Question about Beko Washing Machines
Beko C510wm12 washing machine stopped working changed Fuse an still nothing any help would be nice
    Genius:
  • Beko Master
  • 1,585 Answers
Check door inter lock
Posted on Apr 13, 2015
barkencoa
  • 3463 Answers
SOURCE: how to change brushes on beko washing machine
remove rear cover of washer, locate and remove belt.
Unfasten motor ,disconnet motor lead, and remove motor.
Brushes are located at opp end to motor pulley.
Replace if less than 5mm long.
Plz rate my solution.
Thanks
Posted on Jan 21, 2009
  • 44 Answers
SOURCE: beko wma641w reset
hi
to reset these al you do is press and hold the start button for about 5 seconds then it should reset if not then you have a faulty pcb
regards
Posted on Mar 22, 2009
  • 42 Answers
SOURCE: changing the brushes on a beko washing machine
Its been a while since I changed beko but here goes.......... Put the machine on its side (soapbox side down, This prevents excess water from the soapbox dribbling into the PCB and creating a further problem). There is an opening at the bottom of the machine in which you will see the motor. On each side of the motor will be the brushes each with a connecting spay-tag, gently take of the spay tag with long nose pliers (not grabbing the wire) and change the brush. VERY IMPORTANT.....each brush is angled and it is important you replace the correct brush eg. left hand brush to left hand etc. or else when you goto wash the next time you will simply hear a bang and have to price a new motor. I highly recommend when you take each brush off do it slowly noting its angle and replace the new one at the same angle. Wfen done replace the spay tag. I am presuming you know to do this when the machine is fully powered off and plugged out. Happy Fixing.
Posted on May 07, 2009
SOURCE: MY BEKO WASHING MACHINE IS STUCK ON WASH/SPIN/END
bottom left as you face the washer, let down the panel and unscrew the stopper inside, you can use your fingers, remove whatever is in there its usually loose change and your washer will be fine.
Posted on Aug 19, 2009
  • 6277 Answers
SOURCE: my beko washing machine has
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
(If these actions have not cured the problem, it could be the control board OR the main motor. Motors will show weaknesses when commanded to spin.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 12, 2011
Beko washing machine seems to go straight into a spin cycle,bangs around too.I did the test program, it didn't turn clockwise gently or anticlockwise gently it just spun really fast then blew the fuse
Hello!
It sounds like the triac, which drives the motor is in short, you can recognize from the heatsink, on Beko usually is riveted, not fixed with screw, but you can drill'em off, its an BTB12 ( or 16 ) Triac, replace, thermal grease under and back.
Rarely this problem could be caused by tacho circuit error, but ususally Beko just stops and do nothing when tacho error
Aug 31, 2016 | Beko Washing Machines
Forty cycle takes some water in then stops
Beko WM5100W Washing machine wash/spin problem ...
? 3:59
https://www.youtube.com/watch?v=rih6H1cpu9Q
Jun 12, 2012 - Uploaded by ilona ilona
problem in washing cycle. fast spin for few seconds and cut off .... I have same machine, it starts up fills half way with water then stops :'.
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jan 10, 2016 | Beko Wm & Wma Models Washing Machine Motor...
Why dosen't Beko WMB 61631s washing machine work?
sounds like a software problem.
Try unplugging for 2 hours, then replugging and starting the cycle.
The long unplug is to drain memory voltage.
Aug 19, 2014 | Beko Washing Machines
My washing machine was switched off mid cycle. Now the start/pause, ready, wash & spin/end buttons are lit up. I have switched it on and off from the mains. No change. It is a beko wm6123w. Please help
Try looking in the troubleshooting section of the products user guide/instruction manual, if you have lost this, you can normally download a copy from the manufacturers (beko) website, this is normally located in the support section of the websites.
have you tried pressing the start/stop button as the cycle maybe simply paused.
WM6123 Washing Machines Beko
Jul 04, 2014 | Washing Machines
How to reset Beko wmb 91242 LC? Machine won't do
My washing machine beko WME7247W won't do anything it said C on it won't start change tem do anything can you help me
Apr 08, 2012 | Washing Machines
Beko WMA10 W Washing machine. Power light on but thats it.
sounds like the main bearing,it would be cheaper to puchace a new mc
Jan 05, 2010 | Washing Machines
Washer stop before completely filled with water.
beko washing machine when turn it on it trips
Dec 12, 2009 | Kenmore Washing Machines
Washing Machines Logo
47 people viewed this question
Top Beko Washing Machines Experts
Tom Chichester
J D Wright
 Russ Hill
Russ Hill
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
