Question about Beko Washing Machines
Wm6120 wont lock door have tried different door locks but still wont lock why??
    Genius:
  • Beko Master
  • 1,585 Answers
Check door strike also that power is going to inter lock
Posted on Apr 13, 2015
Testimonial: "yes we have power to interlock i even tryed locking it with screw driver but no joy"
Why is oven door locked and won't open?
Troubleshooting a GE Oven That Can Not Get Out of Locked ...
motherhood.modernmom.com > Around the House > Home Appliances
Self-cleaning GE ovens have a locking oven door as a safety feature. ... How to Troubleshoot a GE Artica Profile Refrigerator That Won't Get Cold ... Allow the oven to cool down if there is food inside the oven, and unlock the door once the ...
Oven won't open!!! [Archive] - Chronicle Forums
www.chronofhorse.com > ... > Off Topic
The Chronicle of the Horse
Dec 25, 2010 - 100+ posts - ‎100+ authors
Different ovens unlock at different times, some are by temp and some are ..... -cooktops/19645-ge-oven-door-wont-unlock-after-self-clean.html)
Dec 30, 2015 | GE Ovens
Kenmore smartwash quiet pak 9, wash machine door wont lock
the door latch on the machine is already locked in place
or there is electric circuit issue, the wire going to the lock broken, come loose,
you mite try, resetting the unit it it has reset switch.
or
try unplugging the unit for a while 30 minutes than plug back in try setting up a different wash cycle.
if all fail than call the customer service line ask for technical service.
Oct 04, 2015 | Kenmore Washing Machines
WHAT SHOULD I LOOK AT FIRST
You need to look at the door lock actuators, I'm guessing 1 is operating but staying on when locked and draining the battery. Try manually locking the doors and see what happens. It may come down to removing the door trims and disconnecting each lock in turn, don't forget the boot lock, until you find the culprit. Its possible you may hear the lock solenoid humming or buzzing or feels warm as its trying to lock the door unsuccessfully.
May 20, 2014 | BMW Z3 Cars & Trucks
Car alarm is in lock mode, car wont start, what can I do? Has power. How do I get it out of lock mode.
put key in drivers door, turn to lock then unlock and try to start again.
if that fails to work try a different key.
Sep 03, 2012 | 2002 Chrysler PT Cruiser
How do you program new spare key for 2007 rodeo RA?
if its the ignition key it must be done by a dealer and have a lage black plastic head which has got a transponder in it. If you got a blank key cut at the locksmith it will turn the locks but wont start the car. Usually you get the dealer to do both supply ignition key and then get it cut, then they can program it.
but if your asking how to program the keyless entry remote follow this procedure.
take note step 5 is different for different year models.
Make sure that all the doors are closed and unlocked and wait for dome light to go out before starting.
Insert the ignition key into the ignition switch
Open drivers door
3 on/lock
Close/open drivers door
Wait 8 secs
On/lock/on (MY06-07) OR 2 on/lock OR on/lock (MY08)
Close drivers door
Hazards flash
Press remote & keep pressing one button & then the other slowly(2 secs) until locks start working(they wont operate if key is in ignition).
Hazards flash
Feb 23, 2011 | Isuzu Rodeo Cars & Trucks
My 2005 ford focus has a red light that just came on. It looks like a lock and now it wont start. What is this?
This is the key security system. Somehow youv'e set it off. Used the wrong key tried to open the door with the alarm on. Opened the door or trunk from the inside after locking it from the outside. If your the real owner of the car it'll be no problem to get it fixed. If you have the correct key lock the doors from the outside with the key and lock it twice ( the doors ( all of them ) should lock). Leave the car alone for a minute, maybe 5. Then unlock the door twice, all the doors should unlock the second time. Enter the car and start it with the key. If you with a remote door lock fob that can work too. If this fails then try a different door or even the trunk. Sometimes the driver doorlock switch wears out or gets ice in it and unlocking a different door or useing the remote can get you going again.
Jan 25, 2011 | 2005 Ford Focus
My chevy silverodo's drivers door handle wont open and I usualy have 2 lock the truck from the outside
You mean it wont lock? or wont open? the inside door handle? or outside? Opening and locking are 2 different things.
May 14, 2010 | 1995 Chevrolet Silverado 2500
Error code F DL
https://secured.whirlpool.com/Service/...nsf/.../Duet%20Job%20Aid.pdf
I think Duets have a propensity to have door lock failures...Why removing the surge suppressor would make a difference I have no idea.
F/dL Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Door Lock Mechanism broken or removed from the Door
Check Door Lock/Switch Assembly
Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
http://elektrotanya.com/whirlpool_ghw9100l,9200l.pdf/download.html
service manual above/
Apr 10, 2010 | Whirlpool GHW9100L Front Load Washer
406 hdi pass door lock wont lock so car wont lock
Remove the door pannel and spray releasing oil over the central locking solinoid.That should sort it for you good luck.
Sep 02, 2009 | 2005 Peugeot 405
I have a 95 Toyota Celica, and my locks automatically lock and unlock when I turn my car on and off and take the key out of the ignition. But recently the passenger side door wont lock from the inside by...
You might want to take the door panel off and check the metal rods that connect on the inside of the door to make sure that one of the plastic inserts hasn't broken. If you find that it has broken there are several different ways to fix that. Some use black tape, some use an epoxy. I don't recommend the epoxy due the the fact that that metal rod turns inside the metal bracket that controls the lock.
Mar 03, 2009 | 1994 Toyota Celica
Washing Machines Logo
60 people viewed this question
Top Beko Washing Machines Experts
Tom Chichester
J D Wright
 Russ Hill
Russ Hill
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
