I want install refill toner for
Sir, i have refill toner i want fix the toner. when install the cartage it showing replace cartage please guide to me
jaylex
  • 417 Answers
SOURCE: Resetting Toner count onprint settings PRINT SETTINGS report
I don't suggest refilling cartridges as I work on printers every day but seems to me that you have done everything correctly the only thing I think you have done is either filled with incorrect toner thus giving a incorrect reading or when moving gear you have dislodged the pin that activates the reset procedure.
Thanks J
Posted on Feb 03, 2008
SOURCE: samsung ml-2240 printer is not accepting refill toners please hel
my samsung printer is model ml-2240 is not accepting refill toners please help, it is showing message that toner is exuasted, even though i refilled it, plesae help?
Posted on Nov 01, 2009
pineworks
  • 4041 Answers
SOURCE: need to reset ink levels on printer (lexmark 2600)
Hi
It is the chips on the inks that make it shore empty nothing you can do about it.
But I have found this bit of read up on the internet forum Gave it a go may work if it works come back let us know so I can pass it on to others Thanks.
1 Take a small pice of clear tape. Try covering one of the outside vertical row of contacts at thr front of the cartridge. Re-insert it and it shoudl "fool" the printer into thinking it is a new cartridge. It works for my Lexmark 2600 series all in one.
2 Use clear tape over left hand row of sensors on front of cartridge and re-insert. ink now shows with question mark but reads as full and prints fine.
3 I had fully covered the contacts because it was the full length of my Scotch tape. It did not work. I went back and re-read thread, wiped the contacts the computer was telling me, took off the strip and put on just a sliver covering the left vertical side of the contact only. It worked! Yippee! Thanks a million!
Go to this website to see all
You can go to this link to see all the read up about it.
http://www.fixyourownprinter.com/forums/inkjet/35235
I not have this printer myself so I not can say if it works or not.
All The Best Hope it works for you
Posted on Jan 31, 2010
SOURCE: samsung scx-4200 refilling second time
CAN I RESET MY SAMSUNG SCX4200 TONER CHIP MANUALLY BY SOLDERING
Posted on May 03, 2010
  • 360 Answers
SOURCE: Getting below error , even
you have to reset your toner visit
www.youtube.com samsung scx 4300 toner reset.
see video
Posted on Sep 11, 2010
Replace toner and before filling the powder it shows toner low
Dear Ahmed
You have not mentioned the printer model, however if your printer use chip that has also replaced during refilling. If you are in India put a sticker on the chip contact area only.
Also the page count of the printer is based on the equivalent to 5% of standard A4 page. and irrespective to actual page consumed.
THANKS.
Mar 04, 2015 | Office Equipment & Supplies
Dear Sir, I am facing problem with my oki B410dn printer. It is showing "INSTALL TONER, 613: TONER MISSING". Would you please help me to solve the above problem. Thanks Mahmud
1 Printer off then removing tonner and shake 5 times after insert tonner then switch on printer
2 tonner powder emty then refilling tonner
Sep 25, 2011 | Office Equipment & Supplies
Kyocera FS-C5030N Led Printer My printer ran out of the blue (cyan) toner so I replaced the cartage carefully following are the cleaning steps like I've done successfully before with the other colors....
You need to reset the toner counter. This is done through the Menu button and selecting Life Counters. The instructions on how to do this are found in the Advanced Operators Guide on page 2-75. The link below will take you to the manufacture's website where you can download it.
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=14192&rid=14764
Resetting the Toner Counter
The toner containers must be replaced when the printer displays the Low toner or Replace toner message which will be given depending on the color of toner. The Low toner message will be shown as a pre-warning that the toner is running out and the printer will soon stop, at that time showing Replace toner. If you replace the toner container before Replace toner is displayed, you must manually reset the toner counter as explained below. Note that if you reset the toner counter before the toner container is replaced, the subsequent toner warnings will not be indicated correctly.
I hope this is helpful,
Shawn
Mar 09, 2011 | Kyocera FS-C5030N Led Printer
Hello sir i want to know the details of cartridge if it shows the status " The Toner is exhausted replace the toner" is there any chance to refill that one or replace it please give reply.
It depends on the Model of the printer and cartridge number. You can't refill all the cartridges. If you let me know the model of your printer and the cartridge number, I think I can help you how to refill it and how to open it apart.
Thanks.
Aug 30, 2010 | Office Equipment & Supplies
How i can refieling cartage
Its best that you go to web page of OASIS IMAGING, there are detailed instructions for Canon and HP remanufacturing.
But the most easyest way that you punch, or drill, or with soldering iron make an hole in crg, fill with toner and tape the hole.
But I recomend the Oasis whole procedure.
Jun 02, 2010 | Canon X25 Toner Cartridge for imageCLASS...
The toner life ended and then we got a refill. Earlier on refill, It was working fine, But this time it still says , TONER life end, replace toner. We tried loading 2 different refilled toners and cleaned...
we can refil toner many times but we should reset cartage, while we refiling toner to open cartage we should sides white rings middle plastick flate white plate make adownof cartage it is first methode. when we put reffiling cartage put on printer and do on at that time we push cartage right side pointo re set. look on www.brother.com
Nov 05, 2009 | Brother MFC-7820N Printer
Can we refill toshiba e-studio 207 Tonar Cartige ( Cartige No.T-1640D
sir i have Toshiba 207 copier sir now write on screen call for service C44 sir please solve my this problem thanks
Sep 03, 2009 | Toshiba e-Studio 205 Copier
How do you add toner in Samsung ML2010 printer w orig cartridge?
all samsung cartage can be refill.we use on it non magnatic dust. whi is define in ur purchase box. there is cap in cartage. from we can putdust. if ur printer shown cartage empty u shold reset it by fuse/cheap .
Jun 11, 2009 | Samsung ML 2010 Laser Printer
Sir i have brotherfaxprinter i refilled the cattriage but the printer was showing this option remove the door and replace the toner toner life over please the reply soon
If this doesn't work please let me know exaclty what model you have.
Open the front cover of the machine, press clear/back or options, the lcd should display change drum? press *00, close the front cover
Jun 11, 2009 | HP 645A Magenta Toner Cartridge (C9733A)...
Toner Refill
check this video it is very easy with no special equipment
http://www.youtube.com/watch?v=iMiTopIVMxM
hope helping you
Dec 20, 2007 | HP LaserJet 1020 Printer
26 people viewed this question
k24674
jasbo
jasbo
