteries but it still doesn't work. Any tips or do I have to get a new one?
Check for rusted battery contacts due to leaked batteries. Clean them with polish paper or blade. Due to leaked batteries it is quite likely that the wires connecting remote control pcb & battery contacts are cut off.
sonsunny
Jul 02, 2011 | Televison & Video
Remote stopped working so I cant use the tv what can I do I was trying to set the firect tv remote and could not get it to work. After I tried that the remote to the tv would not work anymore. I tried...
your best bet is going to be contacting rca and having them send you out a new remote alot of the universals have a 50/50 chance of having the needed frequency so I try to say away from them
hope this helped
Robb
Apr 22, 2010 | RCA RCU600M Remote Control
My remote does not work with my bush a632 tv. i tried changing the batteries adn using a different remote but it still doesnt work. The tv light flashes when pressing buttons on the remote but it doesnt...
Asker's Testimonial " Oh my goodness thank you so much for this advice. I was a bit sceptical but it worked wonderfully!! " - aurora393
Feb 06, 2010 | Televison & Video
Remote does not work
Remote stopped working - I bought a universal remote Phillips / Magnavox used a code in the 400 range and everything worked. Hope this helps.
Aug 08, 2008 | Zenith IQB50M90W 50" Rear Projection...
Help pleaz
1- make sure that the batteries are new and installed the right way (follow the diagram under the batteries).
2- if you threw out your manual download a copy at www.retrieve.com
Mar 15, 2008 | Philips Magnavox 20MC4304 20 in....
Televison & Video Logo
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
