Question about Fisher and Paykel Dishwashers
We have a 5 year old double drawer dishwasher (DD60DCHX6). the top drawer works perfectly. The bottom drawer leaks water, from under the left side of the front panel, when the cycle draws water.
It washes perfectly, but every time the machine needs water, it also pours out from under the front panel. We did not use the machine incase there was a wet sensor issue, but the problem persists. Each time we use the bottom drawer, the amount of water leaking gets worse. Cracked water feed? Any thoughts and a solution would be welcome and thank you in advance. Caroline.
  • Caroline Foley
    Caroline Foley Apr 30, 2015
    Thank you. I checked and the machine is balanced, I can't tilt it back any further because of the cabinet and th top drawer is working perfectly.
    I was hoping to run a cycle so that I could give exact times when it leaks, but now the bottom drawer will not function at all and gives the F2 error when switched on.
    However... when we run the long 162 minute eco wash on the top drawer, at 40 minutes left, the bottom drawer starts repeatedly beeping with an F2 error.
    As I remember, when we ran the bottom drawer, it leaked water within the first few minutes - it was relevant to when the machine draws in water - but it washed and rinsed perfectly with no water left in the tray.
    Any other ideas please?
  • Caroline Foley
    Due to the F2 error, I have cleaned out the motor and surrounding area but still no joy.
    Top Expert:
  • Fisher and P... Master
  • 46,312 Answers
Personally I would call a repairman .might be a split tube or a bad gasket .
Posted on Apr 30, 2015
Testimonial: "Thank you. Problem solved by the engineer, it was 522765 ? KIT STRAINER SOFTENER ASSY."
SOURCE: Dishwasher stopped working. Suspect electronics issue.
An expert from another site says it's a faulty control panel and may need new actuators.
Posted on Feb 01, 2009
  • 17 Answers
SOURCE: vulcan dishlex mark 8 leaking water from bottom front door in wash cycle.
try adjusting the feet at the front of your dishwasher so it leans back slightly to keep the water towards the back of the washer
Posted on Dec 11, 2007
SOURCE: fisher & paykel double dish drwer
The code is a water leak problem.That is the warning
Posted on Oct 22, 2008
SOURCE: leaking dishwasher
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Posted on Feb 11, 2009
SOURCE: My Miele Turbothermic dishwasher (7 years
mine does the same! Did you ever find a solution? Tx!
Posted on Jul 23, 2010
The top drawer will not take in water. The tap symbol flashes. The bottom drawer is working perfectly. I have cleaned and checked it - no obvious obstruction in the drawer.
1 the inlet valve need replacing its bottom of the draw bit tricky to replace it to check it just unclip bottom draw to the side disconect the hose from the inlet top draw valve and turn it on for a sec see if water pumps out make sure you got small bucket if that works finne. 2 its the pump under neath the dish draw thats very tricky took me 1 hour to do
Sep 17, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
The bottom drawer is leaking
replace the pressure switch to stop the flow of water that is the cause of overflowing
Jun 04, 2010 | Fisher and Paykel DD605FD Stainless Steel...
Our two drawer dishwasher model 603dd was working - it showed the "flood button" and then the power cut out and now there is no power to it. Its two years old. Id it worth fixing?? id there anything we can...
I am assuming one of the drawers has caused water to leak into the base of the dishwasher cabinet
Disconnect the mains power connection.
Extend the bottom drawer out as much as possible. Use towels and hair dryer to dry out the base - especially the flood switch that is located towards the back middle of the base.
Leave it open until the moisture disappears. Reconnect mains power and try to start one of the drawers.
The water can leak due to kink or crack in hoses or simply too much foam from detergent.
Hope this fixes the problem - hopefully nothing to replace.
Feb 17, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Our Fisher & Paykel single dish drawer unit (6 months old) is leaking limited water from its base down the front of bottom drawer below the unit's base onto the kitchen floor. One inspection by a...
