Question about Lenovo Tablets & eReaders
Charger port broke on Lenovo a3000 tablet - Lenovo Tablets & eReaders
    Sergeant:
  • 249 Answers
Find someone close to you who does small electronics repair. Tablets are tricky and the most expensive part is the labour cost in getting the unit apart carefully and safely. I have repaired tablets and computers to component level. I also happen to be a qualified electronics engineer.
Posted on Apr 13, 2015
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 94 Answers
Most of the time they are not worth fixing since the charger port is connected directly to the main board so you would have to replace the whole board. Rich
2 Suggested Answers
  • 928 Answers
SOURCE: The charger port broke off in the tablet of Nextbook 8. Is there a way to remove/fix this?
To fix you must take apart the device. I suggest that you search for "How to repair XXXXXX on Nextbook 3"
If the port is not solder, you should be able to fix it. Best of luck.
Posted on Jan 02, 2015
My lenovo tablet is not charging it appears as if the charger port may be loose??
Hi Laura, The link below is a YouTube video showing how to fix your phone, Also there's video's down the right side of the link that may help as well....CHEERS..
lenovo IdeaTab A1000 Power on and Charging Failure Issue dead after low...
May 11, 2016 | Lenovo Tablets & eReaders
Tip
DISASSEMBLING AND CHARGER CHECKING
LENOVO S5000-F - S5000-H
Checking the Computer AC Charger
When you use the computer AC Charger to charge the tablet but no power is charged, see the instructions in this topic to check the computer AC Charger.
To check the computer AC Charger, do the following:
1. Disconnect the micro-USB cable from the tablet.
2. Measure the output voltage across the connector marked B of the micro-USB cable. Refer to the following figure:
For more pictures and description check the link bellow. On search tab type Lenovo
www.electro-medical.blogspot.com/
google.com/+AjinGopakumar
on Mar 07, 2015 | Lenovo S5000 7" Android 1GB 16GB
My Charger Port is no longer there is there any other way to charge it
Jillian, Check warranty, I beleive should be one year, call manufacturer right away if under warranty. Option 2 Have charger port replaced at a computer/cell phone repair shop. Check links below and see how they fixed this issue.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Android tablet charging port fix
How to Fix the Charging Port on Tablet
Is there any way to charge my tablet without the micro USB port
http://forums.androidcentral.com/amazon-kindle-fire/283806-anything-i-can-do-if-my-charging-port-broke.html
Apr 26, 2016 | Tablets & eReaders
How to replace charger port on Lenovo tablet?
has to be sent in to a repair shop .check with Lenovo as to where they might be Official Lenovo Support Home Lenovo Support US
Aug 14, 2015 | Lenovo ThinkPad X60 Tablet PC
How do I get my tablet to turn on
It sounds like it may not be fully charging.
If the port on the tablet is loose/damaged or the cable/charger is failing, then the tablet may not be charging even though its plugged in.
If you can, try a different cable.
Make sure the charger is the correct one for the tablet! Some tablets require more electrical current then a computer's USB port provides. Same thing applies if you are using a 'phone' charger with the tablet, might not be enough current.
Most USB ports/chargers output about 5 volts DC (direct current), but they can vary in the amount of Amps (A) or mili-Amps (mA) they produce.
FYI - the symbol used to represent Direct Current is straight horizontal line with a dashed horizontal line directly under it.
Most computer USB ports only produce 500mA.
Most phone chargers only produce 1A.
Many tablets require 2.1A or 2.4A to properly charge.
Check with your tablet manufacturer to find out what your specific make/model requires and the look closely at the charger you are using to see what the OUTPUT is ... e.g. 5.2V 2.4A
Mar 29, 2015 | Lenovo S5000 7" Android 1GB 16GB
The charge dock on tablet broke so we can not charge tablet can it be fixed? We just got it this October.
Juello. Did some research on your tablet at Amazon, (http://amzn.to/1xWx6S5) and see that they also have an AC charger (AC charger adapter with a 3.5mm power jack and delivering 5VDC 2A). Available for $5: iRulu Black AC Home Wall Adapter Cable Charger for Tablet PC 5V 2000mAh or a there's a nice replacement KB and cover: iRulu New Portable 10 1 10 5 Android Tablet USB Keyboard Case Black . I would guess the connector snapped off inside the tablet, so you will have to remove it with some tweezers. If the pin for the AC adapter broke off inside the tablet, that's a problem, but most everything can be charged from the USB port too see this website:
How To Charge Samsung Galaxy Tab 2 Via USB Port On Computer Laptop PCNEXUS (Samsung used as an example). GL
Jan 08, 2015 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
My charger plug broke off my charger cord and is stuck in the port of my tablet.How do I fix it myself?
The only way i know of is to take off the back casing and look at where the the charger port is and you might be able to remove it with an object a little bit bigger than the end of the charger. otherwise you cant do it your self withput messing something up on the tablet.
Jun 05, 2014 | Nextbook Premium 8 Se Android
If I am reading you correctly the charger port from the charger has been lodged in the tablet. Get some tweezers and pull it out very very carefully. Hopefully no damage has been done. Buy a new charger afterwards.
Tablets & eReaders Logo
210 people viewed this question
Top Lenovo Tablets & eReaders Experts
vojvodabudva
Computer Links
Are you a Lenovo Tablet and eReader Expert? Answer questions, earn points and help others
