Question about Brother HL-4070CDW Printer
WILL NOT FEED PAPER FEOM LOWER TRAY - Brother HL-4070CDW Printer
SOURCE: no longer prints envelopes from manual paper feed
you need to change driver configuration
very easy
elvis
Posted on Apr 18, 2008
  • 18 Answers
SOURCE: paper tray problems
If you take your paper tray out and remove your drum unit, out the machine on its bum, so to speak, and it should sit nicely. If u look at the belly of the machine there should be a little grey roller just at the top, if you get some soapy water on an old rag and give it a wipe. Then if you look at the paper tray there is a grey pad give that a wipe as well and then wipe off all the excess water and try to feed from it again.
Good Luck
Posted on Dec 09, 2008
  • 215 Answers
SOURCE: MFC886DN will not pick up the paper in the lower tray.
first, most common problem is the rear stopper in the cassette is pressed too tightly against rear of paper. leave 1/8" gap between stopper and rear of paper. if that doesn't help, pull cassette out and locate gear on left side of cassette bay and make sure it is not dislodged.
good luck,
razors
Posted on Apr 15, 2009
jubag14
  • 89 Answers
SOURCE: Printer prints from manual feed but not from tray.
you need ot open up the papper tray and more the laser down then it should work
please rate my helf i need you to i am a exert
Posted on Apr 20, 2009
anantakumarj
  • 330 Answers
SOURCE: Paper Feed Tray will not feed paper. There is a
goes through below link and download the manual and try to clean the paper pick up roller and check i think it will solve your problem .......
Posted on Dec 14, 2009
PAPER DOESN'T FEED THROUGH
check on the panel of the printer if the selected paper tray is the lower tray or the upper tray put paper on both tray mark the paper so you can see which tray is being feed,
Aug 04, 2011 | Canon LaserCLASS Fax 710 Printer
I Have an EPSON Stylus TX700W Printer , & am having problems getting it to feed paper. Have tried all the Paper Jam solving problems to no avail. Printer just keeps saying "The Paper Cassette is...
This can also be caused when the upper cassette tray (for small paper stock / photo paper) becomes detached from the lower tray. There is a gear attached to the lower paper tray which handles movement of the upper paper tray. Make sure that moving this gear causes the upper paper tray to move. If it doesn't, then you need to snap the upper paper try on a little better.
Jul 10, 2011 | Office Equipment & Supplies
Paper will not "feed" from
this is an issue with the papper feed and pickup rollers if it is not taking the paper from draw you need to replace the pickup and feed rollers also check the paper feed clutch if no good replace as well
Also make sure also make sure the paper is being lifted up when you close the draw you should hear the tray lifting the paper up to the feed system
Feb 17, 2011 | Minolta EP4000/5000 CS/PRO Copier
Im having problems with my Riso RZ300. error A-06 and ive tried to clean the paper tray it keeps on flashing the same error. Thanks for your attention David
There should be a numeric extension to the error. Ist it this error A06-403? This means:
Error type A06: Check paper feed tray Error point 403: Either the upper or lower safety switch of the paper-feed-tray is OFF.
Hint: Check the mentioned switches.
Oct 10, 2010 | Riso RZ220 Duplicator
Problema para Riso - Duplicadora RZ220 Copiadora Error message A-06-403 Mensaje de error A-06-403
where can i find the Riso RZ Paper-feed-tray upper or lower safety switch
Aug 09, 2010 | Riso RZ220 Duplicator
Model PF-108 error c0991 a piece of a roller fell off when opening the bottom paper drawer is there a way to order the part and fix it ourselves?
Yes you can order the parts. I know exactly what happened. I sure this is on the lower most tray also called the LCT or large capacity tray. There is a defect in these trays where a plastic arm that holds the feed rollers warps and does not hold the feed rollers high enough so when the tray is opened/closed it hits the tires and snaps it off. The problem is that you have to pull the whole paper feed assembly out of the tray to replace the parts. This is not an easy process and certainly more than I could try and type here. The easier way if you have the manpower is to remove the latch plates and the 4 corners of the lower tray "cabinet", disconnect the wiring that is behind the center plate on the back side and have a couple guys lift the machine up off of the paper feed cabinet.
Then you will be able to see the feed parts.
Precisionroller.com has parts with pictures that hopefully you can match up with what you need.
Hope this helps.
Aug 04, 2010 | Minolta DiALTA Di250 All-In-One Laser...
Sharp AL-1540CS Single By-Pass works, regular copying get flashin
Could be dirty feed rollers. I am assuming you are selecting the lower tray as your paper source when you get the "P"
OK, so take out the paper tray. Remove all the paper and look for 2 felt pads on the metal spring loaded plate where the paper sits. Spray these 2 pads with glass cleaner. Wipe of the excess spray from the metal plate. Install the tray, select that tray as your paper source and hit the print button. You will get the "P" of course so just hit C then print again. Do this several times. What you are doing is having the feed rollers rotate against the pads and thus cleaning them. After you do this 5 to 10 times then remove the tray. Dab a dry cloth on the pads to dry them somewhat, add paper and re-install the tray. If the problem was dirty feed rollers then this will fix it. The other cause of your feed trouble could be a paper feed clutch going bad. This was somewhat of a common problem on these machines. You would need a service tech to get to the clutch, remove, clean, lube and re-install it. But only if the above procedure does not work.
Jan 08, 2010 | Sharp AL-1540CS All-In-One Laser Printer
Can I disable the lower print tray?
Hi wogan2:
Normaly when you get this problem it means that you need to replace the feed rollers in that tray.
Inspection
Rollers:
Replace the rollers when you see any of the following defects:
 Flat spots
 Out of roundness
 Cracked rubber
 Loss of traction (tackiness) causing pick or feed failures.
Xerox paper pick roller
Part # 401-0882-00
Hope this helps
May 21, 2009 | Xerox Phaser 8200 Laser Printer
Dell 922 All-In-One Printer will not print anything
The printer does not feed paper from the tray and then states that there is a paper jam. I have removed all paper and there isn't a paper jam. It will feed paper through the lower roller and straight into the printed paper tray, but will not feed a new sheet.
Nov 01, 2008 | Dell 922 All-In-One InkJet Printer
Will not automatically feed
I had to fix similar if not the same problem in the office today. After you load paper, the paper holder steel plank should pop up. In my case it didn't, the result was what you have described. To solve, before you close (push in) paper tray, on the lower right side of the paper tray there is a little plastic button, push it up from the buttom. This will pop up the steel plank on which paper rests, then close tray.
It worked for me...
Aug 14, 2008 | Sharp AL 1631 Copier
Brother HL-4070CDW Printer Logo
43 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
