I dropped my Adler Satallite III Typewriter on the floor and a very large spring came out of it, where dose it
2 Suggested Answers
unaasp192
  • 29 Answers
SOURCE: I have a Triumph Adler Royal Satallite III model
check if it is a 50hz or 60hz.
checkthe motor has water in it or is moisten.
check the cable for cuts.
and check if you get 120v. or more than that?
unaasp192
Posted on Apr 12, 2010
Where can I find a new Print Wheel for the Adler Royal Satellite 4?
You might want to contact Will Repair Service for supplies and parts for all typewriters. www.willrepairservice.com.
Sep 15, 2014 | Royal TA Adler-Satellite 40 Typewriter
The typewriter is suddenly squeezing all the letters really close together???
Depending on the typewriter, there is a "PITCH" control putton or keyboard function, 10 pitch is pica (10 characters per inch) 12 is elite or 12 characters per inch and there is a 15 pitch which will crowd letters together. set the pitch to 10, make sure the printwheel is a 10 pitch wheel and this may work. Also there is a chrome rod runs from left to right, place a small drop of 3/1 oil on tis rod and move the carrier back and forth either by hand or tab and carriage return...
Sep 20, 2013 | Royal TA Adler-Satellite 40 Electric...
No power to royal alpha portable typewriter
If the motor makes any noise at all when you turn it on, the belt is probably broken.
Mar 19, 2013 | Royal TA Adler-Satellite 80 Typewriter
Carriage lock on adler typewriter
Turn the T/W off, slide the carrier to the R., look for debris in the carrier area. Spray some WD40 on the silver shaft that the carrier slides on.
Move the carrier back and forth to be sure tghere isn't a bind or hitting something.
DickyO
Aug 29, 2012 | Royal ADLER Satellite 40 Typewriter TA...
I have a Triumph Adler Royal Satallite III model typewriter. I replaced the blown 4 A 120V fuse and the new one blew immediately. Is there something else I can check? Thanks. Phil pnkeppel@att.net
unaasp192
Apr 07, 2010 | Royal Office Equipment & Supplies
Label stuck under typewriter platen/roller of Adler Royal
Roll a new piece of paper the best you can. Dribble a little paint thinner on the paper, letting it run down under the roller. The thinner will disolve the adhesive on the label. After a couple minutes, you should be able to roll out the paper and the laber with no problem.
Aug 28, 2009 | Office Equipment & Supplies
Royal-Adler Stellite 40 mistyping
The printwheel has lost it's home position. Release the lever holding the printwheel, remove it and re-install it. Push the lever toward the platen to lock it in. Turn the typewriter on. The printwheel should spin, the carriage should move to the left and the come back to the left margin. You should be OK after that. Let me know if it helps or not Ed
May 30, 2007 | Royal Satellite 40 Typewriter
96 people viewed this question
k24674
jasbo
jasbo
