Question about Epson WorkForce WF-3520 All-in-One Inkjet Printer
A video I watched seems to indicate a spring that needs to be repositioned but the video is dark and not helpful
SOURCE: Epson AcuLaser CX11N ADF Paper Jam
I had a very similar problem with the ADF, it resulted in ADF paper jam - message and then in Req Code 2011.
I checked sensors and everything else, then called a epson service professional.
After telling him the Req Code, he knew the problem and said that the problem is the board, which needs to be exchanged, mentioning that this spare part is expensive.
I then checked the whole ADF again, now opening the long grey cover on the backside, I disonnected the connector cable from both sides and - using a multimeter - checked this connector cable for breaks.
Result: the violet cable was broken, so I soldered in a new wire, using the last cm of (old) wire on each side - and now the ADF works fine.
This cable is easy to change if you get the spare part, there is a connector plug on each side, on the ADF side is an additional ground wire (green) fixed with a single screw. Thats it !
For the electronic experts: the configuration of the connector:
sourrounding metal cover = ground, thick green Wire on the ADF side
If you turn the plug that way, that the two single contacts are on top, these are the colours:
1st row: brown - black
2nd row: green - yellow - orange - red
3rd row: grey - violet - blue
Hope this helps
Posted on Sep 17, 2008
SOURCE: Message Paper Jam MP E
The sensor at the back of the printer is either stuk or out of position open the back of the printer and see if there is a little black lever sticking out if so check it for movement if it sticks yuo have to remove the back paper guide and reseat the lever in its correct position
Posted on Dec 22, 2008
SOURCE: ADF Jam... Service req c2011
Can be a tough one.
1st - Open the ADF & make sure that the 2 little Sensor tabs move freely.
2nd - Lift the ADF & check that the White Plastic Paper Guide is "down in the slot" & not resting on edge of the white flat bed scan pad or overlapping the scan pad.
For some C Error Codes
Check for electrical interference from external devices.
Disconnect the Printer from all devices, and run a test print..
Here are the "c2011 error" fixes per the manufacturer:
Replace the Automatic Document Feeder.
Replace the Scanner.
Replace the Main Board.
You might try unplugging the ADF & see if you can operate without it.
If you unplug the scanner, the printer might not function.
Posted on Feb 06, 2009
SOURCE: message: Error paper jam. There is no paper jam.
Yes there is some micro piece of paper is under a sensor somewhere Get serious and pull it apart, what have you got to loose! Inkypete
Posted on Apr 21, 2009
SOURCE: Epson Artisan 800...adf keeps saying paper jam,
ADF Motor Assembly has gears which crack. Replacement of ADF Motor Assembly normally required. Compass Micro Inc sells this part. Part #: 2132225.
Posted on Jul 30, 2011
Feb 01, 2017 | LG Washing Machines
on Feb 13, 2018 | Dell A940 All-In-One InkJet Printer
Mar 30, 2015 | Epson WorkForce 545 Wireless All-In-One...
Feb 26, 2013 | Casio A168W Wrist Watch
Oct 23, 2012 | Computers & Internet
Watch this videos tips:
http://www.youtube.com/watch?v=qgb2TY3WCkg&feature=related
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness
http://www.fixya.com/support/r10786838-test_procedure_dc_motor
http://www.youtube.com/watch?v=23ZgWaVEQjA
You must need level the equipment please see you user manuals+Test the main motor , after you saw the videos.
Sep 08, 2011 | Proform Crosswalk 500 Treadmill
May 29, 2011 | Citizen Eco-Drive watch
May 11, 2011 | HP LaserJet M3035 MFP Printer
Dec 04, 2010 | Brother MFC-8860DN All-In-One Laser...
Dec 03, 2010 | Dell 2135cn All-In-One Laser Printer
126 people viewed this question
Hi Betty Zimmermann, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? ADF is the document feeder. Is that where the jam occurs?
