Arion television turns on but no sound nor picture what should i do?hard reset please
Television froze but when turned back on, the 1080i 60 Hz is flashing in the corner, no picture or sound
Do a factory reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 19, 2016 | Proscan Televison & Video
RCA 50 light turns blue no picture or sound
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jun 12, 2016 | RCA Televison & Video
How do I fix it
Try a hard reset to this set, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Televison & Video
Power comes on but no picture or sound
Make a hard reset to this set and try. Unplug the TV from AC mains wall socket, and re-plug it after 15 minutes or so. This will make the TV to a hard reset.
Sep 25, 2012 | Philips 42PFL3704D LCD TV
I turn my TV off everything was ok..then I turned it back on but no picture sound only ,,,why ?
you might try do a hard reset. turn tv off unplug it hold power button on tv for bout 30 sec. then plug it back in. i had a similar problem and this worked for me.
Oct 08, 2010 | Pioneer SD-P50A5-K 50" Rear Projection...
I have sound and no picture just black screen
Try a hard reset, which simply means unplugging the power cord, and replugging it after 4 hours have passed. (Turning the switch on and off does not work). This technique reprograms the electronics, to a certain extent. If the picture does not return, then you will need the expertise of a TV repairman.
Hope these suggestions, help you out. Please take a moment to rate this info, by using the rating system below. Thanks.
Jul 13, 2008 | Televison & Video
Mitsubishi WS-48613
Did you try reset? Unplug AC cord for a while,plug in try again...
2) With paper clip, activate reset thru access hole on front of
TV ( consult owners manual) recheck.....................
3) Leave set unplugged from AC overnight.................T.
Please rate this solution........................
Nov 11, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Viewsonic w3250n no sound, no picture, beeping
Hi, Any other indicators aside from the beeping sound like blinking leds/lights? For the time being try to do a hard reset, unplug the LCD TV from the mains for a couple of hours and thereafter try again with a known good outlet.. If still a no go, post back, Good luck and kind regards.
Aug 26, 2007 | ViewSonic NextVision N3200w 32 in....
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
