HOW DO YOU OPEN CD TRAY
JUST CANT SEEM TO OPEN THE TRAY. NEVER BEEN USED. IS THERE SOMETHING WE HAVE TO UNLOCK
  • 682 Answers
We'll if the cd tray fails to open either by the remote or by the eject button on front fascia...try looking for a small pinhole underneath the cd tray.this is a manual release port which allows you to push a sewing needle or fine paper clip.this should release the tray mechanism.sometimes the tray jumps a cog during transportation from one place to another or the cd does not seat into the tray properly and prevents normal ejection.hope this is helpful.
Posted on Apr 13, 2015
How do I open the tray?
Dear
Open my computer right click on cd drive icon and click on eject cd. If it is not working then take a small pin push it in the small hole found at the cd drive bezel to unlock the cd tray.
Thanks.
Mar 15, 2015 | Samsung Computers & Internet
How do i open the disc tray on my laptop
Presuming you are talking about a CD-ROM drive, you should first check your manual for information on operating the drive. There are many ways drive trays may be opened. Sometimes there is a button on the laptop that has the standard symbol for CD eject on it that will open the cd tray. Sometimes, there is a small button on the cd-tray itself that when depressed will cause the tray to open after a small delay. This all presumes that you don't have a tray-less
CD drive, that is just a slot on the side of your laptop. If the CD tray is stuck, because of some problem, look for a small hole on the face of the CD tray. Take a straightened out paper clip and push it gently STRAIGHT into the hole until you feel it stop against a bar. Push just a little harder, and the tray should pop open. This latter procedure should only be used when all other methods have failed to open the CD tray.
Sep 04, 2014 | Toshiba Satellite Computers & Internet
I copied some pictures to a cd and the cd ejected when it was done...i put it back in to check it and now i cant get it to open and i cant find anywhere that shows the drive exsist...i tried it again and...
It sounds like something is wrong with the CD you burned. Take a paperclip and straighten it out. Open the CD rom cover flap if there is one covering it. There will be a small hole in the cd drive under the CD tray. Stick the paper clip in and push. This will release the tray. Pull the tray out manually and remove the cd, then push the tray back in gently and reboot your computer.
Jan 30, 2011 | E-Machines emachines (emachinees) CD-ROM...
My CD-ROM drive will not open. What gives?
Something is "jammed" -- take a Norwegian paper-clip, and straighten one end. Put that end into the small hole in the face-plate of the drive. Insert it until you feel resistance, and then push another 1/4 inch (0.6 cm). The tray should "unlock" and open slightly; gently pull the tray open, until you can remove any CD-disk.
Then, spend $40 to buy a brand-new CD/DVD reader/writer, and install it.
Aug 22, 2010 | Dell Inspiron 531 Athlon 64 X2 4400+...
I bought the cd changer with my unit & two cds are stuck in it. This happened the third time I used the unit.
this is a mechanism problem. Also, maybe something might have hooked the cd tray and made it stuck.
What you have to do now is to open the player by unscrewing the cover, so that you can gain access to the mechanism inside the player.
After you must have opened the cover, plug the cd changer to light, power it on and use you hand to pull out the tray while you press open button.
Also make observations on the disc tray while you press the open button and check the disc tray and look for what is making it stuck and refuse to open. This is why you need use your hand to support the disc tray by pushing it open from the inside.
I wish you good luck.
Feb 25, 2010 | Bose Wave Radio
I cant open my cd tray on my tascam dp01
Look on the front of the CD tray for a little hole... push the end of a paper clip in the hole and the tray should open.
Dec 12, 2009 | Tascam DP01 All-In-One Recording Package...
Cd/dvd drive does not open and cd stops in the middle of running
HI
HERE ARE SOME SIMPLE STEPS TO OPEN THE DRIVE.
MAKE SURE THAT SLIDE BUTTON IS AT UNLOCK POSITION
  1. Step 1 Power down the computer. You won't need power for this and when inserting metal objects into the computer it is a good idea to keep it turned off.
  2. Step 2 Take your paperclip and straighten it. You probably won't need the whole thing, but straighten most of it.
  3. Step 3 Look around the front of the drive. There should be a very small hole there (just wide enough for the paperclip). This hole will probably have no markings and seem to serve no purpose.
  4. Step 4 Push the paperclip into the hole. There is a button inside there that will release the lock on the CD/DVD tray. It's pretty far in there so push lightly until the paperclip won't go any further. You'll see the tray move a little.
  5. Step 5 Now you'll need to get that tray open. Use something small and flat like a credit card, screwdriver, fingernails, or a dull knife (the type used to spread butter) to pry open the tray until you can get your fingers around it to pull it open.
  6. Step 6 Pull the tray open. It will give some resistance, but this should not hurt your drive. Get the disc out and close the drive again.
  7. Step 7 Reboot the computer afterwards to reset the drive. This step may not be necessary, but it's usually a good idea to reboot after manually opening the drive to make sure it resets and is able to be used normally again.
I HOPE YOU SUCCESSFULLY DO ........
THANK YOU
PLEASE RATE ME....
Sep 17, 2009 | Lenovo 3000 Y410 Laptop
176 people viewed this question
 Grubhead
Grubhead
