Fan runs, igniter runs, but heater won't light. fault light flashes 6 times quickly. chart says "cad cell shut down"? What does this mean? Or what do i need to do to make the heater run properly?
  • 2,992 Answers
I googled cad cell shut down.
Many answers. Most likely the flame detector is bad.
Posted on Apr 13, 2015
What is a cad cell and what does it do
A cad cell is a photo-electric device that reads the UV rays given off by flame after it has ignited. If it does not 'see' the flame, due to a flame failure OR a cad cell failure, the control circuit is locked out.
Make sure there is no carbon on the front (window)of the cell and make sure its adjustment is in perfect alignment to the flame.
Feb 19, 2015 | All-Pro Kerosene Garage Shop Heaters - All...
New Reliance gas water heater won't stay lit
There is a sensor that shuts off the gas to the burner if a flame isn't detected within a few seconds. It will usually look like a tube that extends into flame of the burner. It may be defective or it may just need to be repositioned so more of it is directly in the flame.
Mar 17, 2014 | Reliance Water Heaters
I have a halstead finest gold combi when I turn the boiler on the boiler goes into its ignition sequence when it comes to ignite the boiler fires but after the igniter stops the boiler cuts out completely...
Difficult to get too specific without knowing if you have gas or oil. Also, I am going under the assumption you mean the burner shuts down, not the whole heating system. That being said, all heating appliances have whats called a safety curcuit. Each control has the ability to shut down if certain critera are not met. There is a sensor that senses light down the blast tube. If no light is sensed in a predetermined time period, then the sensor cuts power to the burner. This stops delivery of fuel so if it does ignite you wont blow up.
(I suspect that the ignitor and burner shut down simultainously.)
It may be the sensor (cad cell eye) is doing its job, however why is the question. Could be a number of things including the fuel delivery, ignition, improper air adjustment, etc.
No qualified professional should diagnose a problem unless they are in front of the appliance. I recommend you find a licensed qualified heating techician. Hope this helps.
Feb 04, 2013 | Water Heaters
We have a model TS210KT kerosene heater and it runs for 15 sec. and then E1 CAD Cell Shutdown code comes up and the heater shuts down
  1. 1) Check wiring to Cad Cell (per wiring schematic in manual). Test heater.
  2. 2) Clean Cad Cell photo cell.
    a) Slide Cad Cell out of Cad Cell holder.
    b) Push the photo cell out of the white rubber Cad Cell housing by
    pushing on the blue and white wires.
    c) Clean the photo cell with a soft cloth and rubbing alcohol.
    d) Pull the photo cell back into the Cad Cell housing and reinstall into
    holder.
    e) Test heater.
  3. 3) If the heater still does not operate, replace Cad Cell. Test heater.
  4. 4) Replace oil flame control assembly. Test heater.
    Owners Manual with full details here.
Dec 08, 2011 | Mr. Heater Heating & Cooling
The red light on the water heater keeps flashing
Attached to the water heater is a troubleshooting chart for your sequence light. 1 flash means..., 2 flashes means...., and so forth. Find the chart, count the flashes and see what it means and we'll go from there. Douglas
Sep 18, 2010 | Reliance Natural Gas Water Heater Control
I have a Goodman high-eff furnace, 115 BTU/hr. The fan runs constantly but it has stopped blowing warm air. I'm getting 6 flashing lights as error code. What's this mean?
Remove the lower panel and look for a wiring diagram pasted to it. On that diagram there will be an error code diagnostic chart. Depending upon which model you have it could be an open overheat switch caused by a dirty filter or a bad fuse.
Feb 13, 2010 | Goodman GMS90703BXA Heater
Main Fan won't turn off even with thermostat removed. Burner not
There is a chart with the wiring diagram and othere charts that will tell you what the 6 blinks are for. That should tell you what is wrong and what part you need. Sounds to me like the board has an issue or the gas valve is locked out.
Jan 10, 2009 | Goodman GDS81155CNA Open Flame Mid-Size...
Error code of 6 flashing light on circuit board,
There appears to be a short in the unit. Not sure where. The power to the fan is not interrupted completly when the fan shuts down, still feeding voltage to the fan, keeping it running slow. Before checking the wiring, please turn off power first.
Nov 19, 2008 | Heating & Cooling
All Pro Heater
most parts for kero heaters are interchangable. go to desatech dot com for parts. check for a reset button for your heater. if no reset, does the fan run? your unit can use one of two ignition parts. a spark generator with a spark plug or a hot surface igniter. the unit uses a cad cell flame detector. you might need to replace this.
Nov 18, 2007 | All-Pro Kerosene Garage Shop Heaters - All...
Heating & Cooling Logo
82 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
