Question about Whirlpool Refrigerators
Ice maker does not seem to produce ice as fast. Is there a switch to increase/decrease amount?
  • Whirlpool Master
  • 2,963 Answers
No. Make sure the condenser coil on the bottom is clean, make sure the cooling fan for the condenser coil is working. Make sure there is enough clearance for air to reach the fan intake. Temperature of incoming water may affect the speed of Ice production if it's warmer.
Posted on Apr 13, 2015
The ice maker overflows the ice tray, so water runs down the side of my freezer.
if it has worked for 3 years then I would guess just a new tray
Feb 18, 2015 | Kenmore Refrigerators
Ice maker not producing any ice and need help
Have you tried turn it off and totally defrosting the unit. Sometimes the ice making mechanism leaks a bit of water where it shouldn't and it just frezes the mecahanism.
Oct 11, 2014 | Marvel Appliance Ice Maker
My icemaker overflows and does not produce cubes but a solid block of ice over the unit and down into the cube reception tray and over the bottom of the freezer unit. Have removed all the ice and restarted...
Hi
you need to adjust the water level, carefully remove the front cover of the ice maker itself.
On the front of the ice maker, there is a small nylon screw that controls the water intake amount.
If the screw is turned to the Right, it will Decrease the amount of water entering the ice maker.
If the screw is turned to the Left, it will Increase the amount of water entering the ice maker.
The screw should only be turned 1/4 of a turn at a time; therefore, more than one adjustment may be required.
The maximum adjustment is one full turn in either direction. Additional rotation could damage the ice maker..
OR
Dirty icemaker water valve or broken valve can cause icemaker to overflow.
Thanks for contacting fixya.com
Oct 22, 2009 | Hotpoint Refrigerators
I have a Whirlpool Model EC3JHAXRL00. The ice
Is the ice maker wire shutoff arm or switch (depending on
models) in the OFF position?
 Is the water line shutoff valve to the refrigerator turned on?
 Has the ice maker just been installed? Is the freezer
temperature cold enough to produce ice? Wait 24 hours
after ice maker hookup for ice production to begin. Allow
3 days after ice production begins to completely fill ice
container.
 Does the ice maker mold have water in it or has no ice
been produced? Make sure your refrigerator has been
connected to a water supply and the supply shutoff valve is
turned on.
 Has a large amount of ice just been removed? Allow
24 hours for ice maker to produce more ice.
 Is there a water filter installed on the refrigerator? The filter
may be clogged or installed incorrectly.
 Is an ice cube jammed in the ice maker ejector arm?
For models with an interior ice bin, remove the ice from the
ejector arm with a plastic utensil.
 Is a reverse osmosis water filtration system connected to
your cold water supply? Make sue your connections are secure.
Feb 19, 2009 | Refrigerators
Ice maker seems to be overflowing with water
check for a ice blockage inside that fill tube that sits in the ice maker.
Jan 10, 2009 | Refrigerators
Kenmore refer #70162990 ice maker leaking into storage tray
Please confirm you have given the complete model number.
If the icemaker has a bail wire to control how much ice is in the bin, there is a fill switch inside the front cover of the ice maker which allows you to increase or decrease the amount of fill.
You may also have a cracked or corroded ice mold. Check by filling the icemaker with water manually, and watching to see if it drips once the initial overfill stops dripping. This would also be indicated by the ice cubes being smaller than usual.
Jan 04, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Ice maker
sounds a liitle to fast actually, its rated for 8 cubes for "harvest"(cycle, and each cycle problably about 1:45, ittl take a while to fill the bucket , perahps 36-48 hours. once filled though maintains good normal use levels.
Oct 29, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
Ice maker
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Jun 24, 2008 | Refrigerators
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Feb 06, 2008 | Samsung RM255LASH Side by Side...
Refrigerators Logo
64 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
