Question about Performance Teknique Car Audio & Video
My 2400 watt 2 channel performance Teknique amp as soon as I get up with power ground and remote the protection mode light comes on how can I fix or repair this
  • William Reba
    William Reba Apr 13, 2015
    Check connections and fuses.
techman
  • 3130 Answers
SOURCE: diagnostic light
Best thing to do is disconnect all the speakers with no input on the amp turn it on and if its still in protection seek help in the repair of said amp at http://performanceteknique.com.. If the protection light goes out then start to put back on each speaker with no volume and the unit off. if you get to a speaker that makes the unit go into protect then leave on that speaker and disconnect all the rest .. If the protect remains then something with that speaker or wiring is bad BUT if after disconnecting the rest of the speakers that you hooked up then theres is still a power issue with your amp
Posted on Apr 05, 2006
SOURCE: amp staying in protection mode
No, this amp is not a heavy power consumer- matter of fact it takes very little power to run.Maybe you should check the fuses on the amp to see if they are what is recommended.Also check your fuse kit to your amp- your fuse might not be big enough.If neither works take it back where u got it.
Posted on Jan 02, 2008
  • 631 Answers
SOURCE: performance teknique icbm 892 1200 watt amp
DD, JL and pioneer in that order. I don't recommend any particular size but 12s are a good compromise.
Posted on Sep 22, 2008
blueextc3221
  • 15935 Answers
SOURCE: ICBM-DIGITAL MONO-Channel 2000W AMPLIFIER speaker much
Look into competition lines of different manufacturers.... Massive Audio DMX, Soundstream, Atomic APX, Incriminator Audio Death Penalty Series, Kicker Solo X etc. In car audio, you have to pay to play. Dont expect a 100.00 subwoofer to take 2000W continuously.
Massive Audio offers a no questions asked warranty. Even covers blown voicecoils!
Posted on Dec 22, 2008
Professor_V
  • 92 Answers
SOURCE: I have an older model Jensen 500 watt 2 channel
REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS AND POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL GOES INTO PROTECTION AND YOU HAVE VERIFIED THAT THE POSITIVE AND ESPECIALLY THE GROUND CONNECTIONS, ALONG WITH THE REMOTE CONNECTIONS ARE 100%, THEN THE AMPLIFIER WILL NEED TO BE SERVICED. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Posted on Jan 06, 2010
Red power/protector light
The amplifier has gone into protect mode and will stay in that mode until the cause is corrected.
Nov 17, 2013 | Sony Xplod 800W Class AB Bridgeable...
I have my amp hooked up right to two 12 inch subs but the red protect light comes on wht does this mean?
Check all your cable work.
Power is connected tight? Ground is attached tight - on both ends (my guess is it is the ground) Remote cable?
Is the ground a proper ground?
Mar 01, 2011 | Dual XPA2100 2/1 Channel 300 Watt...
I have a 1200 watt G-Max sub amplifier and it just went into protect mode
Turn down the volume or power settings on it since its pulling too much power and shutting off for a few sconds to keep from blowing. Depending on the amp and speakers your using dont bridge the channels. If it won't come out of protect mode then unhook everything and just hook power, ground, and remote and wee what happens. If it comes on again and stays on then amp is blown.
Aug 11, 2010 | Jl Audio Car Audio & Video
Blow out amp
try a basic connection connect
positive from car to positive of amp
ground to ground
and positive of car to remote of amp
see if it turns on
also check the fuses in the car
check for voltage on the wires
May 15, 2010 | Performance Teknique ICBM-782 Car Audio...
I have 2 perfomance teknique 700wts and i dont know what kind of amplifier use
Hello perezmagdiel,
That 700 watts is maximum peak power, not RMS. If you're looking to not spend a lot of money for an amp, but want something that sends enough power to the Performance Teknique's, I'd recommend a 2-channel like the Boss Diablo D400.2. It's plently powerful enough and if you change out later, the amp can be bridged. And for inexpensive, it's got a lot of nice features, including a remote level control. It's 2ohm stable in stereo. Nice, for under $70.
Hope this helps.
Jul 17, 2009 | Performance Teknique ICBM-892 Car Audio...
How do I fix the problem so they work again.?
A 1000 WATT AMP HAS PROBABLY GONE INTO PROTECTION MODE BECAUSE YOU ARE TRYING TO RUN 1600 WATT SUBS COMBINED
Jun 08, 2009 | Car Audio & Video
Performance teknique icbm-896 stick on diagnostics
If it's in protect mode, it probably has shorted output transistors. To eliminate other possible problems, read through the following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Sep 10, 2008 | Performance Teknique ICBM-896 Car Audio...
Performance Teknique wont work!!
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following. I'll assume that you've checked the amplifier's on-board fuses.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp almost certainly has shorted output transistors and will need to be repaired.
If you want to try to repair it yourself, read through the following page:
Basic Amplifier Repair Primer
Jul 02, 2008 | Performance Teknique ICBM-779 Car Audio...
Amp staying in protection mode
Jan 01, 2007 | Soundstream XTA880.2 Car Audio Amplifier
Diagnostic light
Apr 05, 2006 | Performance Teknique ICBM-782 Car Audio...
Car Audio & Video Logo
59 people viewed this question
Top Performance Teknique Car Audio & Video Experts
hoyzee1
Jose Velazquez
Jose Velazquez
George Nalley
Level 1 Expert
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
