Question about FocalPrice MX Google Android 4.2 Dual-Core 1.5GHz HD TV Box with RJ45 LAN Port, Built-in WIFI N Module
My android mx box as frozen wont show nuthing only start up mbox how do i get past it
  • tracy margetson
    tracy margetson Apr 23, 2015
    done all that it ain't doing nuthen quess its naccerd that's all it dose gose to start up shows @9 first then green android man then mbox nuthing after that
  • 720 Answers
Unplug from mains ...then reconnect...go into settings and check if the Ethernet or wifi is connected....sometimes restarting the router puts things right...without that you can't proceed....if you have not already done so download kodi version 14 as this seems to be quite stable.once downloaded go into API installer and direct to your internal sd to locate the Kodi apk file.once installed you can then set up your ad dons.a quick simple way is to use a community build from tvaddons.ag.if you are someone who bought from droidsticks you can use the droid stick wizard providing you still have the codes.get back to me if you are still stuck.
Posted on Apr 13, 2015
Testimonial: "it wont let me go on to settins i played round with remort keypad and it says android upgraden and statrting apps it been like that for over a hour"
  • 4 more comments
  • john cordey
    john cordey Apr 13, 2015
    If you keep getting a crash on xbmc try going into settings then apps look for Jodi and clear cache...then restart xbmc.
  • john cordey
    john cordey Apr 19, 2015
    Okay ...two things you can try....restart the box with an Ethernet cable between box and router...if you already did this then remove cable to force the box to use the wifi...it sounds as if it wants to update but can't because it is either configured to use wifi and you are using cable or it is configured to use cable and you trying to use wifi.if all u
  • john cordey
    Else fails try to reset the box entirely by using a paper clip i
  • tracy margetson
    tracy margetson Apr 19, 2015
    how do I reset it
  • john cordey
    There should be a tiny pinhole on the side next to one of the USB ports.push a safety pin into the hole whilst it is switched on and it should restart with factory settings.google updates cause this sort of crash.
  • tracy margetson
    still won't let me do nuthing tryed resetting just don't do nothing
My MBox wont go past start up screen what do you suggest?
Could be something as simple as a flattish battery
Apr 04, 2018 | Computers & Internet
I have an mx3 android box was working great. All of a sudden after I downloaded some shows try to watch them, click on android player it will not load anymore. Goes back to download screen.
Hi there, have you tried a different player like MX player or vlc? If you don't have them installed, you can download them from the play store. If your files don't play on any other player then the problem is with your downloaded files. If they work on one of the other players then the problem is with your android player. May need to be updated or it may not support the file type of your downloaded files. MX and vlc support pretty much every file type, so if your files don't work on them, then they didn't download properly or are corrupt. Hope this helps.
Jul 04, 2016 | FocalPrice MX Google Android 4.2 Dual-Core...
I have m8s tv box stuck on first page I tried the hard rest by insert toothpick on av hole nothing happen it get black tv screen
android tv box stuck on a9 cortex start up screen ? - YouTube
? 0:38
https://www.youtube.com/watch?v=M1PuUl_OjOA
Feb 6, 2014 - Uploaded by wayne nottz
android mx tv box stuck on a9 cortex boot up. ... I have the same problem gets to MBOX and stays there ...
How to factory reset the U-M8 TV box, How to restore your ...
? 4:59
https://www.youtube.com/watch?v=cHuPeWU2cTA
Dec 14, 2014 - Uploaded by EntertainmentBox
I will show you how to use the android system first and also how to reset with pin in ... ... factory reset M8 but ...
stuck on m8 box logo - FreakTab.com
Dec 02, 2015 | Televison & Video
Wont load past android logo
Give it about 2-5 minutes , if that doesn't work try holding the power and volume button until it shows you a reboot option.
Mar 31, 2014 | Hannspree SN10T1 101 Tablet
My digidesigh mbox wont install on my pc
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or you can download the drivers
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
hope this helps
May 02, 2011 | Digidesign Mbox External Sound System
G1 boot up error
when i turn my phone on it wont go to the android area. instead it shows a picture of my phone with a exclamation inside a triangle... ive tried to reset it and it wont go past this.
Jun 16, 2009 | HTC G1 Smartphone
Mbox 2
dkjkjd jheuj'y je
Jun 13, 2008 | Digidesign Mbox 2 Barebone
All the lights are on on my Mbox. it wont be recognized by pro tools. help!!
un plug it uninstall the mbox and all the asio drivers. update protools. then reinstall the mbox and all the asio drivers you should be fine.
Feb 12, 2008 | Digidesign Mbox 2 Barebone
FocalPrice MX Google Android 4.2 Dual-Core 1.5GHz HD TV Box with RJ45 LAN Port, Built-in WIFI N Module Logo
776 people viewed this question
Top FocalPrice Televison & Video Experts
john o grady
ray gallant
Are you a FocalPrice Televison and Video Expert? Answer questions, earn points and help others
