Question about Universal Office Equipment & Supplies
What can I do when shredder stopped working
UNV38162 - Was shredding and stopped - Tried again next day and still does nto work
SOURCE: shredder
Check for stuck paper and remove if any. Then check if motor is ok with a multimeter and also main switch.
Posted on May 21, 2007
SOURCE: My shredder stop shredding. has paper caught in it
Shredder drive gear is probably shredded - hard part to find or replace usually. Could mean a new shredder;-(
Posted on Sep 08, 2007
SOURCE: My shredder stopped working
This shredder is supposed to reset after 15 minutes.
Posted on Dec 10, 2007
fellowesrep
  • 102 Answers
SOURCE: shredder stopped working
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc1.gif board, contact manufacturer for more info.
Posted on Mar 02, 2008
SOURCE: staples spl-710sh paper shredder stopped shredding
This exact thing has happened to my unit as well. Ive disassembled it to discover that 5-7 teeth on the gear that the motor drives have been stripped off. Unless the gear can be replaced (which is probably not worth the expense), then the unit is toast. Sorry. Good luck.
Posted on Nov 01, 2009
My Black & Decker Shredder #BD-61 all of a sudden does not work. I used it tonight, but the next time I tried it does not work. The lights come on in both positions, but
On some shredders when both the forward and reverse LEDs are on it can indicate either a jam or a full receiver bag/ container (the area that the shredded paper is fed into).
Try the following steps:
  1. ) unplug the power
  2. ) open up the shredder (see 1 on diagram)
  3. ) empty out all the shredded paper (see 2 on diagram)
  4. ) check that the shredding jaws (both the entrance and exit) are clear of any shredded material (see 3 on diagram)
  5. ) put everything back together
  6. ) plug power cord back in
  7. ) force the shredder into reverse (see 4 on diagram)
Hopefully you should hear your shredder motor running. If it is switch it to automatic and try shredding again
Jan 24, 2015 | Shredder Office Equipment & Supplies
My shredder will not shredd paper
1. There is usually a small metal piece in the basket portion that has to hit the shredder when in place. If it gets bent, it won't line up and wont work. You can easily bend it to fit if that's the problem.
2. In general most people (like me) get all excited the first day of a new shredder. It will automatically STOP when it over heats. Don't worry, just wait until it cools itself long enough, turn it back on and it works again.
3. Aluminum in a shredder??? Never heard of that. sorry.
Sep 18, 2014 | Shredder Secure Shred Shredder
Omnitech shredder ot-nxc10pa
You must first unplug it and look inside the shredding blades, especially around the spot usually near the center, where there is a pressure button. When paper hits it, it starts shredding. Chances are some pieces of paper have jammed just over it stopping paper from hitting it and switching it on. I have had to use long tweezers to work the jammed bits out... Once clear it will work again. Also using shredder oil every 50 sheets through will help it cut easier , and jam less frequently. Do not put too many sheets through together in a bunch. No staples...
Aug 23, 2014 | Office Equipment & Supplies
Gears are not rotating; motor works though
I guess you have made sure that the cutters are not jammed by bits of paper and card?
Mar 23, 2014 | Office Equipment & Supplies
Sh92100 shredder not power
Shredders will stop when overloaded and they have to be disassembled to get them moving again. There is way more paper inside the cutters than you can see. Remove all screws and carefully dig out all paper shreds. Manually turn gears and it should get get working again. Shredder life isn't long after this happens so you may want to look into a replacement.
Jan 06, 2014 | Staples Office Equipment & Supplies
Royal 85x paper shredder: The shredder will start to shred but stops shortly after "grabbing" the paper. In order to get it shredding again, I have to put the machine in reverse, remove the...
Sometimes spraying shredder oil on the cutting teeth wil work.
You should shred paper with a light weight machine oil poured on the paper to keep the cutting teeth working freely.
Good luck.
P.S. If this doesn't work then just take the head off and cleanj/lubricate any bearings you find.
Mar 23, 2011 | Royal 85X Shredder
I have an Ativa MD 460c paper shredder that reads misalignment. What do I do?
I have a Ativa MD 1000 that I just bought. It ran for a few minutes the first time I used it an then stopped. I turned it off and unplugged it in case it had overheated. The temperature light did not come on. I wait for over 30 minutes and tried using it again. I was able to shred a couple of sheets of paper and it stopped again. The next morning I couldn't get it to work at all. The green ready light is on but the shredder will not start. I can't tell if anything is stuck in it. How do I getting running?
Sep 08, 2010 | Fellowes DM8C Cross-Cut Shredder
Shredding stops after 2 or 3 inches
If you have a strip cut machine it may be a problem with the gears. if it is not a strip cut it may be overheating due to not being oiled. First check with your manual to make sure you are not exceeding your duty cycle some machines only have a 2min on and 10 min off cycle,
Oct 20, 2007 | Fellowes P70CM Shredder
Aug 29, 2007 | Quartet gbc 6120S Shredder
109 people viewed this question
Top Universal Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Universal Office Equipment and Supply Expert? Answer questions, earn points and help others
