Question about Measuring Tools & Sensors
Need clearance for valves for briggs and Stratton engine 121602 0175 p1
  • 3,519 Answers
Hi Edward:
Here's a site that looks like it should have the exact info that you need, Depending on how old the motor is that you are working with, you may need to "wing it". Back when I was a kid 60 years ago, we would set them at 8 and 10 thou respectively for intake and exhaust. If they "clicked" then we'd tighten then up 1/4 turn at a time. Definitely not scientific, but fun to do, and they worked fine.
Posted on Apr 13, 2015
Valve clearance Briggs model# 331877 1371b1
Danny, I set lash at .004" / intake and exhaust clearance. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www4.briggsandstratton.com/miscpdfs/RNT/Engine%20Specifications%20Chart_ms3992.pdf
briggs and stratton 21HP backfires like cannon
YTS3000 Craftsman model 917 289213 valve gap setting 331877 1371 B1 Briggs...
Lawn Mower Repair Valve Adjustment
Jul 08, 2016 | Garden
Valve adj. B&S gen. Model 030246 10 hp. OHV
Briggs and Stratton Valve Clearances
outdoorpowerinfo.com/engine_specs/briggs_valve_gaps.asp
Briggs & Stratton Intake and Exhaust Valve Clearances. Model Series, Engine Type, Intake Valve Clearance ( in. ) Exhaust Valve Clearance ( in. ).
Briggs and Stratton 10hp Generator Carburetor Repair ...
? 6:17
https://www.youtube.com/watch?v=O-fROtibEvE
Jun 5, 2010 - Uploaded by IFIXIT4U
In this video I will show you how to clean the carb on a Briggs10hp. This is a Nikki carb.
Nov 03, 2015 | Measuring Tools & Sensors
How tocheck timing onbriggs stratton model44577
The timing is fixed, if you suspect the timing is off the only adjustments available are the .030 clearance from pickup to flywheel and the shear Key that positions the flywheel on the crankshaft. You would also want to make sure your valve clearance is .030 as well, the issue sounds like a valve leaking, a dead cylinder or mal adjusted valve clearance causing the exhaust valve to hang open just a bit.
May 13, 2014 | Briggs & Stratton Briggs Stratton Intek V...
How do I adjust the valves on a Briggs and Stratton Intek V Twin
Remove the valve covers look up your valve clearance specs turn the engine by hand until the piston is at top dead center then go 1/4 turn past that and then put a feeler gage for the valve clearance you need for that valve and snug up the adjustment nut. Check your oil when your done some oil will spill out when opening the valve cover.
Apr 17, 2013 | Briggs & Stratton Briggs Stratton Intek V...
Need valve clearance for 24 ohv engine,4457770168e1
You should be able to get the settings from the Briggs & Stratton Website
Aug 24, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I need to adjust rocker arm clearance on a 15.5 briggs engine
you go to the briggs & stratton website, already knowing the numbers from the side of the engine, you look the clearances up under support.
you go to you tube and search, i am sure there will be some videos on there for adjusting rocker arm clearance. one short movie is worth a thousand words. the key is to understand the timing. where the piston is in relationship to where the valve should be. once you have them adjusted, make sure you turn the engine over a few times without the plugs in, and then do it again.
Apr 04, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Have a 20hp vanguard on a go-devil long tail motor. engin runs at idle speed then when i put the propeller into the water it stalls. if i pull the choke and give full throttle it will run some and backfire
These engines seem to have problems maintaining the correct valve lash settings. try taking the valve covers off and checking the valve/pushrod clearance.on tdc compression stroke it should be .001-.003 clearance. then check exhaust stroke tdc on exhaust stroke. clearance should be same on the other valve then. hope this cures your problem.
Dec 22, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Measuring Tools & Sensors Logo
284 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
