Hi what is 1.8 metres into ft and inches - Office Equipment & Supplies
    Sergeant:
  • 249 Answers
1.8m is approximately 6 feet.
Exactly 5.90551181 feet (5 feet 1055?64inches)
Posted on Apr 13, 2015
Conversion PSI to NM
The conversion is from inch pounds to Newton Meters
The factor: 1 Lb-Ft = 1.35582 Nm.
The direct quote: boltscience.com
Torque is a measure of how much twisting is applied to a fastener. The units used to measure torque are in the form of force times length.
The metric (SI) unit of torque is the newton metre (Nm). In inch units, torque is usually measured as Lb-Ft (pounds feet) or Lb-In (pounds inch). The Torque Converter Calculator will allow you to convert Nm to Lb-Ft or Lb-In or vice-versa. The calculator uses the conversion 1 Lb-Ft = 1.35582 Nm.
HOPE THIS helped
Torque Units Conversion Online Units Converter
Oct 25, 2016 | Cars & Trucks
How to work out how many liters in a tank 2.500mmx1.900
1000mm = 1 liter
volume of tank = area of base by height
pye ( 3.1417) X radius squared X height
the volume should come out around 5,000 liters
Jul 25, 2016 | Cars & Trucks
If 140 metres equal 4.5 inches what does 3 metres equal in feet and inches
There are several ways to do this. The easiest way to explain this is to use ratios.
140 metres 3 metres
4.5 inches x inches
Cross-multiplying we get 140 x = 3 x 4.5
Thus, x = 13.5/140
Good luck,
Paul
Apr 28, 2016 | Office Equipment & Supplies
How many feet and inches is 3 meters
An inch is defined, strangely enough, as 2.54 cm. There are 100 cm in a metre. So 300cm is 3 metres.
Setting up the ratio, we have
1 inch = x inches
2.54cm 300cm
Next, we cross multiply and get 2.54 x x = 300.
Dividing both sides by 2.54 to get x by itself.
I get 118.11". There are 12 inches in a foot, so we get 9 feet. Subtracting 108" (9x12) from the 118.11", we get 10.11" left over, so 3 metres is 9 feet 10.11 inches.
Good luck.
Paul
Apr 26, 2016 | Office Equipment & Supplies
How many square meters in 90,000 linear feet of 41.3" wide material?
First, we need to determine the number of square units in the Imperial system. We can choose to do the calculation in feet or inches.
Let's do it in inches first. There are 12" in a foot, so we multiply 90,000 by 12 to get 1,080,000 linear inches. Multiplying this by 41.3", we get 44,604,000 square inches. We can convert this to square feet by dividing the number of square feet by the square inches in a square foot. Since a square foot is one foot by one foot, or 12 inches by 12 inches, there are 144 square inches in a square foot. Dividing our previous answer by 144 will give us 309,750 square feet.
Converting to square metres. An inch is defined as 2.54 centimetres ("cm"). Thus, there are 2.54cm x 2.54cm in a square inch or 6.4516cm^2 in a square inch.
Using the 44,604,000 square inches we got above, and multiplying this by 6.4516, we get 287,767,166.4 square cm. There are 100 cm in a metre, so there are 100cm x 100cm in a square metre. So there are 10,000 square centimetres in a square metre. I get 28,776.7 square metres.
There are 3.280839895 feet in a metre. So there are 3.280839895 x 3.280839895, or 10.76391042 square feet in a square metre. Taking 309,750 square feet and dividing by the 10.76391042 we get 28,776.7 square metres.
Good luck.
Paul
Jan 08, 2016 | Office Equipment & Supplies
How many cu yards to cover 196 sq ft to a depth of 2 1/2"
Hi Bob:
1 cubic yard is 3ft by 3 ft by 3 ft.
3 times 3 times 3 equals 27, so
1 cubic yard equals 27 cubic feet.
2 1/2 inches divided by 12 inches equals .2083333 feet
196 square feet times .208333 feet equals 40.83333 cubic feet
40.83333 cubic ft divided by 27 cubic ft equals 1.5123456 cu yards.
Ta Da!!!!
May 01, 2015 | Refrigerators
Square feet converted to square metres
Simply square the conversion factor between feet and metres to get the conversion factor between square feet and square metres.
One foot is 0.3048 metres, so squaring that gives one square foot is 0.09290304 square metres.
Aug 20, 2013 | Casio Brand New-Fx-991es Plus - Scientific...
I dont know how to calculate m2
Hi, a cubic metre is a measure of volume, a square metre is a measure of area. you need to know length and width as well as depth. eg; imagine a cube is 1 metre wide by 1 metre deep by 1 metre high, this is 1 cubic metre, if you sliced this cube into 10cm slices it would cover 10m2. if you sliced it into 5cm slices it would cover 20m2. I hope this helps.
Mar 14, 2013 | Cars & Trucks
Can you tell me how much 30 cubic metres would be in feet and inches thanks
A foot is exactly 0.3048 metres and an inch is exactly 0.0254 metres. So, 30 cubic metres is about 1059 cubic feet or 1830712 cubic inches.
Aug 09, 2011 | Office Equipment & Supplies
jasbo
jasbo
