Question about Sony Cyber-shot DSC-WX220 Digital Camera Black
My camera does not switch on at all. When I open the battery compartment I see a LED light flashing inside. Any ideas?
Battery is okay as it works on my other similar camera. I use the power supply and lead supplied but no yellow light comes on either
Arpi
  • 326 Answers
SOURCE: Camera does not turn on
Hello, reset in this case is not a solution. Maybe your lens is stuck. For further info please contact me at LIVE session. Best regards, Arpi
Posted on Jun 24, 2007
  • 67 Answers
SOURCE: My camera is not going on, I see a yellow light
Sounds like a battery problem , try buying a new battery or the camera adaptor.The battery unfortunately is faulty and wont charge.
Posted on Dec 09, 2007
  • 33 Answers
SOURCE: DSC W30 digital camera, wont power up!
This is embarrassing because I usually know what I'm doing with this stuff! I don't know why, but all it turned out to be for me anyway, is that the battery had lost its charge very quickly. I still don't know why but it's been fine since! I still ahve to cover the battery compartment door with tape but other than that, it's working as expected. Of course, I figured that out after I'd run out and bought a substitute!
Posted on Feb 19, 2009
joughton
  • 40 Answers
SOURCE: Camera won't come on
Likely you need to replace the battery. They're good only for a set number of recharges, and then they just won't store the charge anymore. The other possibility is corrosion or dirt on the battery contacts (on the battery and inside the camera) -- wipe them with a Q tip dipped in rubbing alcohol, let them dry, then try it again.
Posted on Jun 05, 2009
SOURCE: Nikon D40X quit working - memory card access lamp flashing??
As per the Samsung digimax range, internal memory seems to be faulty. Insert an external memory card and try to power up the camera.....
Posted on Jun 12, 2009
Camera won't switch on using batteries or external supply!
Dear!
Fuji product! The is so old, it is better to bring your nearest local repair shop check! But at least you can do yourself easy so you can save time and money. Check really well your camera battery contact both battery compartment inside using flash light and magnifying glass and battery cover contact. You can use eraser and rubbing alcohol to clean.
Hope you lcuk! A Professional Camera Clinic Guy!
Mar 30, 2015 | Fuji FinePix Cameras
Red light flashes but camera will not stay on
When the red LED goes on. the batteries are empty. When the LED is flashing, it is even worse.
Your camera will work with AA batteries.
Always be sure the batteries are charged.
Insert the batteries correct plus to plus and minus to minus. Only one battery the wrong way around and the camera won't work. Check contacts of the batteries and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera.
Do not use alkaline batteries unless it is absolutely necessary. In most cases, alkaline batteries have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera. They can't deliver enough power and can start leaking, causing damage to your camera.
Mar 01, 2014 | Konica Minolta DiMAGE Z3 Digital Camera
The camera (option m*5 pentax) got wet (on Songkran in Thailand). Now it works again except that it seems not to be able to load the battery. If I connect the battery charger while the camea is 'off'', the...
Normally when camera gets wet, first remove battery, use dry facial quality tissue to wipe water, keep camera in a/c so that whatsoever moisture inside camera evaporates due to low humidity in AC room for 24 hours . Take hair drier set in low heat mode holding minimum 6 inches away from camera blow warm air in battery compartment, mirror compartment, memory card slot for 2minutes each. Wait for cooling down to room temperature. Put battery switch on. It should work. Wet camera if you switching on main board get short due to flash voltage in side camera.
Sep 25, 2017 | Pentax Optio M85 Digital Camera
Cant get battery compartment open
Sorry just got this message okay here is a sequence for opening, closing and removing the battery.
I'm also supplying some diagrams. The battery compartment is a push type towards the outer edge of the camera body then it swings up and open.
Battery cover picture
Loading the battery
Removing the battery there is a little catch on the one corner that needs to be released.
Have fun with your camera
Dec 27, 2010 | Fuji FinePix F480 Digital Camera
My DMC-TZ3 battery charger green light is flashing, why ?.
I have the same problem. When I try to charge a battery the green LED onthe charger flashes green and the battery does not charge. Any ideas?
Jul 08, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Hi, my Samsung nv10 camera, when switching on, only the auto focus light comes on. The lens does not pop out or open. The only way to switch off the aoto focus light is then to remove the battery. Any...
If you have recently dropped the camera you may have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 14, 2009 | Samsung NV10 Digital Camera
When I try to turn on my DC4800, the ready light
The problem you describe is frequently due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the inside contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe the ends of the batteries and replace them in the camera. This clears up the problem about 90% of the time -- I hope it works for you.
Sep 10, 2009 | Kodak DC4800 Digital Camera
Wont charge
That does like the battery is not making a good connection to the camera,
when it in the dock it being powered by some other connection, right, so it works okay , however when using the battery only, it don't work, check the connection(s) inside the battery compartment.
Jun 16, 2009 | Fuji FinePix F410 Digital Camera
Remote not working
i've a philips video player model no  ( DVD622),remote not working
May 23, 2009 | Philips DVDR3575H/37
Sony Cyber-shot DSC-WX220 Digital Camera Black Logo
35 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
