Question about Kyocera CS-2050 Black and White Copier
The copier works fine. I was trying to stop a print run and was pushing buttons and now when a print is sent from the computer, it prints a solid black page.
  • William Reba
    William Reba Apr 13, 2015
    Unplug and reset demo or test page settings.
  • 523 Answers
You need to change the charger, it is the piece that sits on the drum.
Posted on Apr 25, 2015
leroyal
  • 2120 Answers
SOURCE: printing all pages as black
Open up the left side door and push in all of the chargers to make sure they are seated.
Posted on Jan 17, 2009
M2Tech1
  • 313 Answers
SOURCE: Problem for print by photo copier
sounds like the charge grid is not set properly in the drum unit..did you et up the drum unit properly and run the new dev and drum set up..if youy are getting black the charge is not working correct as the charge of the drum help to keep the toner from adhering to the drum surface when copying .. I would take the drum chrge unit out again and check it is set in the right way when you put it back on also check the contacts arent put out of line.
Posted on Aug 05, 2009
  • 66 Answers
SOURCE: copier km-c2525e will only print 1 page of document
Hi
it might be a long shot but have you got an add toner message on your copier screen.
When toner is required the copier will only print on page at a time.
Alternately you should ensure that you have not selected a partial print  eg
print current view or print current page.
if all this fails, reload the driver and or your Acrobat reader
hope this helps
Posted on Aug 16, 2009
  • 22 Answers
SOURCE: Kyocera KM 2030 Changed the toner and it is now
You need to clean the corona unit again.
Posted on Nov 23, 2009
n25an
  • 622 Answers
SOURCE: My Kyocera Mono Laser Printer is stopping between each page
call a service technician to clean the paper feed rollers... they aren't picking up the paper... this triggers the error so you have to stand there and manually reset the error and it prints...
Posted on Dec 24, 2009
The power button on my hp deskjet 3845 is flashing & not responding to pending print jobs. help
it is possible that the printer as a ink issue or thinks it has a paperjam, another thing that can happen is that the print sent to the printer become corrupt locking the printer in a "i dont know what to do" state.
try to run a test print through the printer using the internal test, this is normmaly done by holding down the power button till the power light blinks it should then spit out a print (do this while unplugged form the computer)
**for full test print instructions refer to user manual)
if the driver has become corrupted it also will send damaged print information to the printer
if the test print works fine than you may need to delete all your queued jobs and then run a WINDOWS TEST PRINT form the driver. if this still does not work reinstall the drivers of the printer
(providing the printer will run an internal print)
Feb 08, 2011 | HP Deskjet 3845 InkJet Printer
A document was sent to the 5110cn color printer. it is a full color duakl sided brochure. Keeps trying to print but errors out before loading all images so all that gets printed is one or two of the...
The reaason it keeps trying to print is because it's in the print queue on your network.
Have whoever sent this to the printer open the print queue and delete it.
Only the originator or the print queue admin can delete the job
Jan 06, 2011 | Dell 5110cn Laser Printer
Started out with paper, would start to load paper them as soon as paper stared in would stop. After several tries it would work. Then it stoped taking paper at all. Each time you try to print it stops and...
First I would remove the paper tray and check the rollers and print path for any scraps of paper that may be tripping up a sensor. If all seems well, ...
Try this next: It will reset the printer's configuration info.
To factory reset your Dell 1700 series printer follow these steps.
  1. Turn off your printer
  2. Open the front cover (push the button on the left side)
  3. Hold down the "Continue" and "Cancel" buttons and turn the power back on.
  4. When the "Error LED" light on the control panel is solid, close the cover and release the "Continue" and "Cancel" buttons.
Tip: To print a configuration sheet push the "Continue" button twice. This will give your printers IP Address.
Dec 31, 2010 | Dell 1700n Laser Printer
Our lexmark e234 printer has all lights flashing. Last job was 30 page document which printed out fine, then all lights started flashing. We have not been able to print since. Thank you:)
Try resetting the printer to factory Defaults. First turn off the printer, then open the front cover like if you were to take the toner cartridge out. Once the front cover is open then push and hold the two buttons on the panel of the printer and turn the printer on. Make sure the front cover is open and that you are pushing the two buttons all the lights will flash and they will stop at the very bottom light and stay solid once that happens let go of the buttons and close the cover and that should reset the printer.
Jan 26, 2010 | Lexmark E234 Laser Printer
Printing issue
If command was with computer and you print mode of the printer, do stop by way of the removing the task sent on printer, from panel printers nominated printer afterwards remove problem, but if in mode of copying, push all reset buttom unset or removing the mode of the printer and translation on copying
Sep 13, 2009 | Canon ImageRUNNER 330s Copier
Printer will not copy although we can still print documents sent from the computer.
Is it infax mode?
Do you get a green Start Button?
Are there any error codes diaplayed when you push the button?
If no to these, unplug the machine for several minutes and restart.
Hope this is of some help
May 19, 2009 | Sharp Office Equipment & Supplies
Try to print--scanner failure appears
I think your printer has been, for some time now, trying to tell you something and the scanner failure message
is the last in a series of messages.
First, the copier and the printer and the scanner worked fine, "for years",
Then, the copier stopped accepting scans, while printing from data sent by your computer.
Then, you received a scanner failure message again, and will not accept data from your computer, and
"won't print at all"
Your printer/scanner/copier/fax has needed service for some time after years of continuous service.
Evaluate now, based on its initial cost and the lesser cost of All In Ones whether you have already
obtained sufficient service to amortize the cost over time, and you may conclude that service is eitherr
cost effective or ineffective at this time.
Apr 17, 2009 | HP Office Equipment & Supplies
Zebra 2844 won't print anything.
Sounds like you may have taken out more than the fuse. In case there is still life the next thing to try is a printer reset
1) Turn printer off.
2) Hold down feed button whilst turning printer on.
3) Let go of the feed button as soon as it starts to flash and then wait.
4) Printer will measure out 4 labels then print out a Hex dump ending with a not to "Push Feed to Exit"
5) Push feed
Follow the above instructions, if you mess around tapping the feed button (not following the above) you can change the printer between line mode and page mode. To swap that back is another storey.
David
Jan 26, 2009 | Zebra LP 2844 Thermal Printer
AAAGGGHH! Cannon i9100 printer WON'T Print...can't get help
jast go in control panal in parinter doble cilck on printer icon cancel all the print documets try this mthrod & tell me what happen
Feb 26, 2008 | Office Equipment & Supplies
Kyocera CS-2050 Black and White Copier Logo
49 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
