Question about Garden
Mower starts on the first pull but will only run if you tilt it on back wheels towards handle. I have removed the fuel lines and blown air through but that hasn't helped. Suggestions?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
What engine ??? You'll get a professional answer if you would of included this in the first place...
Posted on Apr 14, 2015
  • 3,519 Answers
Hi Lynne:
What a great puzzle!
Here are a couple of things to check.
1) Oil level. If it's overful it may be "damping" the engine.
2) Throttle / governor linkage. Check that the spring hasn't come off.
Somehow, gravity is allowing it to run when it is tipped. The trick will be to look at the different things that can happen, and find the one that's trying to trick you.
Posted on Apr 13, 2015
  • 4,821 Answers
Try a carb cleaner like BG, amsoil or outboard product. They work..easier then rebuild
Why does my mower starts on the first pull then dies out
Dirt in the carb jets would be the common reason, will it stay running if you cup your hand over the inlet of the carb, not block the airflow completely but restrict it, if the engine stays running blow out the carb jets with compressed air.
Sep 28, 2016 | Garden
The lawn mower won't stay running. It starts up without a problem. I mowed the lawn for about 45 mins and the mower sounded like it was out of gas. It has plenty of gas in it. If I tilt it, by...
Sounds like the automatic choke to me. When it acts up next time, remove the air filter, and observe the butterfly valve on the carb. Hold it open with a screwdriver, and see if it starts and runs. I have found that wireing the thing wide open solved my Toro problems. The mower is still under factory warrenty however, so you can always take it back! Hope this helps my friend!
Sep 09, 2011 | Toro Power Lawn Mower
Scotts by john deere riding mower - 220 hours, 17.5 HP, 42" cut, Briggs & stratton engine -- New Strarter, new battery, good fuel... will turn over but engine will slow down then stop, will not...
Very high likelihood you have fuel line problems. Disconnect primary fuel line from bottom of fuel filter and blow compressed air back up the fuel line to the gas tank. This will clear the line of any trash. Reconnect fuel line to filter. Then remove spark plug and spray a couple of sprays of WD-40 into the cylinder.. Re-install spark plug and then restart. WD-4- will act as a starter fuel and will start the engine for enough rounds to get fuel pump to working to normal run.. Good luck.
May 15, 2011 | Briggs & Stratton Garden
Lawn Mower will not stay running then will not restart
I think we all understand the frustation penaone.
I noticed u didn't clean the fuel tank, water, dirt, and rust in it can give u problems. But u need to clean the lines and carb. again also. One of the kids filled my mower gas tank with driveway gravel once, and after I cleaned things out, the mower never run so good. Also your spark may be grounding out somewhere before it gets to the spark plug. Check for a bad spot in the wires from the magneto. Some of that may be behind the flywheel though.
ballping
Jul 28, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Runs for five seconds after being tilted up and put back down.
Trash in the tank fuel line outlet. When you tilt it the trash moves and lets some gas in. Set it down and the trash goes back in the hole and shuts off the gas. No pressure to feed fuel so when you pull choke makes it run rich and then starves for gas again. Dump gas, disconnect the line at the carb. Put a clean tube (drinking straw, plastic tube, whatever will fit so you don't get gas in your mouth) in the gas line and blow air into the tank through the filter clearing the obstruction. Reconnect line then see if it runs longer before it shut off. If it does clean the tank and flush the dirt out.
If that doesn't change anything then it has to be a carb diaphragm leaking and it need a rebuild kit and fuel system flush.
Apr 30, 2010 | Mtd 22" Yard Machine Push Mower
HI GUYES WHO HAS THE SECRET TO REMOVE THE TILT WHEEL PADDLE LEVER ON A 02 DODGE DURANGO.....THANKS FRED
You've got to be very well versed in steering assemblies before attempting to do this. There are very strong springs int there and if not carefully positioned they can hurt you severely. You must first remove the wheel with a steering puller set. Make sure that the wheel is in the upper most position, first. then pull the wheel. keep track of the order in which the parts come out.Taking pix along the way often lend to ease the reassembly. Use the circlip removal tool to remove the clip holding the lock plate down.By now you'll be able to see the turn signal switch. remove the lever hold down screw and slide the turn lever out.Remove the three retaining screws for the switch and pull it straight towards you enough to lay it to the side. No need to diconnect the wires.Once you've finished with this, take the tilt pin remover from the set and while keeping a slihght pressure on the respective side, 9:00 for the left pin, 3:00 for the right. Remove the pins and then you'll be able to slide the collar up and away enough to get at the tilt lever. That's all. Reverse the order for assembly. Thanks, Dana
Aug 25, 2009 | 2002 Dodge Durango
My Troy Bilt Self Prop. Z-start won't keep running. I clean All, replace Filter and Plug, have clean gas and lubed all. It Starts for 2 seconds and then cuts off. What do you think it could be? Thanks....
I had the same problem, Tilt the lawnmower on it's side air filter facing up and remove air filter cover and air filter then remove the fuel bowl underneath the carb; then clean the fuel bowl with some gas and a clean rag. For the next step be sure to aim blower tip at target then look away before pressing trigger, this will prevent gasoline form getting into your eyes.Take an air compressor and carefully clean out the carb where the flap is and the tube where the fuel float that would rest inside fuel bowl is. Leave on side install everything back except for air filter and cover. Then pour a little gas in the carb to prime it, lay the lawnmower back on all 4 wheels and try to start.
Aug 02, 2009 | Troy Bilt 5.5hp Self Propelled Mower
My husband has a husqvarna self propelled mower that was running great and now all of a sudden it will not allow him to pull the string to start it? I believe the model is gcv190? Do you think something...
the problem with tilting the mower on its side is that you put oil up in the carburator.that makes the needle let dirt through it.remove the spark plug and pull the recoil a few times until you do not see any more fuel comming out.once all the fuel is out of the cylinder,reinstall the spark plug,chech oil level.you should change the air filter.it probally has oil in it and will make the engine not run right..start the mower and let it run awhile.the problem shoul clear it self up.if it happens again you will have to clean the dirt from inside the carburator.hope this helps let me know...................
Jun 06, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Cannot pull rope out to start mower
Bad news , Mower has sit up too long and the piston / crankshaft has become rusty and froze in place. (fix) buy some liquid wrench it comes in a can at your local hardware store...Tilt the mower onto its front wheels and remove the spark plug. Fill the Cylindar with the oil and leave it for a couple days. after a few days lean the mower back and attempt to pour out the left over oil. Then (Check Your Oil level) preferable replace old oil and pull choke..and start mower...if the engine is still frozen (Buy a New mower) 125bucks Sears.
Mar 22, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
