Question about SharpVision XV-Z10000U Multimedia Projector
How to change fuse - SharpVision XV-Z10000U Multimedia Projector
    Top Expert:
  • Sharp Master
  • 1,144 Answers
See Service Manual, fuses F7001 (6,3A), F7002 (1,6A), bimetal switch (page 17 - power unit, page 33 - Checking the power unit, page 126 - gray areas of the wiring diagram, fuses F7001, F7002):
http://diagramas.diagramasde.com/otros/XVZ10000.pdf
Posted on Apr 13, 2015
I wanna know how to change a fuse for a saturn aura 2007.
What fuse ? Regular mini fuse ? Just pull it out with the fuse puller tool located in the fuse box compartment . Replace with same number fuse . 5,10 , 20 , 25 etc.. what ever it is . How To Safely Change Blown Fuse
Feb 02, 2017 | Saturn Cars & Trucks
How do I change the fuses?
Remove the fuse box cover remove old place new fuse of same size. Step by Step:
  1. Locate your car's fuse panel.
  2. Take off the fuse panel's cover.
  3. Locate the blown fuse.
  4. Remove the broken fuse.
  5. Insert a replacement fuse of the correct amperage-make note of the fuse panel and your owner's manual on this one.
  6. You do keep a few extra fuses of various amperage in your glove box.
How to Find and Replace Blown Fuse in Your Car or Truck
Changing Fuse DMV org
How to Change Vehicle Fuses
How to Change Car Fuse in 8 Easy Steps
May 30, 2016 | Cars & Trucks
How to change a fuse panel cadillac 2001
    images for How to change a fuse panel cadillac 2001
    More images for How to change a fuse panel cadillac 2001
    Cadillac Crisis DIY: Checking Fuses - YouTube
    ? 6:25
    https://www.youtube.com/watch?v=xwJodTmj7Jo
    Apr 8, 2009 - Uploaded by bountyCXVII
    Just a simple video about how to check, and replace possibly burn out fuses. also it shows where both fuse ...
    How to Find and Replace A Blown Fuse in Your Car or ...
    ? 3:32
    https://www.youtube.com/watch?v=faWZmG0fXy8
    Jul 1, 2011 - Uploaded by 1A Auto Parts
    How to Find and Replace A Blown Fuse in Your Car or Truck ...How To Wire A Fuse Block - Easy - Duration: 10:56. klowny1969 9,283 views.
    Cadillac DeVille Questions - do i have any fuse boxes under ...
    www.cargurus.com > Questions > Cadillac > DeVille
    CarGurusMar 3, 2013 - That's where you will find your rear fuse block. ... The fuse panel is accessible by removing the shroud cover. ... 2001 Cadillac DeVille Base.
    How to change fuse on 68 cadillac - CarGurus
Jan 14, 2016 | Cadillac Cars & Trucks
Fuse is out for step and radio
How to Change a Vehicle's Fuses - For Dummies
www.dummies.com/how-to/.../how-to-change-a-vehicles-fuses.html
A fuse box located under the hood. ... A fuse box is easy to recognize, and replacing burned-out fuses is a fairly simple matter. ... Before you open or work on a fuse box, be sure that your vehicle's ignition is turned off.
Changing a Fuse ' DMV.org
www.dmv.org/how-to-guides/fuse.php
The Unofficial Guide to the DMVDon't stress out, it's a pretty easy procedure. ... Step-by-Step: How to Change a Fuse... Replace the blown fuse with a new fuse of the same amperage. ... Consider using the fuse for your cigarette lighter, the radio, or the back window heater.
How to Check Fuses (with Pictures) - wikiHow
Dec 01, 2015 | Cars & Trucks
Konica Minolta 215 error C0F501 solution
Fusing Pressure Roller warm-up failure
• The voltage of the Fusing Pressure Roller Thermistor does not increase by five steps within 20 sec. after the predrive of the Fusing Roller has been started during a warm-up cycle. Remedy 1 Check the Fusing Unit for correct installation (whether it is secured in position). 2 Check the Fusing Unit, PWB-MC and PU1 for proper connection and correct or change as necessary. 3 Change Fusing Unit. 4 Change PWB-MC. 5 Change PU1.
Jul 19, 2015 | Konica Minolta Office Equipment & Supplies
Where is fuse to change on tcl tv
Locate the power regualtor board. The fuse must be there.
Apr 20, 2012 | Samsung LE40M91B 40 in. LCD TV
Minolta dialta 183 help me... theres a code in the screen CO5 .. and automatically turn off.
C0500: Warm-up failure
Step 1
Check:
Fusing Heater Lamp (H1) turns
ON.
Step 2
Check:
Fusing Heater Lamp (H1) is open-circuited.
<Check Procedure>
Check the resistance across both
ends of the Fusing Heater Lamp
(H1).
The Fusing Heater Lamp is open-circuited
if the resistance is infinity.
Result: YES
Action: Change Fusing Heater Lamp (H1).
Step 3
Check: Thermoswitch 1 (TS1) is operational.
<Check Procedure>
ends of the Thermoswitch 1 (TS1).
The Thermoswitch 1 is open-circuited
Result: NO
Action: Change Thermoswitch 1 (TS1).
Step 4
Check: Fusing Unit Interlock Switch (S2) is
operational.
<Check Procedure>
Check continuity across terminals
when the Fusing Unit Interlock
Switch (S2) is turned ON.
• Across S2-1A and S2-1B
• Across S2-2A and S2-2B
Result: NO
Action: Change Fusing Unit Interlock
Switch (S2).
Result : YES
Action: Change DC Power Supply (PU1).
Step 5
Check: Thermistor (TH1) is open-circuited.
<Check Procedure>
Check the resistance across CN15-2
and CN15-3 on the Fusing Unit side
with CN15 disconnected.
The Thermistor is open-circuited if
Result: YES
Action: Change Thermistor (TH1).
Step 6
Check: The following voltages are supplied
from the Master Board (copier: PWBA).
<Check Procedure>
Check voltage across a Master Board
(copier: PWB-A) pin and GND when
the Power Switch is turned ON.
• Voltage across PJ10A-7 and GND
DC24 V when Fusing Heater Lamp
(H1) is OFF
DC0 V when Fusing Heater Lamp
(H1) is ON
• Voltage across PJ10A-10 and
GND
(H1) is OFF
(H1) is ON
Result: NO
Action: Change Master Board (copier:
PWB-A).
Oct 05, 2011 | Minolta DiALTA Di183 Copier
C-3721 error is displaying. How can I fix it?
Fusing abnormally high temperature detection (heating side)
Check the fusing unit for correct installation
Check the fusing unit, PRCB and DCPU for proper connection and correct or change as necessary.
Change fusing unit
Change PRCB
Change DCPU
Jun 28, 2011 | Konica Minolta Bizhub c203 Copier
SharpVision XV-Z10000U Multimedia Projector Logo
154 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
