Question about Winco 15 kW PTO Generators - W15PTOS
I hooked up. it dont produce power. It has set for a long time. why
  • Winco Master
  • 1,169 Answers
If the generator doesn't have a auto field field flasher it possibe it has lost its residual magnetism. If also it is a manual pull stater the same thing can happen.
Simply reflash the rotor field and it should again generate power. The procedure varies from manufacture to manufacture.
Posted on Apr 13, 2015
Can voltage on Powermate be adjusted?
yes
the adjustment is by the rpm setting on the governor spring
thee is a nut that you adjust the spring tension with and lower the rpms and watch the voltage gauge until you get the desired voltage
if the load is going to be constant but is well within the rated capacity( example 2kva of a 6.5 kva set) of the gen set then the variation when the load comes on will be less than 5 volts
however if the power required is close to the max capacity of the gen set ( example 4.5kva of a rated 5 kva set) , then turn the unit on and adjust the rpms up to the required voltage required
remember that an advertised kva is not the rated kva
rated kva is what the gen set will produce all day and is normally around 1kva less than advertised kva
so if you have a 6.5 kva gen set ,it will handle current peaks to 6.5 kva but will burn out if required to run long time at that load
if the gen set is 1000 watts then rated watts will be less ( 750-800) for long time use
Oct 22, 2015 | Electrical Supplies
My fridge produces water which turns to ice but we dont have any water hooked up to it, how do i fix it
your freezer has defrosted without your knowledge,has someone turned the power off???
Jun 20, 2015 | Frigidaire Refrigerators
I bought a Logik car radio but every time I switch my car on I have to set the station and the time all over gain.. I dont even bother to set the time because it changes back to Midnight every time I
you forgot to hook up wire to fuse box with all time connection to power even when car is off.if u connected thw stereo red wire positive black ground theres always another wire yellow/blue/orange that needs to be connected to constant power that wire once connected will have all ur memories stations set and clock.ned to check wiring
Mar 03, 2014 | Car Audio & Video
I'm dumb. Can I hook an inverater to my generator and produce more enegry than my generator produces???
Please understand that the generator produces power from fuel with an engine wheras the invertor is one which genrerates power from a stored battery using the principle of frequency switching a DC source to induct and produce AC.
Now you can have an uninterupted power supply setting with the invertor backed up by the generator so that when the battery voltage goes down you can start and charge the invertor and also supply the extra energy .
the ratings of both must also be considered.
Sep 25, 2010 | Electronics - Others
Ive not changed any of the hook up, yet one day somethingsmelled as if burning, then no more amplification. Un hooked everything, left sit a few days then re hooked in same fashion. Now when bridged sub...
Oh i know what this is, that burning smell were some of your heat sink transistors, every amplifier has a specific number of them, if you fry a few, your amps power supply can no long disapate heat as well as it did when they were all working. So now the ones that are working are having to make up and carry the load for the ones that arent working, so to say in plain terms, they are probably running at 150% to produce the same amount of power now that some are damaged. Best fix, is to replace it. because replacing just the damage transistors will cause you to run uneven. age, and usage makes the performace of them fade over time. so if you dont replace them all your not going to be running as efficient as you were when they were new. So to save time and money, just replace the amp. Not that its one of my favorite brands rockford fosgate has the best warranty ive seen, if your amp gives you any problems just send it in after you call and get the control number and they will replace it with the exact model or a newer model. I know this because i just replaced my sisters. Hope this helps
Aug 09, 2010 | Kenwood KAC-729S Car Audio Amplifier
Spore killed ma pc
How did you check that power was going in, I wonder.
I rather imagine that something overheated and that produces your condition; resetting the BIOS is a likely solution rather than a problem, but you want to recreate the old settings....
   Are you not getting a beep code?
You should try to carefully reseat your videocard, and have your speaker hooked up so you can hear a beepcode if you get one.
I might suspect your power supply was overused also; unplug it a while and/or try a spare (being careful to replug the videocard too.)
Then make sure things are cooled right before playing again.
Killer app indeed.
Sep 09, 2008 | Intel Motherboard
Sony cdxm610
Red- Constant Power -
Yellow - Ignition power - 12v
Black - Ground
Blue - Ant & memory
Orange - Dimmer
All the wires that have 2 of the same color are speaker wires
ex - green, and green with stripe. The one with a stripe is the Negitive
In most cases the red and yellow need to be together to get the cd player to start if you dont have 2 hook ups for both constant and ignition powers.
The black ground can go to any bolt that is screwed into a metal grounded object. The blue and orange are not needed unless you have a harness that supports the dimmer and memory feature.
If you cd player works with this but wont keep settings or time, hook up the blue to the power so it can constantly save your settings.
All the speaker wires a total of 4 diffrent sets of 2 can go anywhere as long as you dont want to fade or bal your speakers if so you need to test them by hooking up 1 speaker at a time to find out where it leads to. GOOD LUCK
And
Thank you for your question
Aug 04, 2008 | Sony CDX-M610 CD Player
TV searchs for channels everytime it is powered on
the only thing i see is getting a UPS and plug tv into it. manufactures dont put batteries in tv's because most people dont unplug their tv.
using a UPS to maintain memory and plugging UPS to keep UPS battery at peak charge
Jul 29, 2008 | GE 31GT659 31" TV
Winco 15 kW PTO Generators - W15PTOS Logo
65 people viewed this question
Top Winco Electrical Supplies Experts
John Trevino
J.D. Browning
J.D. Browning
Tom Chichester
Are you a Winco Electrical Supply Expert? Answer questions, earn points and help others
