Question about JVC Televison & Video
My JVC MX301T keeps shutting back off into standby no matter what I do. Don't have a remote either. It turns on then shuts back off no matter how many buttons I press. Help me! Thanks!
3 Suggested Answers
  • 125 Answers
SOURCE: the door for the dvd player keeps opening and
Look here:
http://www.fixya.com/support/r4700329-cd_dvd_blueray_player_tray_keeps_opening
BR
/SciPhinx
Posted on May 06, 2010
gopakumarg43
  • 73647 Answers
SOURCE: My Samsung HT-D5530 3D Blu-Ray when in Standby mode keeps turning itself on, you press the Standby Button on the remote, it stays on Standby briefly and then 'Turns itself on
Check its mechanism for fault.
Posted on Apr 16, 2012
Standby light jvc
Most times a standby light is meant to stay on when the unit is turned off.
May 29, 2013 | Audio Players & Recorders
Mr slim indoor fan shuts off
Might change the battery on your control. I wish these had a hard wire thermostat not a big fan of the remote can be confusing.
Mar 19, 2013 | LG LS-L1210CL Mini Split Air Conditioner
Samsung model PN50C550G1FXZC shut off and won't come back on - no standby light
My guess is the power supply has failed, especially if the standby light is off
Nov 27, 2012 | Samsung Used Original PN50C550G1FXZC...
Tv keeps shutting off and when u go to turn it back on it turn's right back on.how can I fix it
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_14_2012_1_12_32_pm.jpg
May 14, 2012 | LG 50PC5D Television
We have a red light flashing on the front of the tv.It shut off and we don't know how to turn it back on.
A red flahing light is sometimes a Standby Mode. Does the power button on the remote turn it on.Sometimes the remote has multi funtions and you need to select TV for it to work.Try using the Power Button on the TV.Good Luck.
Jul 29, 2011 | Toshiba 44NHM84 TV
TV Turns Off On Its Own
Standby light flashing is error sign and shows tv got problem some where in its circuit boards.
You will notice 3 seconds long pause between red standby light flashing so count pause to pause and post how many times it flashing to diagnose problem of tv.
Thanks.
Jul 01, 2010 | Sony KP-65WS500 65" Rear Projection...
TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Dec 01, 2008 | JVC AV-32D305 32" TV
My tv keeps switching itself back onto standby, why is this ?
your tv is in shut down mode ,the voltage is to high ,it protects the tv
Oct 18, 2008 | JVC Televison & Video
Our sony tv keeps turning itself on stand by. you press the standby button on the remote and it comes back on for a few minutes then does the same again until it will not turn back on. you have to then...
When the Sony shuts down, the standby light shoulb be blinking a repeated count. Can you please post the model number and that count? The count will indicate the circuit that had a problem causing the set to shutdown.
Thanks,
Dan
Jul 24, 2008 | Televison & Video
Won't Turn On
Try reseting the system. Instructions below.
DVD reset procedure for TH-A10
1. Make sure there is no Disc in the tray.
2. Disconnect the power cord.
3. While Pressing "Stop" and "Open/Close" buttons together reconnect the power cord
4. Front display will show "TEST0".
5. Then the display will change to : "TEST1 JC2".
6. Press "Enter" button on the remote, display will show "EEPROM"
7. Press "Power" to shut unit off.
8. Reset is finished
Jun 01, 2008 | JVC TH-A10 System
Televison & Video Logo
35 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
easy alberta
easy alberta
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
