Question about Samsung Televison & Video
Backlights not coming on in samsung led tv
Backlight tries to come on twice and then remains black but do have sound. Have replaced backlight inverter and main board. Getting 5 volt reading from power board CN8105 pin 1.
    Top Expert:
  • Samsung Master
  • 74,211 Answers
Back - light problem? Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should troubles shoot. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Posted on Apr 13, 2015
Sanyo DP46142 TV comes on for approximately 30 seconds and then screen goes black. Power LED stays on.
Sounds like a backlight problem to me. If you input a signal to the HDMI or Composite input and then it goes black have you tried taking a flashlight to the screen to see if the picture is still there but just dark? That would indicate a backlight issue. That model appears to be an LED edge lit backlight, so if the picture is still there after going black your going to have to trace out the backlight circuit and see whats going on. Usually with LED backlighting if it comes on at all then the LED's are good, its just the driver supply thats failing to keep them on. Some TV's have a small separate board that provides the backlight control, but i suspect with this model its on the power supply board and not the motherboard. Have you checked that board? It could be bad caps on the power supply board, check the voltages to the backlighting when it lights up and then when it goes dark. It could just be some failed capacitors on the power supply causing that voltage rail to drop off.
May 04, 2017 | Sanyo Televison & Video
Samsung series 5. 5500 LED TV BLACK SCREEN
perhaps the backlight invertor driver circuit.
Samsung TV Repair Part Number Identification Backlight Inverters LED...
See where the wires from the long LED strips on the both sides of the screen lead you to.
does your model have separate board for backlight ? or is it integrated with TCON ?
Aug 17, 2016 | Samsung 32" Class 1080p 60Hz LED HDTV -...
How do you fix a Samsung 55" Television with no picture but good sound?
The symptoms you described would indicate the backlights are not working.
The 2 main reasons are the backlight inverter board has gone or the backlights have blown!
Since you have replaced the inverter board with a new working one then this would point towards the LED backlights.
Apr 02, 2016 | Samsung Televison & Video
Has sound, but why no backlight?
This will get you started on your troubleshooting journey.
Let me know what you find
Troubleshooting LCD Backlight Failure Samsung LNT 4066
Might be the tube light itself too
How To Replace LCD Backlight
Or the inverter
How to Fix an LCD backlight power Inverter Using Fujiplus FP 988D For 0
If you have an LED you might have better luck getting a new TV :(
Feb 10, 2016 | Samsung Televison & Video
LG 50ln5200-ub led TV . Has no picture but great sound . What is the problem ? I did the flashlight test and can see the faint picture which tells me the backlighting is out . This tv model is a Black...
usually bad power supply, Where did you source your part? return/exchange it. Bad LEDs/ possible but not as likely, Tcon working if you can see images with flashlight. You must also have backlight on signal from main board ,check for 3 to 5v on labeled connecter on power supply. UPDATE---47" & 50" LN series. This model has had LED problems if your TV acts as described by Mr. Hughes in is answer to this problem you have bad LEDs
Feb 16, 2015 | LG 50 Inch LED TV 50LN5200 LN5200 Series...
I have a Samsung LN40A450C1D TV that has sound but the backlight doesn't come on. I replaced the power supply board and same problem. I then replaced the backlight inverter. Same problem! I'm absolutely...
You have to check all the voltages, that comes from its main power supply board, to its back light inverter board. These is one pin at the backlight inverter board; comes from the main board; which controls the back-light inverter to start and off. This voltage is generated at the main board, and send to the back-light inverter board, as control voltage. It will be best to contact any service technician. If you wish to get some details; check the site linked here.Viewing it in "Mosaic" will make surf easy.
Feb 24, 2014 | Samsung LN40A450 LCD TV
Samsung LCD TV backlight switched off
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 24, 2017 | Samsung LE-46A566 46 in. LCD TV
if your TV is LCD or LED you have a faulty inverter board just replace it and your TV works fine again..
If plasma you have faulty y-sustain.
Hope it helps,,don't forget to rate and write a testimonial
Oct 28, 2012 | Televison & Video
Picture goes black, have sound, red light comes on at the on button, 60'' phillips tv
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board,will get ur picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.It a long board in shape.
Mar 16, 2010 | Televison & Video
Televison & Video Logo
70 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
