Question about Karcher K 3.540 X-Series 1800 PSI Electric Pressure Washer
Brand new unit, will not turn on, the start switch just moves back and forth freely - no resistance no contact there fore it will not start.
  • Karcher Master
  • 2,992 Answers
Return to the store for an exchange.
Posted on Apr 13, 2015
What do you need help with? Hp Deskjet 2645 is showing error code and it refusrs to print
The carriage that goes back and forth when printing may not be moving freely. Turn off all power and see if you can move it back and forth easily. If not, put a drop of light oil on either side of the cartridge holder and slide it back and forth. You can also clean off the carriage rod with a cloth before oiling.
If this does not clear up the error code, the main board has failed and it will not be worth repairing, unless the unit is under warranty.
Oct 04, 2016 | HP Office Equipment & Supplies
No start at power on
did you or do you smell anything when it tries are any lights coming on with the power off try to spin in manually (with a fork or something) if it wont move motor seized better going off to get another one. if it moves freely (no resistance) the drive gear snapped a problem with plastic parts.
some resistance is what it whold be normal i would then go and check bases make sure there is no switch to the out let plug something else in and see if it works.
Mar 07, 2015 | Blenders
Embroidery compontent wont move has computer first starts up
When the embroidery unit is not connected to the machine and you power up the machine it comes up in sewing mode? Holding the embroidery unit in your hand can you move the embroidery arm back and forth and the frame carrier back and forth? Is it very very easy to move or is there resistance? If its easy, probably a belt break. If it is very very hard, take it to a dealer at least for a learned opinion.
Nov 29, 2013 | Baby Lock Sewing Machines
Bryant breaker panel Main breaker won't reset
Is the handle freely going back and forth, not having
any resistance when you move it?
Jul 13, 2012 | Electrical Supplies
I purchased a Eureka C4910 last year and have a question that I am hoping you can answer. There are two motor actions with this vacuum, 1) the vacuum suction, and 2) the beater bar. The action of the...
Good day!
Normally when the motor is easily moved back and forth means that it have a proper lubrication,proper alignment and no clogs.
When the motor and the belt is OK the problem could be on electrical wiring and switch.
If found electrical switch burned out you need to replaced it because when the switch is burn the contact of that switch is open even you turn it ON.that's why the motor is not function because the voltage is not pass through the circuit because of open switch.You need to replaced it.
And check some fuses if any and other burned electrical wire.Replaced it also.
Thank you and don't forget to rate my answer.
May 28, 2011 | Eureka C4910 Bagged Upright Vacuum
I have hercule console rmx it making static sound when moving fader and music is running slow.
Clean the contacts inside the unit with contact spray or move the switches and fader back and forth several times while the unit is unplugged.
Nov 28, 2010 | YouTube Videos
The spinning brush isn't moving
Belt may be off the motor spindle, with the vacuum off try turning the brush by hand, does it turn freely or can you feel the resistance of the motor?
May 17, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
In sinkerator will only "hum" and not run to grind food
On The bottom of the unit there should be a place to put an allen wrench. Unplug unit, Insert wrench and turn the wrench back and forth this moves the blades if the blades move freely then nothing is stuck. If wrench does not move freely, with flash light inspect inside of disposal (the rubber flaps are usually removable to gain better eye site) if objects (bones, utensil, etc) are noticed remove them and try the wrench again if now freed problem solved. If wrench turned freely from the beginning and motor still hums. Replace disposal.
I hope this has answered your question, please rate how helpful the answer was. Good Luck and Have a great day.
Apr 03, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Kenmore Garbage Disposal Blades not rotating
turn it off then on the very bottom in the center use an allen wrench to turn . wiggle back and forth until you can turn it one full time freely. this will free the blades.
Mar 14, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Karcher K 3.540 X-Series 1800 PSI Electric Pressure Washer Logo
97 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
