My washing machine. Isn't working just two lights flashing. Easy iron and rapid. Anyone help ?
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Remove plug 4 ten to 15 mins
Posted on Apr 13, 2015
    Top Expert:
  • 52,086 Answers
Sadly no since there is no make or model listed to begin search call a service man
  • Keil Stanley Apr 13, 2015
    Ariston a1636 1600 spin
  • 209 Answers
SOURCE: indesit WIL103 flashing lights problem
because of the short time this runs then stops, there could be maybe 3 faults, 1 check water inlet valves and supply for water flow 2 check for any motor action (use another programme) 3 check heater element for open circuit number 1 or number 3 sounds most likely hope i have helped, if so rate me please
Posted on Sep 25, 2007
  • 160 Answers
SOURCE: I have an ariston A1437 washing machine and when
Fault is a motor one...Motor jammed / tacho detached: check motor & module connections for loose or broken wire..
Posted on Jan 04, 2010
  • 3 Answers
SOURCE: Hi, we have an Indesit WIXL 143(UK)washing
This probably happens after the main wash has completed and it is just finishing the first rinse. It seems to be a warning that there is a partial blockage on the waste outflow. Empty the wash and use the DRAIN program to get as much water out as possible. From the FRONT of the machine open the lower flap and and then put a large towel on the floor. Unscrew the big black filter cover slowly - some water will come out -about a cupful. Ensuring the machine is turned off, use a cloth to remove any obvious build up of "gunk". Would suggest using an old toothbrush to clean off the surface and the plug.
99% of the time - Job Done!
You may have a blockage in your waste pipe. (If using an extension check any coupling has not "bunged up".
Last, check your waste pipe / grey water connection. Again, this "should" be fine, but it may be bunged up, especially if it feeds into the sink outflow.
Stick back together, plug in and use the 11, fast wash option in cold. Should now be happy, and you should hear water gurgling away noisily down the waste.
Always worth doing a 2 - 90 extra hot wash once in a while even EMPTY of washing just to "flush the system" now and again.
Hope this helps and saves you a £104 service engineer call from indesit :)
Posted on Mar 10, 2010
blueextc3221
  • 15935 Answers
SOURCE: Washing machine not working
The lid switch/latch has failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 10, 2010
SOURCE: My Ariston A1437 will start
I had this problem last year and had to call an engineer out. The problem was not with the washing machine but with the drainage pipe to the sink unit which had become 'backed up' with softener and the machine could not empty properly. 1 year on I now have the other 2 lights flashing and need to find out why. Any help gratefully received!
Posted on Oct 21, 2010
All lights flashing rapidly
Did you use a big hammer
That will fix it every time LOL.
Jun 29, 2012 | Fisher and Paykel Fisher Paykel Intuitive...
My Ariston A1437 will start working as normal and then both the lock light, easy iron and rapid buttons flash and then the washing machine stops after about 3 minutes. Any help muchly appreciated!
Aug 29, 2010 | Washing Machines
Control panel lights ALL flashing on hotpoint aquarius washing ma
my lights are all flashing on my control panel, its takes water in then pumps out straighaway doesnt wash or spin i have changed the brushes so i know it isnt that please help it only about 3 years old
Dec 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Lights flashing on indesit WIL123S
Hi, sounds like you need to change the door interlock located where the door catch pushes into.
Take the top off and undo the two screws with a tork screwdriver
and replace.
(Remember to turn off the supply and pull out the plug top)
May 09, 2009 | Indesit W 123 Front Load Washer
Indesit washer dryer stops halfway through a wash....
depends on what lights are flashing this is your fault code
Mar 28, 2008 | Indesit W 123 Front Load Washer
Indesit WIL103 flashing lights problem
Sep 25, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
