Question about Craftsman 27cc 2-Cycle Curved Shaft WeedWacker Gas Trimmer
Grass trimmer pull cord has frozen in the out position
    Top Expert:
  • Craftsman Master
  • 52,099 Answers
Oops jerked too hard or too far . give it a semi gentle thump and see if it retracts
Posted on Apr 13, 2015
Trimmer pull cord stuck in pulled position. How do I go about finding and fixing problem? Not sure exactly which screws/bolts to remove to get at the assembly.
How to Fix a Weedeater's Stuck Rope ' Home Guides ' SF ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
A gasoline-powered string trimmer has cords on both sides. Most people ... In order to troubleshoot and fix a stuck cord, you have to remove the starter housing. ... Swivel each plate until it locks into position and then tighten the screw to hold it.
WeedEater string pull repair STRING WON'T RECOIL ...
? 6:35
https://www.youtube.com/watch?v=eIcj4KFmp4A
Aug 8, 2013 - Uploaded by AdamDIY
WeedEater string pull repair STRING WON'T RECOIL - FeatherLite XT260 ... How To Properly Replace Fuel Lines On a Weed Eater Trimmer
Nov 26, 2015 | Garden
Tanaka tht 2100-very difficult to start. Pull cord is is either too loose when pulled or it is jumpy, meeting with a bit of resistance?
i think it sounds like the motor is going i had a chainsaw and it did the same thing after a while the motor went and the chainsaw was no good anymore so you mite want to take it to a dealer that deals with your grass trimmer
Sep 03, 2012 | Tanaka Commercial Grade "Inspire" Design...
Engine start procedure for grass trimmer 350 L x series
  • With the trimmer placed on a level piece of ground press the primer bulb about 10 times.
  • Open the choke.
  • Press the throttle and lock it in place with the lock button
  • Pull the start cord until the engine catches. It doesn't matter if it cuts out again.
  • Close the choke, and if the engine did cut out the first time, pull the start cord again. This time it should start and you can start trimming the grass. If it didn't cut out just close the choke and you're ready for trimming.
Apr 06, 2011 | Husqvarna Garden
The strings keep on breaking off at the eyelet
Usually means grass is too long for that trimmer or you are cutting too close...try trimming with just the tip of the cord...or eyelets are worn sharp
Aug 08, 2010 | Ryobi 18v Lithium Grass Cordless Trimmer...
How to change the spool in the black and decker grasshog
Is this the cordless Grass Hog? Turn the trimmer upside down so you're looking at the bottom. There are two orange tabs on either side of the spool -- push these in and the head should pop up so you can pull it out.
On the new spool, feed the cord out several inches and stick it through the hole in the trimmer where the old cord stuck out. Then pop the spool into the cavity so that the orange cover faces out (toward you). Pull the cord taut and make sure it is not long enough to hit the plastic guard. If it is too long and it touches the guard, pull the spool off and wind the cord in a little bit. If the cord is too short, pull the spool off and thread out a little bit more length and try again.
Turn the trimmer right side up and turn it on to make sure it works. If you hear a loud rapid thumping sound that sounds sort of like a machine gun, the cord is too long and is hitting the plastic guard.
Jul 04, 2010 | Black & Decker 14" Grass Hog Xp...
Cannot get the housing off so that I can change the pull cord on my troy bilt tb70ss grass trimmer
If you are holding the unit where the drive cable goes in, there is a screw in there. It is a #15 or 20 TORX screwdriver. Take out the screw and it will allow you to get to the starting spool. Good luck...Lee
May 29, 2010 | Troy Bilt Tb70ss Gas Trimmer
Stihl strimmer engine runs but wont cut grass the head wont turn what cuts grass
First take the head off and look for grass, weeds and string wound up in there. A lot of times that's the problem.
Next, with the head off and the switch in the off position, pull it over a few times and see if the shaft spins. If not, could be a broken shaft or a bad clutch.
Apr 04, 2010 | Oregon Scientific Complete Carburetor for...
Describe your Black & Decker
Take the casing apart and I bet one of the wires for the cord pulled out. I bought a brand new ryobi sawsall,used it ten minutes and it quit. Was going to throw it away but decided to open the casing and the black wire pulled out of the terminal,it was a five minute fix swear to God!
Aug 10, 2009 | Black & Decker 14" Grass Hog Xp...
Installing new line on my string grass trimmer
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Jul 03, 2009 | Homelite Mighty Lite Lawn Trimmer
Craftsman 27cc 2-Cycle Curved Shaft WeedWacker Gas Trimmer Logo
91 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
