Hello, the machine turns on, seconds later it trips the main fuse boxes, kitchen sockets fuse.
  • Mehmet Ahmet
    Mehmet Ahmet Apr 13, 2015
    Thanks for your reply, we will buy a new version we have owned this on since 1998.
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
I whould start by disconecting heater element wires the try if it dosent trip after that replace element
Posted on Apr 13, 2015
  • 2,413 Answers
You have a short some place or motor could be shot. Get it checked out by a professional.
time.
My hotpoint Aquarius washing machine keeps tripping out and won't stay on
Hello Russell;
My name is Peter. I am a retired field service appliance technician.
You did not provide your model number so I have to be general.
There are 2 components that will shut the dishwasher down after start-up.
Door latch contact switch.
images?q=tbn:and9gcrmzmahngpjk6jot1w429lw3ev-0sqso8t6pqbfm9ukveqmbaus
Turn the dishwasher power off at your breaker box. Check to make sure the power is off by turning your dishwasher on.
Remove the front of the control panel. Some units have a small front panel and other units you have to remove the whole front of door. Generally the fasteners are torque screws.
Remove the door switch. Using a multi-meter set to the lowest Ohm setting touch both contacts on the switch with the meter leads and depressing the switch in. If the meter reads 'O' the switch is good. Anything else the switch is bad.
Ohm these components the same way.
Nov 22, 2014 | Hotpoint Washing Machines
Zanussi FLE1416W trips consumer unit fuse switch.
A shorted wire or component somewhere
Nov 04, 2017 | Washing Machines
Why is my washing machine tripping my main fuse box even when I change the plug socket
by "tripping main fuse" do you mean the high amp (eg 60 amp or 100 amp) fuse that feeds the whole fuse box? if that is the case, there is too much stuff on in your house that's drawing power. The fuse box is too small to power all the stuff you have plugged in and running. Suggest turning off other high draw appliances in the house, like large TVs or microwaves or air conditioners, when running the washing machine.
Nov 18, 2013 | Washing Machines
My maytag dishwasher apparently blow a fuse in Fuse Box. I then throw the switch it worked ok, next day or two my wife try to start the dishwasher it would not turn on. I bought new fuse to put in...
It seems you may have an Electrical Insulation Break Down fault with your machine.
My suggestion would be to get a Registered Appliance Technician to test the internal circuit of the machine before attempting to switch on the appliance or rectify any fuses.
The appliance needs to be issued with a (PAT) test first to determine if the appliance is safe to touch when applying power to the machine so you dont electrocute your self.
Once the (PAT) test has been applyed then the technician can visually inspect the high voltage internal parts that could be the result of the insulation break down.
I strongly suggest if any kitchen appliance trips the main fuse for any reason I would recommend not trying to change any fuses as this second atempt to reboot the machine may have blown the machines 'Power Control Module'!
Apr 30, 2011 | Maytag 24 in. MDB9150A Built-in Dishwasher
My hotpoint aquarius wdl540 keeps tripping the switch on the main fuse for the kitchen plug sockets
hello, the reason for this because theres a dead short inside washer or the socket may have a loose wire check all the earth wires inside the washer and the sockets get back to me if you still have trouble
regards
shaun
Jan 03, 2011 | Hotpoint Aquarius WD640 Front Load...
Hygena oven trips main fuse box when switched on
sounds like that element is getting a "hot spot",high resistance area, will oven operate w/o that element in place?you also could have a bare wire touching the oven case somewhere, if it trips w/o having anything turned on remove back cover and examine all wires and connections
Aug 14, 2009 | GE Spectra JBP78 Electric Kitchen Range
Indesit washing machine WIXE127 switches off main fuse
Have you added anything else that is drawing juice on the same breaker?
If so try turning those off.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Jan 31, 2009 | Indesit WA 125 Front Load Washer
Washing machine keeps tripping electric switch
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Jan 16, 2008 | Washing Machines
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
