Question about Maytag Washing Machines
Maytag washer 9501EWW leaking only when agitating
Washer only leaks from bottom when agitating
    Genius:
  • Maytag Master
  • 1,585 Answers
Check pump
Posted on Apr 13, 2015
  • Maytag Master
  • 2,992 Answers
Could be shaft seal at the agitator top or there is a seal at the bottom that may leak from the agitation vibration. There are several online appliance parts sites that will help with diagnosis and repair parts.
My Maytag A9700 is leaking from the bottom of the outer tub. I have changed both the tub bearing and the stem seal but it is still leaking - even more than before I started. My question is whether I
If the boot seal was properly seated onto the outer tub lip, then you should focus on the water seal (#39 in the graphic - it should have come with the mounting stem kit) as the source of the leak. Extra care must be used when installing this over the agitator drive shaft - some recommend adding a lubricant (Maytag center seal grease works well) to the shaft before sliding the mounting stem (and water seal) down onto the agitator shaft. Also, check the two sealing surfaces where the top of the boot seal (#40) meets the bottom of the mounting stem (#30). Look for cracks, chips or any bits of debris. Anything that keeps those two surfaces from meeting perfectly will cause a leak. These repairs should go fairly smoothly, but leaking water seals and chipped boot seals can cause problems.
Dec 06, 2014 | Maytag Washing Machines
Washer slinging grease from bottom of tub onto sidewalls of washer. Also beginning to leak water while it is agitating and spinning. Do I need Tub Bearing kit?
You need the outer tub seal as a minimum for the water leak. The grease is a different mater, it could come for several places by the most likely in the transmission, not the bearings.
Jun 29, 2011 | Maytag Washing Machines
Washer leaks after it starts to agitate. It seems to be coming from the front of the washer. Thanks for any help.
To find where the leak is coming from, remove the 2 bottom bolts on the lower kick panel and remove panel. Next, remove the 2 bolts holding the upper front panel and remove it also. Now, with the front panels removed, run the washer and look for where it is leaking from. Repost your observations.
Feb 11, 2011 | Maytag SAV365ZAWW 3.3 cu.ft.
Maytag Washer noisy & leaks lots of water from bottom of machine
the drum bearing are damaged due to water leak from seal inside the drum. that's why water on the floor. silicone paste mo use as it has other major problem.
Nov 02, 2009 | Maytag Washing Machines
Mold and smell from Maytag washer
The mold will be growing in the upper parts of the agitator basket above the water line. Spray these areas with a bleach/water mixture using a spray bottle. Turn off the hot water valve to your washer. Disconnect the hose connected to this valve. Connect a leak free garden hose to the valve. Connect a garden sprayer to the other end of the garden hose. Turn the hot water valve back on. Check for leaks. Use the garden sprayer to rinse and remove the mold. Be careful to keep all of the water in the agitator basket. Turn off the hot water valve. Reconnect the hose from the washer to this valve. Turn the hot water valve back on. Check for leaks. Run a wash cycle with an empty load.
Jan 15, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer leaking water on floor
Need to check drain pump and its hose connections. If its not from the drum seal then that's usually where the leaks occur.
Mar 30, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washer leaking water from bottom
Probably a main tub seal, big job!
Nov 16, 2007 | Maytag MAV7600 Top Load Washer
Washing Machines Logo
80 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