One drawer leaks can cause this problem. If you don't fix it. One day it will turn on the pumps from both units without any one touching them since the floor sensor at the bottom housing detects water and it will run for ever until you unplug the power cord. This dishwasher is a state of art in design and replacing parts is very simple once a person has enough understanding of its mechanism. If the tech fail to find the problem then he is not qualified to touch this dishwasher. When there is a leak, it is a problem with the lid seal from the top not closing down tightly so during the wash cycle, water shoot up and leaks through the top opening then collecting on the bottom housing of each unit. Let say the top draw is leak, so the bottom housing of top draw if full of water then it overflows to the bottom drawer unit then the floor. Here is the idea of how it happens. The top lid is pulled down by 2 actuators from both sides at first start. That is why you can hear the motor noise turning on at the beginning of the wash cycle. That is the noise from the actuators. If the actuators are bad. only one side works then the lid can not be sealed properly there is a leak. If bothe of actuators are week the gear worn out so they can not hold the lid down during the wash cycle then it can cause a leak. You can pull each tube out and access from the left side at the bottom to touch the bottom housing to fell the wetness. Put in tower to dry them out. If there is a weteness from the bottom housing upper tube it doesn't mean the bottom drawers is leaking. It is wet just because the top is leaking. However you have to dry the bottom in order to continue use the bottom dryer. If you ignore my advice then your circuit board at the bottom housing of lower drawer will be damaged and it is not cheap. With the information that I provided you can interview a tech claiming know about the this type of dishwasher before letting him coming into your house. Good luck.
Dec 28, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
The dishwasher top drawer is leaking all over the floor during the cycle. When the top drawer is running, It fills up the the bottom of bottom drawer with water also and then neither drawer drains...
Fisher and Paykel design a air gap kit to prevent the water back flowing to the other while one is running. it really works and worth of your money. You need to change the lid seal and a pair of actuators from the top drawer. Because of the leak then the floor switch activated not allowing a complete cycle. Need to dry out the wetness from the bottom housing of both top and lower drawers by pulling the tubes out and accessing from the left side with small tower until it completely dry. Here is a link to buy air gap kit http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
Dec 15, 2009 | Fisher and Paykel DD605SS Stainless Steel...
Kenmore Elite Drawer Dishwasher leaking
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
ppi
Jun 29, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
F&P double drawer (DD603) won't empty
Ok you need to remove the motor rotor it's under the spray arm and comes out like a light bulb from the top draw and check for anyting stuck under it or any damage done to it. Try swapping it with the one out of the bottome drawer and see if that works. When you first start the washer does it drain all the water?? if still no luck try swapping the motor contoller modules (computer board) from the top drawer to the bottom drawer and retry both drawers ,if the fault moves drawers with the part, then that part is faulty cheers
Mar 18, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel Dishwasher leaked
From what you describe, drain water from the top drawer is getting into the bottom drawer or waste water from the disposer is backing up into the bottom drawer.
1. Each drawer has its own drain hose. Each hose should terminate at the drain point with a 'Y' adapter.
2. Inspect the drain point (under the sink where the drain pipes are) to make sure this 'Y' adapter is present. (you should see two drain hoses from the DW). If not present, then the DW drain lines are not installed properly. (Someone took a shortcut and installed the 'Y' adapter behind the DW)
3. If terminated properly, make sure the drain hoses extend upward as they leave the drain point.
It is important the drain lines are connected properly to ensure proper drainage from the DW. Consult the installation manual for complete details.
Jun 08, 2008 | Fisher DD603B / DD603W / DD603H Dishwasher
Dish drawer leaks Fisher Paykel
When water accumulates in the bottom it triggers an error code and it keeps running. There is a water sensor in the bottom. I pull out the bottom drawer, mop up the water and use a hair dryer to dry the water (the more you mop up the less you need the hair dryer). Be careful to not get any of the plastic too hot. Kill the power before messing with the unit. The first time I did this it took 20 minutes to dry out. I have gotten more proficient and it take about 5 minutes now.
I had a water leak which was due to the rinse agent cap not being completely sealed. Water leaked out of a small hole in the front (I'm guessing an air vent but don't know for sure) and flooded the bottom.
I also had a leak due to having too tall a dish in the drawer and the top not sealing. I currently have a leak on the top drawer of unknown origin, but the bottom drawer still works.
Hope this helps.
May 15, 2008 | Dishwashers
Fisher & paykel double dish drwer
May 15, 2008 | Fisher and Paykel 23 in. DD603H SS...
Dishwashers Logo
142 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
